1. Knowledge Articles
  2. Understanding the Components of Your RV Electrical System
RV
Chris Wallace-Tarry
Published 03 Sept 2026
Reading Time 18min
Adventure van electrical system
This article serves as an overview of the structure of your RV electrical system. Starting with the batteries at the core of your system, we’ll go over the system’s essential functions and the components that perform them. We’ll look at the components that charge your batteries and the components that power your appliances. Next, we’ll look at the components that allow you to monitor and control your electrical system’s functioning. Finally, we’ll go over the structural components that connect your system together and ensure its safe operation.
DC and AC Power: The Lifeblood of your RV Electrical System
An RV electrical system primarily runs on DC (direct current) electricity. This is because a road vehicle’s on-board electronics run on DC electricity supplied by the starter battery. An RV electrical system can be seen as an extension of these on-board electronics; hence, it uses the same electricity standard.
Whilst 12V works well for the DC side of most RV electrical systems, 24V or 48V systems are more appropriate in some cases:
  • Higher power consumption: powering high loads at a low voltage like 12V requires thicker, more expensive cabling. Increasing voltage to 24V or 48V means you can work with smaller cables.
  • 24V or 48V appliances: you may choose to run higher-voltage appliances in your RV, and matching voltages minimises losses when converting between voltages
  • Longer cable runs: voltage drop increases with distance, so long cable runs in larger vehicles work better at a higher voltage
For simplicity, this article focuses on 12V systems, covering the majority of RV use cases. The choice of components and the way they function applies at 24V and 48V; if you need help deciding which battery voltage suits your build, see section 3.2 (‘Battery Voltage’) in our inverter/charger help-me-choose guide.
In order to run mains appliances in your RV, 12V DC electricity must be converted to 120V/230V AC (alternating current) electricity. Any appliance or device that plugs into a wall socket in your home, like a laptop charger, blender, or hair dryer, runs on mains AC electricity.
Standard voltages around the world
230V is the standard voltage for mains AC electricity in Europe, Australia, New Zealand, and most of Asia. 120V is the standard voltage in Canada, the USA, and most of Central America.
Converting from 12V to 120V/230V in an RV requires an inverter or inverter/charger. We’ll look at those in more detail in a later section. An RV electrical system with an inverter installed thus has two interlinked electrical systems; a 12V DC main system, and a 120V/230V AC subsystem.
Let’s take a look at the components that make up your RV electrical system, starting with the the core of that system: the leisure battery.
Leisure Batteries: The Core of Your RV Electrical System
Leisure batteries store the electricity that power devices and appliances. Whilst the RV’s starter battery powers factory on-board electronics like cabin lights, radio, and electric windows, it lacks the capacity to power campervan appliances. For the higher-capacity power storage that makes an RV a home on wheels, you must install leisure batteries.
victron-lithium-leisure-battery-hero-image
Leisure Battery Capacity
The capacity or ‘size’ of a leisure battery refers to the amount of usable electrical power it’s capable of storing. A bigger battery allows you to run a greater number of higher-power devices for longer before recharging. Battery capacity is quoted in amp-hours (Ah). The capacity of your chosen leisure battery is determined by the following factors:
  • The combined power draw of your on-board appliances in Amps (A)
  • The number of hours you want to be able to use each appliance every day
  • The number of days you want your battery to survive between charges
  • The usable capacity of your leisure battery
Usable Capacity and State of Charge
The usable capacity of a battery differs from the battery’s rated capacity in that many batteries shouldn’t be discharged until they’re empty. The degree to which a battery is charged is referred to as its state of charge (SoC). A battery at 100% SoC is fully charged, whilst a battery at 0% SoC is empty: fully discharged. Regular discharging to 0% or close to it significantly impacts a battery’s overall lifespan: that is, the length of time a battery remains usable. Think of how your phone’s battery gradually performs less well over the years, and imagine the same happening to the leisure batteries at the core of your RV electrical system. To preserve your batteries, regular deep discharging should be avoided. A lead-acid battery discharged to 0% can be rendered completely unusable if it's left that way, necessitating a full replacement.
Image comparing the usable energy of lead-acid vs. lithium batteries
Battery Chemistries: Lead-acid and Lithium
This is where different battery chemistries come in. The principal difference between lead-acid leisure batteries and lithium leisure batteries is that lead-acid batteries should only be discharged to around 50% SoC, whilst lithium batteries can handle more frequent discharging to 20% or even 0%. Lithium batteries also have longer lifespans regardless of state of charge, charge more quickly, and weigh less. Our article on upgrading from lead-acid to lithium has much more information on the differences between the two types. For more information on the different types of lead-acid batteries, take a look at our deep dive article.
How deeply can lithium batteries be discharged?
Whilst lithium batteries can be fully discharged to 0% without immediate serious damage, regular deep discharging damages the battery over time, reducing its overall lifespan. For this reason, we recommend that lithium batteries are not regularly discharged below 20%.
For more detailed information on properly sizing your RV leisure batteries, take a look at our step-by-step guide. With leisure batteries covered, let’s take a look at how you’ll keep those batteries charged.
Charging Methods: Keeping Your RV Electrical System Running
RV electrical systems are charged in four ways: via a connection to mains electricity (shore power), from solar power, from the RV’s engine via the alternator, and from a generator. The charging capacity of these components is largely determined by the size of your batteries, which is why it’s important to size your batteries first.
Alternator Charging
Alternator charging is the other primary off-grid charging method, and relies on charging from the RV’s running engine via the alternator. The alternator is an electrical device that takes a small amount of power from the engine to charge the vehicle’s starter battery and power electrical components like headlights and windscreen wipers. This device can be tapped into and used to charge leisure batteries whilst the engine is running.
Split Charge Switches and Relays
The alternator can be wired into your RV electrical system in a number of ways. Simpler options like manual relay switches, split charge relays, and split charge diodes are cheap and simple but inefficient, unable to charge modern leisure batteries to 100%, and offer no protection from overcharging the battery. Voltage sensitive relays and FET battery isolators are more efficient, but are unable to charge lithium leisure batteries as they can’t vary their output voltage and thus can’t provide the high voltage needed to charge a lithium battery at the end of its charge cycle.
DC-DC Battery Chargers
DC-DC chargers, also called smart chargers or battery-to-battery chargers, have become standard for most RV electrical systems. They’re highly efficient, as they’re smart enough to charge a leisure battery based on its chemistry, charge state, and temperature. This also allows them to charge batteries to 100%, unlike other alternator charging technologies.
DC-DC charger in RV power system
Names for DC-DC chargers
DC-DC chargers are referred to by many names. The terms DC-DC charger, smart charger, battery-to-battery charger, and B2B charger all refer to the same type of device.
A quality DC-DC charger incorporates a full suite of safety features, protecting against overheating, battery overcharging, and dangerous malfunctions. They’re also the only kind of alternator charging device that is capable of charging a lithium leisure battery. Finally, DC-DC chargers are the only split charging device compatible with smart alternators. Smart alternators started replacing standard alternators in about 2016. They output a fluctuating voltage which allows the engine to operate more efficiently, but which can only be moderated by a DC-DC charger.
Solar Charging
Solar power is one of two off-grid charging methods available to RV travellers. Once you leave the campsite or your driveway, off-grid battery charging gives you independence on the road. A solar charging system is composed of two main components:
Solar Panels
Solar panels convert sunlight into usable electricity. These are usually mounted on your RV’s roof, as it’s a large space where panels can be permanently fixed. Solar panels come in two types:
  • Rigid solar panels are bulkier and mount to brackets on the roof. They’re the most efficient and durable solar panel type, but they’re more difficult to install.
  • Flexible solar panels are much lighter and thinner, sticking directly to the roof and conforming to its curves for a very easy, hardware-free installation. They are, however, less efficient and don’t last as long as rigid panels.
