Multi RS
Battery connection procedure
Warning
Specific care and attention must be taken when making the battery connections. Correct polarity must be confirmed with a multimeter before connection. Connecting a battery with incorrect polarity will destroy the device and is not covered by warranty.
  • Undo the two screws at the bottom of the enclosure and remove the wiring compartment cover.
  • Install a DC main switch and DC main fuse in the system and only place the DC main-fuse for the Multi RS Solar when all necessary DC connections are finished.
  • Tighten the nuts to the prescribed torques for minimal contact resistance.
