1. Knowledge Articles
  2. How to winterize an RV: electrics, cold-weather camping, and storage
RV
Chris Wallace-Tarry
Published 26 Nov 2026
Reading Time 17min
how-to-winterize-an-rv
RV winterization can mean two different things: winterization for use, and winterization for storage. If you’re winterizing your RV for storage, the most important thing is to ensure that water systems don’t freeze and that your batteries aren’t damaged by sitting idle in the cold. If you’re winterizing your RV for use, there’s more to consider; maintaining the whole interior comfortably above freezing and keeping power coming in are multi-system challenges. This article will cover how to winterize an RV, both for storage and for use. We’ll be talking about winter use first; skip ahead if you’re preparing your RV for winter storage.
winterized_rv_in_landscape
What does winterizing an RV involve?
Winterizing an RV for storage mainly means making sure water systems don’t freeze and rupture and protecting batteries from the cold. Water systems include the obvious, like tanks and plumbing for sinks and showers, but also the water inside pumps, water heaters, water filters, and the engine’s coolant system. Other important elements are:
  • Inflating tyres to an appropriate pressure to prevent sagging and flat spots over the long period of immobility
  • Inspection and maintenance of all exterior seals if storing outside
  • Emptying the fridge and propping the door open
  • Controlling for rats and mice
We’ll cover these in a later section. Winterizing an RV for use focuses on keeping the interior comfortably warm and keeping systems powered. Heating the interior is as much about heating systems as it is about insulation. Keeping the electrical system running requires a properly sized battery that’s either heated or can charge in the cold, combined with adequate charging. A key factor is that electricity use is much higher in winter, whilst solar power is more scarce. Backup power is more important in winter than the rest of the year. Other important elements are:
  • Ventilation without heat loss; interior moisture increases during winter
  • Installation of winter tyres
  • Regular maintenance of exterior seals
  • Clearing solar panels of snow
  • Equipping yourself for winter travel; shovel, traction boards, towing eye, and survival kit
  • Drying wet clothes and equipment
We’ll start by discussing how to winterize an RV for use through the cold months.
Essential electrical preparations for winter RV camping
Preparing your electrical system for winter involves processes discussed in detail in other articles: sizing your leisure batteries correctly, choosing the right battery chemistry for cold charging or else keeping your batteries warm, and sizing your solar system for your use and solar availability. Other important aspects include backup charging and monitoring.
Choose a battery chemistry that copes with the cold
As covered in our detailed guide to cold-weather battery storage, low temperatures affect battery chemistries differently. Lithium batteries only see a slight reduction in usable capacity in the cold, and can discharge without problems when well below freezing. A lithium battery, no matter its state of charge, can stay idle at freezing temperatures without issue; useful if the interior of your RV drops whilst you’re away from your van for a longer period. The downside is that lithium cannot be charged below about 0°C (32°F); the mandatory battery management system (BMS) blocks charging below this point, but the battery is not damaged. This means that the interior of your van must remain above freezing for charging to occur, or your batteries must be heated. Some lithium batteries, like the Lithium SuperPack NG, come with integrated heating that activates automatically to keep the battery at the right temperature for charging.
superpack ng - cold temperature performance
Lead-acid batteries can be charged below freezing as long as chargers apply appropriate temperature compensation.
Temperature sensing and compensation for battery charging
Most Victron chargers, including solar charge controllers, DC-DC chargers, battery chargers, and inverter/chargers, possess temperature sensors and modulate charging based on the temperature they detect. However, if your batteries are in a drastically different temperature environment, this temperature compensation won’t work correctly. In this case, real battery temperature must be monitored using a Smart Battery Sense, a BMV-712 or SmartShunt with a temperature sensor, a GX device, or a BMS. Note that the Orion-Tr Smart and Blue Smart IP65/IP67 chargers cannot receive an external battery temperature reading.
Lead-acid charging is much slower when the battery is cold. When discharging in the cold, lead-acid sees a significant reduction in usable capacity. Lead-acid batteries can also freeze and crack when discharged in cold temperatures.
In many cases, lithium is a good choice for winter use due to its near-unchanged usable capacity when cold and the fact that it can’t freeze. If your battery compartment is heated during periods where charging is important, you’ll have no issues. If not, consider a heated lithium battery like the Lithium SuperPack NG. Read more about the differences between lithium and lead-acid batteries in our dedicated guide.
Keep your batteries warm
The easiest way to keep your batteries warm and ensure optimal performance is to keep them within your RV’s heated envelope. Keep them off cold metal or otherwise uninsulated parts of the floor, not in an isolated, uninsulated garage or exterior bay. Heating pads may be useful; these can be bought in 12V or 24V and powered by the battery itself. A GX communications centre and relay can work in conjunction with a temperature sensor to automatically activate the pad when temperatures drop below a set level. More simple is a self-heating battery like the Lithium SuperPack NG.