Solar panels can be mounted singly or in arrays of two, three, or more panels. The size of a solar array is determined by the size of the leisure battery it’s charging and how quickly that battery needs to be charged. Read all about solar system sizing in our handy guide.
rv-solar-array-top-down-view
Solar Charge Controller
A solar charge controller sits between the panels and the electrical system, regulating the incoming power and safely charging the battery. Charge controllers come in two main types:
mppt-solar-charge-controller-installed-2
Also worth noting are all-in-one combined MPPT and inverter/charger units. Read all about the design and cost of a full RV solar system in our comprehensive guide.
Shore Power Charging
Shore power refers to a fixed mains electricity connection; the term comes from sailing, where a boat is plugged into an on-shore distribution point when docked. RV users typically plug into a similar point or ‘post’ when parked at campsites, or they may run a cable from their home electricity supply.
A shore power connection has two functions:
  • Charging leisure batteries
  • Directly powering high-wattage appliances, bypassing the RV’s leisure batteries
These two functions are mediated by a battery charger. A battery charger takes power from the shore connection and uses it to safely and efficiently charge your leisure batteries. Generally, this power comes into the van via a shore power cable and an external shore power inlet, wired into a consumer unit. We’ll discuss consumer units in the section on fusing and grounding below.
rv-shore-power-connection-inlet
A battery charger is the simplest shore power solution, but an inverter/charger is more suitable if you want to run AC appliances off-grid, not just at a campsite. An inverter/charger charges your leisure batteries from shore power, converts DC battery power to AC mains power, and automatically switches between battery and shore power for seamless charging when you pull up to or leave a campsite. Our help me choose guide on inverter/chargers has all the information you need about these versatile, efficient devices. For a beginner’s guide to RV shore power in general, our explainer has everything you need.
Generator Charging
Generators can be used to provide AC power, which is functionally the same as charging with shore power via a battery charger or inverter/charger. Generators can be carried for running appliances with power demands that are more than leisure batteries can handle, like washing machines and air-conditioning. They’re also useful as a last-ditch backup solution for when solar and alternator charging are unable to keep leisure batteries alive.
With batteries and charging methods in place, we can now look at using those batteries to power appliances and devices.
Battery Loads: Inverters
As mentioned earlier, an inverter is a device that takes DC electricity from your leisure batteries and converts it to AC. This allows you to run domestic appliances in your van and install mains plug sockets like those in your home. Inverters are complex devices, and there are a number of factors that differentiate them:
  • Waveform: inverters are divided into two families by the type of waveform they produce; pure sine wave and modified sine wave.
  • Surge and continuous ratings: inverters are ‘sized’ by their maximum carrying capacity in watts or volt-amps. They also have a secondary capacity which determines their ability to support high initial inrush currents from the powering-on of certain appliances; these two ratings are the inverter’s continuous and surge ratings.
  • Efficiency: this is a measure of how much power is lost in the conversion from DC to AC, and varies with manufacturer and inverter capacity.
Power ratings: watts and volt-amps
Many inverters and appliances quote power ratings in watts (W). Victron’s inverter power ratings are quoted in volt-amps (VA). This is a more accurate measure of the inverter’s power output, as power output in watts changes with temperature and the efficiency of powered appliances. Check product datasheets for surge and continuous ratings and to understand how the watt rating of a given inverter changes with temperature.
Inverter/chargers
As mentioned in the section on shore power charging, an inverter can be combined with a mains battery charger in a single unit, called an inverter/charger. This is a space-efficient solution with an easier installation than a separate inverter and charger. Learn all about the above factors and choose an inverter/charger that suits your needs with our handy guide.
multiplus-installed-in-rv
Having covered the AC subsystem, we’ll move on to the other side and look at DC loads powered by your leisure batteries.
Battery Loads: DC Loads
DC loads are devices and appliances that run on DC power directly from your leisure batteries. These might be lights, fans, water pumps, charging ports, or heaters. A fridge is a key DC appliance found in most RVs.
