Multi RS19 Solar
Batteries are not being charged
There are a few situations that could cause the batteries to not charge.
This could be indicated by low or no battery current shown in the VictronConnect app.
  • The battery is full, and no more current is needed.
  • Wrong configuration (voltage or current set too low).
  • The charger is externally controlled (ESS or DVCC).
  • The battery temperature is too high and temperature-compensated charging is active or set incorrectly,
  • Reverse PV polarity.