Size your RV electrical system for winter
When sizing leisure batteries for a winterized RV, consider first the extra loads present in winter. High heater use, battery heating, longer lighting hours, longer induction hob hours, more ventilation, and more use of devices like computers, speakers, and projectors in the longer evenings all add up. Next, consider your off-grid independence and redundancy. A battery bank sized exactly to your one-day electricity usage is workable in summer when you can nearly guarantee solar charging all day, every day. In winter, heavier usage combines with shorter days and far fewer hours of direct sunlight. You’ll need to size your batteries to three or even four times your daily usage to ensure they don’t run down during periods of bad weather. Read much more about leisure battery sizing in our longform guide.
winterized_rv_solar_panels
Design your solar system for winter
Following on from the previous point, a properly-sized solar system must account for the low-angle sunlight, shorter days, and worse weather encountered in winter. Oversizing your solar system is a must; plan a solar array large enough to fully recharge your batteries in a few hours of full sun. This is where high-efficiency solar panels might provide a valuable edge; flexible panels are unlikely to cut it. Past a certain battery bank capacity, you may not have enough room on your roof for an adequately-sized solar array. In this case, a solar array that can tilt at an angle provides a significant boost.
Solar panel open circuit voltage in the cold
The open circuit voltage (Voc) of a solar panel rises in the cold, but headline Voc figures apply at 25°C. You’ll need to check the panel’s Voc at the coldest temperature it’s likely to encounter, and use this figure to size your solar charge controller.
A large solar array only works if it’s clear of snow. Snow clearing will become an important part of life if you’re RV camping somewhere with snowfall. A folding or collapsing ladder and soft broom are important pieces of equipment. Never scrape or chip ice from a solar panel, as this risks scratching or cracking the glass.
rv_with_tilting_solar_panels
Plan your backup charging for RV winter camping
Winterizing an RV involves building redundancies into your system, and backup power is more important than in summer. A complete charging system, including a DC-DC charger and shore power gives you multiple ways to charge if solar alone isn’t enough. Winter RV camping is where a generator is most attractive, as it can top up your batteries using easy-to-find petrol or diesel. Alternatively, a portable power station can act as a secondary, emergency leisure battery.
Monitor your system
An RV electrical system operating in winter is more delicate due to the higher strain, less optimal operating conditions, and elevated importance that everything stays online. This makes proper system monitoring even more important. As mentioned earlier, it’s essential that your chargers know the internal temperature of your battery; if the battery is located in a different environment from the chargers they should be provided with battery temperature sensing.
GX devices can be used in conjunction with Victron Remote Monitoring (VRM) to build a powerful, interconnected ecosystem where devices communicate with each other and with temperature sensors whilst sending telemetry to a programmable dashboard and increasing system efficiency. Alarms are useful to alert you to low battery charge and temperature, whilst Ruuvi tags can be used to measure cabin temperature and humidity. Read much more about building smart monitoring systems using VRM here.
victron-remote-management-vrm-body-1
RV camping in cold weather: Heating, water, and ventilation
Heating, water systems, and ventilation are also put under greater strain during winter camping in an RV. These systems all work together, in tandem with your electrical system; a warm, dry van means better electrical performance, and a healthy electrical system supports proper heating and ventilation.
Heating your RV during winter camping
RVs use fuel-burning heaters rather than electric ones due to the enormous energy consumption of electric heaters. Electrical heating is only appropriate when connected to shore power, and you need an inverter powerful enough to support it.
Fuel burning heaters come in two main types:
  • Diesel or petrol: a small amount of diesel or petrol, usually from the vehicle’s fuel tank, is used to heat air (and sometimes water). These are comparatively affordable, but installation is more complex due to the need for a fuel tap and exhaust. The exhaust can be noisy and fumes may disturb nearby campers.
  • Propane or LPG: propane or LPG kept in a pressurised tank is used in place of diesel or petrol. These are usually more expensive and the additional gas tank takes up space, but they don’t produce toxic exhaust meaning venting is much less important and installation is simpler.
These two heater types still require a 12V or 24V power supply, and they run for a long time every day; make sure you factor them in when sizing your RV batteries. Electricity-free, silent woodburning stoves are another option, but these require significant heat shielding and a correctly installed chimney. Their major upsides are the very dry heat they produce, which is perfect for drying wet clothes, and their completely silent operation.
rv_wood_stove
Proper insulation is an incredibly important part of winterizing a camper, as a well-insulated space can be kept warm using less energy. That means less fuel and less electricity consumed.
