Technical Specifications
Multi RS19 Solar 48/6000/100-450/80 230V - PMN482602000 | |
PowerControl & PowerAssist | Yes |
Transfer Switch | 50 A |
Maximum AC input and pass-through current | 50 A |
INVERTER | |
DC Input voltage range (1) | 38 – 62V |
AC Output (2) | Output voltage: 230 Vac ± 2% Frequency: 50 Hz ± 0,1% (1) Maximum continuous inverter current : 25 Aac |
Continuous output power at 25°C | Increases linearly from 4600 W at 46 VDC to 5200 W at 52 VDC |
Continuous output power at 40°C | 4500W |
Continuous output power at 65°C | 3000W |
Peak power (3) | 9 kW for 3 seconds 7 kW for 4 minutes |
Short-circuit output current | 45 A |
Max. AC output overcurrent protection | 30 A |
Maximum efficiency | 96.5% at 1 kW load 94% at 5 kW load |
Zero load power | 20W |
Low battery shutdown | 37.2 V (adjustable) |
Low battery restart | 43.6 V (adjustable) |
SOLAR | |
Maximum DC voltage (4) | 450 V |
Start-up voltage | 120 V |
MPPT voltage range | 65 – 450 V |
Maximum operational PV input current limit | 12 A |
Max. PV short circuit current | 16 A |
Maximum DC solar charging power | 6000 W total - 3000 W per tracker |
Earth leakage trip level | 30 mA |
Isolation fail level (detection before start-up) | 100 kΩ |
CHARGER | |
AC Input | Input voltage range: 187-265 VAC Input frequency: 45-65 Hz Nominal Voltage 230 Vac Nominal frequency: 50 Hz AC inrush current: NA |
Icw and Ipk requirements | Icw: 500A @ 0.1s and Ipk: 2kA |
Programmable charger voltage range (5) | 36 - 60 V |
Charge voltage 'absorption' | default: 57.6 V (adjustable) |
Charge voltage 'float' | default: 55.2 V (adjustable) |
Maximum charge current from AC (6) | 88 A @ 57.6V |
Total maximum combined charger current (AC + PV) | 100 A |
Battery temperature sensor | Included |
Battery voltage sense | Yes |
GENERAL | |
Parallel and 3-phase operation | 3 Phase supports 1 unit per phase. Parallel not supported. |
Auxiliary output (AC-out-2) (7) | Yes |
Programmable relay (8) | Yes |
Protection (9) | a - g |
Data Communications (10) | VE.Direct port, VE.Can port, BMS Can port & Bluetooth |
Bluetooth frequency | 2402 - 2480 MHz |
Bluetooth power | 4 dBm |
General purpose analog/digital in port | Yes, 2x |
Remote on-off | Yes |
Operating temperature range | -40 to +65°C (fan assisted cooling) |
Maximum altitude | 2000 m |
Humidity (non-condensing) | max 95% |
Earthing system | TN, TT only |
ENCLOSURE | |
Material & Color | steel, blue RAL 5012 |
Protection category | IP20 Protective Class: I |
Battery-connection | Amphenol SurLok Plus - 5.7mm size - 120 A |
PV Connection | 2 strings, each with positive and negative MC4 |
230 V AC-connection | Spring-cage 10 mm² (solid wire), 6 mm² (stranded wire). |
Weight | 12.2 kg |
Dimensions (hxwxd) | 133 x 483 x 430 |
STANDARDS | |
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN-IEC 62109-1, EN-IEC 62109-2 IEC 62040, IEC 62477 |
Emission, Immunity | EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 Pollution Degree 2 |
Overvoltage Category | Battery: OVC I PV port: OVC II AC in / AC out: OVC III |
UPS Specification | Input: 230VAC, 46A, 50Hz Output: 230VAC, 26A, 50Hz, 6kVA / 5kW Protective device (input and output): Max 50A circuit breaker |
1) Minimum start-up voltage is 41 VDC. Over-voltage disconnect: 65,5 V. 2) Can be adjusted to 240VAC and 60 Hz 3) Peak power capacity and duration depends on start temperature of heatsink. Mentioned times are with cold unit. 4) The maximum PV voltage should not exceed 8x battery float voltage. E.g. If the battery voltage is 50 V, the maximum PV voltage should not exceed 8 x 50 = 400 V. 5) The Charger set points (float & absorption) can be set to max 60 V. The output voltage at the charger terminals can be higher due to compensation for temperature & voltage drop over the battery cables. The maximum output current is reduced on a linear basis from full current at 60 V to 5A at 62 V. The equalization voltage can be set to max 62V, the equalization current percentage can be set to max 6%. 6) The maximum charge current from AC sources depends on input voltage and battery current. At 230V input and 57.6V battery voltage, and 25C ambient, the maximum charge current is 88A. See manual, limitations section, for further details. 7) AC-out-2 is connected directly to the AC input and intended for non-critical loads. The AC-out-2 load is taken into account by PowerControl & PowerAssist. 8) Programmable relay which can be set for general alarm, DC under voltage or genset start/stop function. DC rating: 4 A up to 35 VDC and 1 A up to 70 VDC 9) Protection key: a) output short circuit b) overload c) battery voltage too high d) battery voltage too low e) temperature too high f) 230 VAC on inverter output g) solar earth leakage. 10) Not currently compatible with VE.Smart Networks. Connection to a GX device (i.e. Cerbo GX) must be made via the VE.Can interface. The VE.Direct interface is for connection to the GlobalLink 520. 11) Connectivity to the Victron VM-3P75CT energy meter must be made via VE.Can or Ethernet. Avoid intermediate Wi-Fi links between the energy meter and the GX device, as Wi-Fi can introduce latency and reduce reliability. | |
