Multi RS
Settings page
The Settings menu is accessible by pressing the cog wheel from the top right of the Overview page.
The following menu options are available:
  • General: Define the general settings for the Multi RS.
  • Grid: Grid disconnect and reconnect voltage limits can be set including the option to monitor the PE to neutral voltage.
  • Battery: Adjust the charging parameters for the battery.
  • Inverter: Set the output voltage of the inverter and the behaviour of the ground relay.
  • Relay: Select from a variety of relay modes for the internal relay.
  • Aux input: Pick one function for each of the auxiliary inputs.
  • Display: Choose how the LCD backlight behaves and the preferred temperature unit.
  • AC input control: Provides various options to control when the AC input is connected or disconnected.
  • ESS: Setup the energy storage system mode, and settings related to each mode.
  • System: Designate how many units are in the system, and which phase they belong to.
Tap the three vertical dots in the top right corner of the settings page to perform the following actions:
  • Import settings from file: Import previously saved settings from a file in the settings library.
  • Save settings to file: Save the current settings to a file, which will be stored in the settings library. This file can be used as a backup to restore settings on this Multi RS, or to easily apply the same settings to another one.
  • Share settings: Share the settings file via email or other social apps.
  • Product info: Displays the Multi RS model number and serial number. There is also a switch to enable or disable Bluetooth.
  • Reset to defaults: Reset all settings to the factory defaults. This will mean that any customised settings will be lost. Setup will need to be performed again, or imported from a previously saved settings file.