Carbon monoxide
All heating by the burning of fuel, be it diesel, petrol, LPG, or wood, can produce poisonous carbon monoxide. It’s vital that any RV with a fuel-burning heater be equipped with a carbon monoxide alarm.
RV plumbing in cold weather
Plumbing should be kept inside the heated and insulated envelope where possible. Any pipes or tanks that sit against exterior metal risk freezing solid when temperatures drop outside, even when the inside is warm. Pipes running to the exterior, like drain and inlet pipes, should be kept short and at a steep angle to ensure water doesn’t pool.
Exterior water tanks are more difficult in winter. 12V thermostat tank heating pads keep the water above freezing, but must be factored into your power budget. External plumbing itself needs either substantial insulation or its own powered heating. Remember that this applies to exterior wastewater tanks too.
If you want hot water, a combined air and water heater uses the same fuel to heat both your living space and your water. Alternatively, both tank-based and tankless water heaters are available, and generally run on propane/LPG. As with space heating, electric water heaters should only be used on shore hook-up due to their very high electricity usage.
Ventilation and condensation
Condensation is a significant issue when RV camping in winter. Doors and windows are closed, you cook more and heat more water, wet gear is dried, and you spend more time indoors, exhaling moisture into the air. All of this contributes to an increased vapour load. Moisture-laden air condenses on cold metal surfaces, causing rust, mould, and damp insulation. Moisture is bad news for electrics, as it corrodes contact points and increases resistance, and rust on your RV’s metalwork isn’t good either.
A warm van slows condensation, but it’s also important to evacuate moisture. A powered roof vent and a non-powered vent near the floor promote floor-to-ceiling airflow. Placing the two vents at opposite ends of the RV encourages air to fully circulate, sucking moist air outside. An additional powered vent above your cooking surfaces, and a dedicated powered extractor in the shower cubicle should also be considered. All of these fans should be factored into your electricity budget. Remember that networked humidity sensors can be incorporated into a GX-based monitoring system, allowing you to monitor your air quality in real time.
ventilating_an_rv_in_winter
How to winterize your RV electrics for cold storage
If you’ll be storing your RV over winter, pre-storage preparation takes priority. RV batteries need to be carefully prepared to prevent damage whilst sitting idle over cold winters. Self-discharge, a slow loss of charge at rest, and parasitic loads, small loads that stay on when a system is decommissioned, can together drain the battery over a long period of non-use. Deep discharge, and particularly a failure to quickly recharge a lead-acid battery which has become deeply discharged, permanently damages the battery. In addition, a discharged lead-acid battery can freeze and split in low temperatures, making it unusable.
Whether lithium or lead-acid, RV batteries should be fully charged before winter storage. Then, unless critical systems need to stay online, it’s best to disconnect and isolate the battery. This can be done easily using an isolation switch, or the built-in on/off switch on batteries like the Lithium SuperPack NG. If isolating your battery, turn off all elements of your electrical system first; chargers, inverters, fridge, heaters, fans, lights.
If aspects of your electrical system must stay connected to power, you’ll need to keep the battery topped up with solar power or a smart battery maintainer. A battery maintainer is also a good idea for flooded lead-acid batteries and gel or AGM batteries with a high-self discharge rate. Remember that unheated lithium batteries won’t charge in temperatures below freezing. If no mains power is available for a battery maintainer to use, it may be necessary to remove the battery and keep it at home. Read much more on the subject of what to do with RV batteries in winter in our in-depth guide.
blue_smart_charger_maintainer_tender_connected_to_rv_battery
Other important aspects of RV winterization for cold storage
Besides your electrical system, your water system and engine require some preparation before going dormant during winter RV storage.
How to winterize your RV water system for storage
The water system must be drained first to prevent water freezing and cracking pipes, valves, pumps, and tanks. Use the built-in drain valves to fully drain all tanks. Water heaters and showers should be drained the same way, and the heating element turned off. Water filter canisters and cartridges should also be removed and kept somewhere warm, as they contain delicate membranes and meshes. Pumps and pipes can be completely flushed using compressed air; pumps are particularly susceptible to damage by leftover water freezing. Some pumps incorporate a bypass valve and can be damaged by compressed air; check the manual to find out how to drain yours. When you’re ready, connect a blowout plug to the water inlet and connect an air compressor to the plug. The appropriate PSI for blowout will be stated by your RV’s manufacturer, but should be in the range of 20-40 PSI. The final step is to run a non-toxic antifreeze through the system. Antifreeze should be poured into sink plugholes and shower drains (with the drain valves of wastewater tanks closed). It should also be poured into the clean water tank and run through the system using the pump.
