Multi RS19 Solar
User I/O
The user I/O terminal block is located on the bottom left hand side of the front panel.
The terminal block can be removed to make connecting small wires easier. To release it, push both orange levers (top and bottom of the connector) to the left.
Connections are made by pushing the wire into the hole. In the "TOP" orientation, the wire can be released by pushing down the orange tab next to the hole with a small flat blade screwdriver.
Note
From the factory, there is a wire link installed in the Remote_H and Remote_L position. This will enable the Multi RS19 Solar to operate by default. If this wire link, or the connector is removed then the Remote_H and Remote_L terminals become open circuit, and the Multi RS19 Solar will not turn on.
The diagram below shows the pinout of the connector and the function of each pin. The functions are also printed on the side of the connector itself.
MPPT_RS_connector_top_and_sides.svg
Pin number
Pin name
Description
1
RELAY_NO
Programmable relay Normally Open connection
2
AUX_IN-
Common negative for programmable auxiliary inputs
3
AUX_IN1+
Programmable auxiliary input 1 positive connection
4
AUX_IN2+
Programmable auxiliary input 2 positive connection
5
REMOTE_L
Remote on/off connector Low
6
REMOTE_H
Remote on/off connector High
7
RELAY_NC
Programmable relay Normally Closed connection
8
RELAY_COM
Programmable relay Common connection
9
TSENSE-
Temperature Sensor negative
10
TSENSE+
Temperature Sensor positive
11
VSENSE-
Voltage Sensor negative
12
VSENSE+
Voltage Sensor positive
