7. Internet connectivity
Connect the Nucleo GX to the internet to access the full functionality of the VRM Portal. The NGX collects data from all connected products and sends it to the VRM Portal, where you can view the current status of connected products, configure email alarms and download data in CSV and Excel formats.
To monitor your system from a smartphone or tablet, download the VRM App for iOS or Android.
In addition to remote monitoring, an active internet connection allows the NGX to regularly check for firmware updates. Depending on your settings, updates can be downloaded and installed automatically.
Note: IPv6 is supported via automatic configuration. Manual IPv6 configuration is not available.
Internet connection options
You can connect the NGX to the internet using any of the following methods:
Ethernet: Connect a network cable between your router and the NGX Ethernet LAN port.
Built-in WiFi: Connect wirelessly to a router using the internal WiFi module.
Mobile network: Use a GX LTE 4G - a cellular USB modem, or connect through a mobile router.
USB tethering: Share a mobile phone’s internet connection via USB.
Watch this video for guidance on connecting via LAN, WiFi, or GX GSM (also applies to GX LTE 4G):
7.1. Ethernet LAN port
When you connect an ethernet cable between a router and NGX, the Settings → Connectivity → Ethernet page of your NGX will confirm connection. CautionBefore connecting the ethernet cable, be very careful not to confuse the GX device Ethernet port with the VE.Bus or VE.Can/BMS-Can ports! |
7.2. WiFi
Supported USB Wifi dongles
Part Number | Model | Remarks |
BPP900100200 | CCGX WiFi Module Simple (Nano USB) | Compact, low cost. |
BPP900200300 | Higher cost; better reception than Nano USB. Supported from software v2.23. | |
BPP900200400 | Highest cost; superior reception. Supports Wireless AC, G, and N (2.4 GHz and 5 GHz). |
Older, still supported dongles
BPP900200100 | ||
BPP900100100 | ||
BPP900200200 | Slightly higher cost; better reception. | |
BPP900200400 |
Although other WiFi dongles may work, they have not been tested and we do not offer support for other dongles.
WiFi network selection and behaviour
Note
WiFi is inherently less reliable than a wired Ethernet connection. Use Ethernet wherever possible for optimal stability. If using WiFi, ensure the signal strength is at least 50% to maintain reliable operation.
7.3. GX LTE 4G
The GX LTE 4G is a cellular modem for the Victron GX range of monitoring products. It provides both a mobile internet connection for the system and connectivity to the VRM Portal. The modem is compatible with 2G, 3G, and 4G networks.
For detailed installation and configuration instructions, refer to the GX LTE 4G Manual
Note
The GX LTE 4G provides an internet connection only for the GX device. It does not share its connection with laptops, phones, or other external devices.
7.4. Using a mobile router
When to use a mobile router
For installations where:
Multiple devices require internet access (e.g., yachts, RVs), or
A reliable failover/backup connection is needed,
we recommend installing a professional-grade mobile router.
A mobile router can:
Share the cellular internet connection with multiple devices via Ethernet or WiFi.
Switch automatically between cellular and WiFi connections if either link fails.
Connecting the NGX
To connect the NGX via a cellular network:
Install a mobile router
Connect the NGX to the router using either:
LAN (Ethernet) cable, or
The router’s WiFi network.
Important
Choose a router designed for unattended setups. Avoid low-cost consumer routers intended for temporary or personal use. Professional routers may be more expensive, but offer higher reliability and reduce the risk of downtime.
Example of suitable routers:
Compatibility notes
The NGX does not support mobile broadband USB dongles, except for the official GX GSM and GX LTE 4G accessories available from Victron.
7.5. Manual IP configuration
In most cases, manual IP configuration is not required, as most systems support automatic IP assignment via DHCP. This is also the default setting for the NGX. If manual IP configuration is necessary, select the appropriate template. For full details on IP requirements and port numbers used by the GX device, refer to the VRM FAQ - ports and connections used by the NGX. |
7.6. Multiple network connections (failover)
GX devices support concurrent connections to multiple network interfaces: Ethernet, WiFi, and LTE (via the GX LTE 4G accessory).
Interface priority for internet access
When more than one interface is available, the GX device will automatically prioritise them in the following order:
Ethernet; always preferred, regardless of WiFi or LTE availability
WiFi; used if Ethernet is unavailable, regardless of LTE availability
LTE; used only if both Ethernet and WiFi are unavailable
Internet access via Ethernet and WiFi
GX devices can be connected to both Ethernet and WiFi at the same time. Note that this setting does not apply to the LTE interface.
Each interface has an option to control whether it may be used for internet access, regardless of whether IP configuration is set to Automatic (DHCP) or Manual.
Enable the option on the interface that should provide internet access. If the option is disabled, the interface remains available for local network communication, but it will not be used for internet traffic. When this option is disabled, the Gateway field is hidden in the interface settings for that connection.
Technically, disabling the option removes the default gateway from that interface. Without a default route, the interface can only communicate within its local subnet and cannot access the internet.
If WiFi is your only active internet connection, disabling this option will disconnect the GX device from the internet and VRM. Before the setting takes effect, a warning dialog is shown asking you to confirm. If Ethernet is also connected and active, VRM connectivity will be maintained. If disabled unintentionally on a remote system without Ethernet, physical access may be required to restore internet connectivity. |
Important
Connection priority is based solely on network interface availability, not on whether the connection provides actual internet access. The device does not verify connectivity to the internet when selecting an interface.
7.7. Minimise internet traffic
In situations where internet traffic is costly, such as satellite connections or roaming GSM/cellular networks, you may wish to reduce the data usage.
Disable auto firmware updates.
Set VRM mode to read-only - see Access settings for Remote Console & Controls pane in VRM
Disable remote support (Settings → General → Access & Security → Remote support)
Reduce the VRM log interval (Settings → VRM→ Log interval) to the lowest acceptable frequency. Note: State changes (e.g., from charging to inverting, or from bulk to float) and alarms will still trigger additional data transmissions.
Estimating data usage
To estimate the required data allowance:
Let the system operate normally for several days.
Monitor the internet RX (received) and TX (transmitted) counters in your mobile router.
Alternatively, some mobile providers offer online tools to monitor data usage.
Factors affecting data consumption
Systems with more connected products generate more traffic.
Frequent state changes (e.g., inverter to charger transitions) increase the number of transmitted messages. This is particularly common in certain Hub-1 and Hub-2 systems.
Recommendations
Choose a data plan with a cap or pre-paid structure to avoid expensive excess charges.
Consider setting up automatic notifications for approaching data limits.
Advanced option: VPN traffic control
One customer, facing high international data costs, implemented a solution by routing all GX device traffic through a VPN. A firewall at the VPN server then controlled traffic based on time, connection type, location, and destination. Note that this method requires Linux and networking expertise and is beyond the scope of this manual.
7.8. More information on setting up an internet connection and VRM
For detailed instructions and further guidance, refer to:
