Temperature sensor
For temperature-compensated charging, the temperature sensor (supplied with the unit) can be connected. The sensor is isolated and must be fitted to the negative terminal of the battery. The temperature sensor can also be used for low temperature cut-off when charging lithium batteries. You can configure this in the Battery settings page in VictronConnect.
The supplied battery temperature sensor is connected to the battery negative terminal. NoteOnly use the temperature sensor which is supplied with the Multi RS19 Solar. | ![]() |
