19. Technical specifications
19.1. Technical specifications
Nucleo GX(1) | |||
Supply voltage | 8 - 70V DC | ||
Communication ports | |||
VE.Direct ports (always isolated) | 2 (max. possible VE.Direct devices: 25)(3) | ||
VE.Can 1 | Yes - isolated | ||
VE.Can 2 | Yes - non-isolated | ||
Ethernet | Yes | ||
Wifi | Yes | ||
Bluetooth Smart | Yes(4) | ||
Bluetooth Frequencies and Power | 2.402 - 2.48GHz | 5,2 mW | ||
Wifi Frequencies and Power | 2,4 GHz Wifi | Range: 2,412 - 2,462 GHz | 88,1 mW | ||
USB Host ports | Yes – 3 x USB-A (max. 1,5 A @ 5 V combined) | ||
MicroSD Card Slot | Yes – SDHC cards up to max. 32GB | ||
Remote Console Access | |||
The Nucleo GX has no built-in I/O interfaces. For analogue, digital, or relay connectivity, use a GX I/O Extender 150 and/or a GX Tank 140, or alternatively select a Cerbo GX or Ekrano GX. | |||
Access Methods | Web Browser | ||
Other | |||
Mounting | Wall or DIN rail (35 mm)(2) | ||
Buzzer | Yes | ||
Button | Yes (Network reset) | ||
LEDs | 2 (Bluetooth status / WiFi Access Point) | ||
Protection category | IP20 | ||
Dimensions | |||
Outer dimensions (h x w x d) | 78 x 154 x 48 mm | 3,07 × 6,06 × 1 ,89 in (without connectors and mounting accessories) | ||
Operating temperature range | -20 to +50 °C | ||
Standards | |||
Safety | IEC 62368-1 | ||
EMC | EN 301489-1, EN 301489-17 | ||
Automotive | ECE R10-6 | ||
(1) For more detailed information about the Nucleo GX please visit the Victron GX product range page.
(2) DIN rail mounting requires an additional accessory - DIN35 adapter small.
(3) The listed maximum in above table is the total connected VE.Direct devices such as MPPT Solar Charge controllers. Total means all directly connected devices plus the devices connected over USB. The limit is mostly bound by CPU processing power. Note that there is also a limit to the other type of devices of which often multiple are connected: PV Inverters. Up to three or four three phase inverters can typically be monitored on a CCGX. Higher power CPU devices can monitor more.
(4) Bluetooth functionality is intended to be used to assist with initial connection and networking configuration. You cannot use Bluetooth to connect to other Victron products (e.g. SmartSolar charge controllers).
19.2. Network Interfaces and Communication Services (RED 3.3d / EN 18031-1)
Network Interfaces
Interface | Purpose |
Ethernet | Internet connectivity
WiFi client | Internet connectivity
WiFi Access Point (AP) | Remote user interface (Remote Console) |
Bluetooth Low Energy peripheral | Setup network connectivity (Ethernet, Wifi client, Wifi AP) |
Service | Purpose |
HTTP webserver | Landing page to forward a user to the HTTPS login / Remote Console page |
HTTPS webserver | Login page and Remote Console |
MQTT via websockets | Data exchange between GX device and Remote Console |
DHCP (on WiFI AP) | Providing IP addresses to connected clients |
DNS (on WiFi AP) | Providing DNS functionality to connected clients |
SSDP / DNS-SD | Make the GX device automatically detectable on the network |
mDNS | Make the GX device reachable under the name venus.local |
19.3. Compliance
SIMPLIFIED EU DECLARATION OF CONFORMITY: Hereby, Victron Energy B.V. declares that the Nucleo GX is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: .
UK PSTI STATEMENT OF COMPLIANCE: We, Victron Energy B.V., confirm that our product Nucleo GX complies with the security requirements outlined in Schedule 1 of The Product Security and Telecommunications Infrastructure (Security Requirements for Relevant Connectable Products) Regulations 2023. The official Statement of Compliance can be downloaded from .