These devices are all powered by your batteries via a DC fuse box and busbars. We’ll take a look at fusing and distribution in later sections.
With our batteries in place, charging systems keeping them powered, and AC and DC loads connected, we can look at solutions for monitoring your RV electrical system’s performance.
System Monitoring and Automation: The Brain of Your Electrical System
System monitoring allows you to see what’s going on in your battery and how all your electrical components interact. Monitoring setups vary in their complexity, ranging from phone-based readouts showing battery status and charge efficacy to integrated dashboards with the whole electrical system on display.
A complete entry-level solution is a SmartShunt. This device wires directly to your leisure battery and gives you essential battery status information:
  • Battery state of charge
  • Input current
  • Output current
  • Battery voltage
  • Time remaining
  • Historic data such as discharge depth and charge/discharge cycles
  • Other useful information like battery temperature, starter battery voltage, and battery midpoint in a series-wired battery bank
This data is visible using the VictronConnect app, an easy-to-use mobile dashboard. A simple screen display can be added by plugging in a BMV-700 display module, or by installing a BMV-712 Smart, which includes both Bluetooth and screen in one package, plus a configurable alarm for audible alerts and a programmable relay for automation.
victronconnect-v5-22-new-blue-smart-charger-features-and-more-featured
The VictronConnect app also displays information from Smart Victron products. Any device with ‘Smart’ in the name or a Bluetooth logo on its casing can connect to your phone and integrate into the VictronConnect app dashboard. This allows you to build out an integrated monitoring suite where the performance of specific devices is displayed, so you can see how effectively each charging source charges your batteries.
Going one step further, the addition of a communication centre like a Cerbo GX or Ekrano GX brings in data from your entire electrical system. It allows every device in the system to communicate with every other device, maximising performance. GX devices talk to the Victron Remote Management (VRM) dashboard, where you can remotely access granular performance data and fine-tuned control of every element in your electrical system. Discover everything you can do with the VRM dashboard here.
victron-remote-management-vrm-body-1
Complete your monitoring suite with a touchscreen display, integrating a monitoring and control dashboard into your van’s living area. Alternatively, choose the Victron Ekrano as your communication centre, which combines the functionality of a Cerbo GX with a large touchscreen in a single, compact device. You can also create your own DIY GX display using a repurposed Android phone or tablet and the Android GX WiFi Display app.
gx-touch-screen-in-situ
System Automation and Control
The GX monitoring ecosystem’s utility can be vastly extended as a programmable control dashboard using Venus OS Large. This is an extended build of the standard GX software which adds automation and deep system integration, compatible with 3-rd party devices. Using Venus OS Large, you can program custom functionality into your GX-integrated electrical system, like:
  • Integrate a 3rd-party weather device like a barometer or solar irradiance forecast into your VRM dashboard, and use this to predict solar power generation in advance
  • Set your inverter/charger to turn on at a specified time each morning and turn off at a specified time every night, so AC power is there when you need it and forgetting to power it off doesn’t drain your batteries overnight
  • Turn on an outdoor lamp at dusk and turn it off at dawn, with daylight determined by your SmartSolar MPPT’s incoming voltage level
There’s also a fully customisable monitoring UI with custom graphs, gauges, switches, and sliders, which you can use to augment VRM far beyond its default data display capacity. Learn much more about what you can do with Venus OS Large here.
Wiring and Distribution: Connecting it All Together
Wiring up your electrical system is made easier by starting with a wiring diagram. A wiring diagram is a schematic that clearly shows wire connections between components. From the wiring diagram, it’s easier to plan the gauge (thickness) of each wire, how each wire will be fused, and where distribution points fit in. Beginners to wiring might like to start with the Victron Toolkit App, or by reading our free ebook, Wiring Unlimited.