Other RV winterization steps
Tyres should be inflated to the specified running pressure plus 3-5 PSI to keep them firm and prevent flat spots from developing. Use the end of the season as an opportunity to check over all your exterior seals, as winter is the harshest time of the year and a damaged seal can leak a lot before spring arrives. Your fridge should be emptied and the door propped open; you may consider pest control measures to discourage rodents from moving in.
Final Thoughts
Whilst winter is a more challenging time for RV living, it should be time well spent. With the right preparation, you should feel prepared to go out and enjoy the world during this quieter period of the year. Besides the measures we’ve described, it’s a good idea to put together a kit for RV winter travel:
  • Shovel for clearing snow
  • Traction boards for getting out of snow
  • Towing eye/hook should the above prove insufficient
  • Long-handled broom and collapsible ladder for clearing solar panels of snow
  • Long ice scraper for clearing the windscreen
  • Emergency survival kit if travelling in remote areas where breakdown assistance may be days away
Besides these, consider your comfort. Extra blankets, a deep-pile rug, slippers all make your RV more cosy during cold nights. Use the below checklists to prepare your RV for winter, and reverse them when spring comes around again:
Winterizing your RV for storage
Water system
  • Drain all fresh and waste water tanks using their drain valves
  • Drain the water heater and shower
  • Remove water filter canisters and cartridges and store them somewhere warm
  • Check the pump manual for its draining method and any bypass valve
  • Blow out pipes with compressed air through a blowout plug, at your RV manufacturer’s PSI (typically 20–40 PSI
  • Close the waste tank drain valves and pour non-toxic antifreeze into sink plugholes and shower drains
  • Add non-toxic antifreeze to the clean water tank and run it through the system with the pump
  • Check the engine coolant has adequate antifreeze protection
Electrical system
  • Fully charge all RV batteries
  • Decide whether anything needs to stay powered over winter
  • If nothing does: switch off chargers, inverters, fridge, heaters, fans and lights, then isolate the battery with the isolation switch or the battery’s on/off switch
  • If something does: keep the battery topped up with solar or a smart battery maintainer
  • Fit a maintainer for flooded lead-acid, or for gel and AGM batteries with high self-discharge
  • If there’s no mains power for a maintainer, remove the battery and keep it at home
Vehicle and interior
  • Inflate tyres to running pressure plus 3–5 PSI
  • Inspect all exterior seals and repair any damage
  • Empty the fridge and prop the door open
  • Take steps to keep rats and mice out
Batteries and charging
  • Use lithium kept in a heated space, a self-heating lithium battery, or lead-acid with temperature-compensated charging
  • If the batteries are somewhere colder or warmer than the chargers, measure battery temperature directly with a Smart Battery Sense, a BMV-712 or SmartShunt with temperature sensor, a GX device, or a BMS
  • Keep batteries inside the heated envelope, off cold metal and uninsulated floor
  • Fit battery heating pads where needed
  • Size the battery bank to three or four times your daily winter use, including heater, battery heating, lighting, cooking, ventilation and devices
Solar
  • Size the array to fully recharge the batteries in a few hours of full sun
  • Choose high-efficiency rigid panels over flexible ones
  • Fit a tilting array if roof space is limited
  • Check the panels’ open-circuit voltage at the coldest expected temperature against the charge controller’s limit
  • Carry a folding ladder and soft broom for clearing snow, and never scrape or chip ice off panels
Backup charging and monitoring
  • Fit a DC-DC charger and a shore power connection
  • Consider a generator or a portable power station as backup
  • Consider GX and VRM alarms for low battery charge and battery temperature, and networked tags to monitor cabin temperature and humidity
Heating and insulation
  • Fit a diesel, petrol, or propane heater, or a wood-burner with proper heat shielding and chimney
  • Include the heater’s 12V or 24V draw in your power budget
  • Use electric heating only on shore power
  • Ensure sufficient insulation
Water system
  • Keep plumbing inside the heated envelope, away from exterior metal
  • Keep exterior inlet and drain pipes short and at a steep angle
  • Fit 12V thermostat heating pads to exterior fresh and waste water tanks
  • Insulate or heat any exterior plumbing
  • Heat water with a combined air and water heater or a propane water heater, and use electric water heating only on hook-up
Ventilation
  • Fit a powered roof vent and a non-powered low vent, at opposite ends of the RV
  • Consider powered extractors above the cooker and in the shower, and include all fans in your power budget
  • Consider adding humidity sensors to your GX monitoring
Vehicle and kit
  • Fit winter tyres
  • Check exterior seals regularly
  • Pack a shovel, traction boards, towing eye, long-handled snow broom and ladder, long ice scraper, and an emergency survival kit
  • Plan somewhere to dry wet clothes and gear
