Multi RS19 Solar
Cable connection sequence
First: Confirm correct battery polarity before connecting the battery cables, connect the battery.
Second:if required, connect the remote on-off, and programmable relay, and communications cables
Third:: Confirm correct PV polarity, and then connect the solar array (if incorrectly connected with reverse polarity, the PV voltage will drop, the controller will heat up but will not charge the the battery).