Distribution refers to the use of common connection terminals to organise electrical connections. The use of a busbar to distribute battery power, for example, allows a single battery cable to be split into multiple outputs. Your DC fuse box, powering your smaller DC loads (lights, pumps, fridge etc), incorporates busbars, again allowing for one input and multiple smaller outputs.
fuses-and-busbars-in-situ
Victron’s Lynx Distribution system is a modular system based on a battery input terminal and a fused busbar pair. Power coming from the batteries is received by the Lynx Power In, a self-contained busbar with room for four battery inputs, plus a ground connection. The Power In connects without wires to the Lynx Distributor, a fused busbar which organises and sends power to your DC loads whilst displaying fuse status on the front panel. The Lynx system can be capped off with a Lynx BMS, which once again connects without the need for wires, and provides battery monitoring and connectivity like a SmartShunt. A Cerbo GX can be added to the Lynx system for sophisticated system-wide monitoring.
lynx-system-in-situ
The Lynx system is an excellent way of simplifying your wiring and distribution, all whilst bringing your DC loads into your VictronConnect app or GX-powered monitoring ecosystem.
Fusing and Grounding: Keeping You and Your RV Electrical System Safe
The final, but arguably most important, element of your RV electrical system is fusing and switching. Fuses automatically cut power to a circuit when an overload occurs, protecting you from short circuits or malfunctions and preventing dangerous electrical faults, fires, and damage to your components. Each circuit in your electrical system should be protected by a fuse. They come in a number of forms:
  • In-line fuses are individual fuses that sit within a single cable run. They’re integrated into the cable run with a fuse holder.
  • Battery terminal fuses are individual, large fuses, that specifically protect your leisure battery.
  • Fused busbars and fuse boxes organise fuses in a single unit, eliminating the need to fuse each individual cable run with an in-line fuse.
The Lynx Power In fulfills the joint function of a battery distribution busbar and a battery fuse, eliminating the need for separate battery fuses. The Lynx Distributor both distributes DC loads and fuses the individual circuits, also eliminating the need for individual in-line fuses for each circuit. For the many small circuits powering your various DC appliances, we recommend a DC fuse box, which fuses and distributes power to these DC loads in a single unit.
Switches
Isolation switches are another important safety component; wiring an isolation switch immediately downstream of your batteries allows you to safely kill power to your entire electrical system. This is important for any inspection and maintenance work, or if you plan to leave your RV unattended for a long time.
Breakers and Consumer Units
Breakers are resettable fuses which are commonly used in AC systems. You may recognise them from the fuse box in your home; they’re also used to protect AC systems in an RV. When installing your inverter or inverter/charger, you must also install breakers, organising them in a consumer unit. The consumer unit combines inverter fusing with inverter grounding.
Shore power connection wiring diagram
Grounding
Grounding is the final safety consideration for your RV electrical system. Grounding acts in conjunction with your fuses to protect you and your electrical system from short circuits. The following elements of your system must be grounded:
  • Negative DC busbar: the busbar connecting your battery to the rest of your electrical system
  • Shore power consumer unit: the fuse box for your shore power’s AC outputs
  • Inverter and inverter consumer unit: the fuse box for your inverter’s AC outputs
  • DC-DC charger
  • Any electrical components with a metal outer case
Grounding and fusing are critical safety components and it’s important to get them right. Make sure you consult our Victron Toolkit app and the Wiring Unlimited ebook for much more information. Remember, there’s no harm in seeking advice from one of our authorised distributors and installers.
Consult a professional for your electrical installation
Improper wiring, fusing, and grounding can cause electrical faults which damage or break your electrical components, cause fires and explosions, and injure or kill RV users. If you’re not certain of the safety of the system you’ve designed, consult a professional.
Final Thoughts
We’ve now covered the essential components of an RV electrical system. Planning these systems can be daunting, so taking the time to understand each component and how they fit together is key.
If you can’t find the information you need in the resources signposted in this article, take a look at the Victron Community space. This is a free forum where you can ask questions and get answers from Victron experts and other installers.
