Generator programming
The Multi RS has a tolerance for irregularities on the AC input like fast frequency changes or voltage changes to improve reliability when connecting to generators.
Using a generator with the Multi RS requires firmware version v1.11 or later.
Set the following option on the General settings page:
If no grid code is set then set the following on the Grid page:
If a grid code is set then set the following two parameters on the Grid page:
Ensure that the ESS mode is set to "Keep batteries charged". |
The programmable relay contact of the Multi RS can be used to start and stop a generator. The setup is explained in the VictronConnect section.
See Limitations chapter for additional charging power limitations.
