1. Battery Monitors & Batteries
  2. Battery monitors
SmartShunt
The SmartShunt is an intelligent battery monitor providing detailed usage insights via the VictronConnect app. Compatible with any battery type, it's available in IP-rated versions and easily (retro)fitted without cable clutter.
SmartShunt
SmartShunt
SmartShunt
background
  • 99.6% accuracy
  • VictronConnect App
  • In-app battery and DC flow insights
  • Remote Management optional
  • Wireless data sharing
  • SafetyShield+
Models:
IP21: 300A, 500A, 1000A, 2000A - IP65: 300A, 500A, 1000A, 2000A
Year warranty
World-wide support
The brains to ,[object Object],your battery
The brains to
your battery
  • Instant battery and DC energy insights
  • IP65 models available
  • Real-time app alerts
  • Easy setup & retrofitting
Everything you need and want to know
Keep track of all important battery information on your smartphone, in real-time. Metrics include state of charge, time remaining, voltage, current, amp hours, number of charge cycles, and deepest discharge.
System-wide charging efficiency
The SmartShunt shares battery voltage, current, and temperature with connected chargers to enhance charging efficiency and extend battery life. Connect wirelessly via VE.Smart Networking or plug it into a communication centre (optional).
Easy (retro)fitting
Quick installation with minimal wiring. Perfect for clean, clutter-free battery monitoring.
AUX cable options
Monitor starter battery voltage, track battery bank balance, or connect a temperature sensor for more accurate charging.
Optimise system setups with smart functionalities
Easy setup & integration
Get started quickly with VictronConnect, our user-friendly smartphone app trusted by millions worldwide. Extensive battery presets make configuration simple for new or existing systems.
See all important battery and DC flow data instantly in the VictronConnect app—no Bluetooth pairing delays. Access live performance and load metrics, plus 30-day battery history whenever you need it.
IP65 water- and dust-resistance*
The IP65 rating ensures water and dust resistance, even in the toughest conditions. Tested and trusted by professionals worldwide.
* IP65 models only
Extended battery life
The SmartShunt prioritises battery care with SafetyShield+ features, built on decades of battery know-how. Features highly accurate shunt technology and configurable alarm notifications to keep you informed.
VE.Direct port
The VE.Direct port connects to a communication centre for access to VRM, Victron's remote management portal. Configure settings, check system data, analyse performance, and actively manage your system from anywhere in the world.
One solution for every battery
The SmartShunt delivers highly accurate data for a wide variety of battery chemistries, including Lithium, AGM, and Flooded. Use the VictronConnect app to optimise settings or create a custom profile for your specific battery.
Features
A fully-featured ecosystem
The Victron system is designed to give you complete control anytime, anywhere.
  • VRM - Remote Monitoring portal
  • Settings lock
The pocket powerhouse
The VictronConnect app connects you to your energy system, delivering real-time data and a 30-day performance history. Configure devices, update firmware, and create custom alarms, easily adapting a setup to your exact needs.
Master remote management
Connect to the Victron Remote Management (VRM) portal with a communication centre to operate your system remotely. Use VRM app widgets, create custom data views to monitor key parameters, manage multiple systems simultaneously, and set up alerts to prevent issues.
Safeguard critical configurations
Prevent accidental or unwanted changes to device and system settings with settings lock. Protect vital configurations with a password so only the system administrator can make changes. Especially useful for installers managing multiple systems.
Applications
Applications
Recreational Vehicles
Go off-grid with confidence. Whatever your vehicle or trailer of choice may be, our products will power your adventures on and off-road with an energy system built for your setup.
Marine
With our marine power background, we've built the most complete range of onboard energy solutions based on real customer needs.
Off-grid systems
Keep an eye on your batteries with in-depth data and insights. Or use the SmartShunt as a versatile DC energy meter.
Professional Vehicles
As the world market leader in ambulance power supplies, our decades of know-how create robust, professional systems that deliver when failure is not an option.
Powered by decades of know-how
The Blue Power ecosystem
Our modular ecosystem of robust building blocks is designed for maximum performance and efficiency. All products work together as one system and can be managed remotely, from a few feet to thousands of miles away.
Ecosystem
