8. Technical Specifications
Multi RS 48/6000/100-50 230V - PMR482604000 | |
PowerControl & PowerAssist | Yes |
Transfer Switch | 50 A |
Maximum AC input and pass-through current | 50 A |
INVERTER | |
DC Input voltage range (1) | 38 – 62V |
AC Output (2) | Output voltage: 230 Vac ± 2% Frequency: 50 Hz ± 0,1% (1) Maximum continuous inverter current : 25 Aac |
Continuous output power at 25°C | Increases linearly from 4800 W at 46 VDC to 5300 W at 52 VDC |
Continuous output power at 40°C | 4500W |
Continuous output power at 65°C | 3000W |
Peak power (3) | 9 kW for 3 seconds 7 kW for 4 minutes |
Short-circuit output current | 45 A |
Max. AC output overcurrent protection | 30 A |
Maximum efficiency | 96.5% at 1 kW load 94% at 5 kW load |
Zero load power | 20W |
Low battery shutdown | 37.2 V (adjustable) |
Low battery restart | 43.6 V (adjustable) |
CHARGER | |
AC Input | Input voltage range: 187-265 VAC Input frequency: 45-65 Hz Nominal Voltage 230 Vac Nominal frequency: 50 Hz AC inrush current: NA |
Programmable charger voltage range (5) | 36 - 60 V |
Charge voltage 'absorption' | default: 57.6 V (adjustable) |
Charge voltage 'float' | default: 55.2 V (adjustable) |
Maximum charge current from AC (6) | 88 A @ 57.6V |
Battery temperature sensor | Included |
Battery voltage sense | Yes |
Icw and Ipk requirements | Icw: 500A @ 0.1s and Ipk: 2kA |
GENERAL | |
Auxiliary output (AC-out-2) (7) | Yes |
Parallel and 3-phase operation | 3 Phase supports 1 unit per phase. Parallel not supported. |
Programmable relay (8) | Yes |
Protection (9) | a - f |
Data Communications (10) | VE.Direct port, VE.Can port & Bluetooth |
Bluetooth frequency | 2402 - 2480 MHz |
Bluetooth power | 4 dBm |
General purpose analog/digital in port | Yes, 2x |
Remote on-off | Yes |
Operating temperature range | -40 to +65°C (fan assisted cooling) |
Maximum altitude | 2000 m |
Humidity (non-condensing) | max 95% |
Earthing system | TT and TN only |
ENCLOSURE | |
Material & Color | steel, blue RAL 5012 |
Protection category | IP20 Protective Class: I |
Battery-connection | M8 Bolts |
230 V AC-connection | Screw terminals 10 mm² (6 AWG) |
Weight | 11.2 kg |
Dimensions (hxwxd) | 462 x 425 x 127 mm |
STANDARDS | |
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN-IEC 62109-1, EN-IEC 62109-2 |
Emission, Immunity | EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 Pollution Degree 2 |
Overvoltage Category | Battery: OVC I AC in / AC out: OVC III |
UPS Specification | Input: 230 VAC, 46 A, 50 Hz Output: 230 VAC, 26 A, 50 Hz, 6 kVA / 5 kW Protective device (input and output): Max 50 A circuit breaker |
1) Minimum start-up voltage is 41 VDC. Over-voltage disconnect: 65,5 V. 2) Can be adjusted to 240VAC and 60 Hz 3) Peak power capacity and duration depends on start temperature of heatsink. Mentioned times are with cold unit. 5) The Charger set points (float & absorption) can be set to max 60 V. The output voltage at the charger terminals can be higher due to compensation for temperature & voltage drop over the battery cables. The maximum output current is reduced on a linear basis from full current at 60 V to 5A at 62 V. The equalization voltage can be set to max 62V, the equalization current percentage can be set to max 6%. 6) The maximum charge current from AC sources depends on input voltage and battery current. At 230V input and 57.6V battery voltage, and 25C ambient, the maximum charge current is 88A. See manual, limitations section, for further details. 7) AC-out-2 is connected directly to the AC input and intended for non-critical loads. The AC-out-2 load is taken into account by PowerControl & PowerAssist. 8) Programmable relay which can be set for general alarm, DC under voltage or genset start/stop function. DC rating: 4 A up to 35 VDC and 1 A up to 70 VDC 9) Protection key: a) output short circuit b) overload c) battery voltage too high d) battery voltage too low e) temperature too high f) 230 VAC on inverter output 10) Not currently compatible with VE.Smart Networks. Connection to a GX device (i.e. Cerbo GX) must be made via the VE.Can interface. The VE.Direct interface is for connection to the GlobalLink 520. | |
