Aux Input
Each of the two Aux inputs can be assigned to a certain function.
Note
If any grid code functions for Aux inputs have been defined in the grid code settings, these will take priority. Those functions will be shown but they will be greyed out.
See the Auxiliary inputs section for more details.
There are two auxiliary inputs available via the user I/O terminal connector. These are labelled AUX_IN1 and AUX_IN2 and correspond to the ones defined in the Aux Input settings. Different functions can be assigned to each input. If the same function is applied to both inputs, then they both need to be active before any action is taken. By default, these are set to unused. Tap on the box to the right of one of the Aux inputs to select a function. |
Choose one of the options from the popup box. NoteAn Aux input is considered active when it's corresponding AuxIN+ terminal is connected to the common AuxIN- terminal.
NoteThe following two options are only available if a grid code has been set.
