1. Knowledge Articles
  2. The most common types of lead-acid batteries
Justin Tyers
10 Aug 2026
lead-acid-battery-composition-types
Not all lead-acid batteries are built the same way. They can differ in the alloy used to harden their plates, how their electrolyte is held (liquid, gel, or absorbed glass mat), and their mechanical construction — all of which affect performance, lifespan, and maintenance needs. Below, we break down these differences to help you understand which type suits your needs.
Lead-antimony and lead-calcium
Lead is alloyed with antimony (and other elements) or with calcium to make it harder, more durable and easier to process. For the user it is important to know that compared to lead-calcium batteries, batteries alloyed with antimony have a higher rate of internal self-discharge and require a higher charge-voltage, but also will sustain a greater number of charge/discharge cycles.
Wet or flooded versus starved (gel or AGM) electrolyte
The electrolyte in a battery is either liquid - known as ‘wet’ or ‘flooded’ batteries; or it is ‘starved’ - formed into a gel, or absorbed in microporous material known as the absorbent glass mat (AGM battery).
When nearly fully charged, wet or flooded batteries will start “gassing”, which is the result of water being decomposed into oxygen- and hydrogen gas.
In batteries with starved electrolyte, oxygen gas formed at the positive plates migrates to the negative plates where, after a complicated chemical reaction, it is “recombined” with hydrogen into water. No gas will escape from the battery. Hydrogen gas is formed only if the charge voltage is too high. In case of excessive charge, voltage oxygen and hydrogen gas will escape through a safety valve. That is why these batteries are also called VRLA (Valve Regulated Lead Acid) batteries.
These batteries may be distinguished on the basis of their mechanical construction and purpose:
The flat-plate automotive battery (flooded)
This is the battery used in cars. Not suitable for frequent deep discharging, it has thin plates with a large surface area designed purely for the short-term high discharge currents which are ideal for engine starting.
Nevertheless flat-plate heavy-duty truck starter batteries are often employed as house batteries in smaller boats.
The flat-plate semi-traction battery (flooded)
This battery has thicker plates and better separators between the plates to help prevent buckling of the plates and shedding of the active material under cyclic use. It can be used for light duty cycling and is often referred to as a ‘leisure’ duty battery.
The traction or deep-cycle battery (wet)
The thick plate deep-cycle battery must be charged, at least from time to time, at a relatively high voltage. How high depends on chemical and constructive details and on the charging time available.
High charging voltage is needed to reconvert all sulphate into active material, and to help prevent stratification of the electrolyte. Once the gassing voltage is reached, charging is continued with plenty of current (and therefore a high voltage). The resulting gas generation ‘stirs’ the electrolyte and ensures that it becomes well mixed again.
The sealed (VRLA) gel battery
Here the electrolyte is immobilised as gel. Silica is added to the sulfuric acid electrolyte, causing it to set into a thick, gel-like paste rather than remaining a free-flowing liquid. This makes the battery fully sealed and spill-proof, so it can be mounted on its side or at odd angles without leaking. Gel batteries also tend to tolerate deep discharges well and have a long service life, but they charge more slowly and are more sensitive to overcharging than AGM batteries, so they typically need a charger with a gel-specific charge profile.
The sealed (VRLA) AGM battery
AGM stands for Absorbed Glass Mat. In these batteries the electrolyte is absorbed (“sucked up”) into a glass-fibre mat between the plates by capillary action. In an AGM battery the charge carriers, hydrogen ions (H2) and sulphate ions (SO4), move more easily between the plates than in a gel battery. This makes an AGM battery more suitable for short-time delivery of very high currents than a gel battery.
VRLA batteries offer greater ease of use than wet or flooded batteries as they’re maintenance free; don’t gas (provided that the battery is not charged with excessive voltage), and can therefore be installed in out of reach spaces with difficult access.
On the other hand sealed batteries are very sensitive to overcharging (the exception is the spiral-cell battery). Overcharging results in gassing (through the safety valve) which means water loss that can never be replenished, resulting in capacity loss and premature aging.
Comparison table of different lead-acid battery types
Battery Type
Application
Maintenance
Lifespan
Depth of Discharge
Charging Voltage
Flat-plate automotive battery (flooded)
Engine starting; short-term high discharge currents. Not suited to deep or frequent discharging.
Electrolyte checks
Shallow (10-20% DOD): ~1,200-1,500 cycles Standard (50% DOD): ~250-500 cycles Deep (80% DOD): ~50-100 cycles
Low - designed for shallow discharge only, not intended for deep cycling (~30-50% DOD)
Standard charging voltage for starting batteries (~14.4-14.5V)
Flat-plate semi-traction battery
Light-duty cycling; "leisure" use where occasional deeper discharge is needed
Shallow (10-20% DOD): ~800-1,000 cycles Standard (50% DOD): ~300-500 cycles Deep (80% DOD): ~150-200 cycles
Moderate - better tolerance than automotive type (~50-60% DOD)
Standard voltage, slightly extended for light cycling use (~14.4-14.6V)
Traction or deep-cycle battery (wet)
Repeated deep discharge/recharge cycles; requires periodic high-voltage charging to prevent sulphation and stratification
Electrolyte checks, periodic high-voltage charging
Shallow (10-20% DOD): ~1,500-2,000 cycles Standard (50% DOD): ~500-800 cycles Deep (80% DOD): ~300-500 cycles
Higher - designed for deep discharge (~80% DOD)
Higher voltage needed to reach gassing point and re-mix electrolyte (~14.4-14.9V,
Sealed (VRLA) gel battery
Situations needing a maintenance-free, non-spillable battery; lower current delivery than AGM
Maintenance-free
Shallow (10-20% DOD): ~1,000-1,200 cycles Standard (50% DOD): ~300-500 cycles Deep (80% DOD): ~150-250 cycles
Moderate - suitable for regular partial discharge (~50% DOD)
Lower voltage required to prevent gel electrolyte damage (~14.2-14.3V)
Sealed (VRLA) AGM battery
High-current, short-duration delivery; suited to hard-to-reach installs
Maintenance-free
Shallow (10-20% DOD): ~1,200-1,500 cycles Standard (50% DOD): ~400-600 cycles Deep (80% DOD): ~200-300 cycles
High - can handle deeper discharge cycles better than gel (~80% DOD)
Higher voltage tolerance allows faster, high-current charging (~14.7-14.8V)
