Where to buy
Find a dealer near you
This all-new communication-centre allows you to always have perfect control over your system from wherever you are and maximises its performance. Simply connect through our Victron Remote Management (VRM) portal, or access directly, using the separate GX Touch, a MFD or our VictronConnect App thanks to its built-in WiFi Access Point. This latest addition to the GX-range combines all the best of connectivity, redefining smart power solutions in every way.
Watch the new video that explains all there is to know about installing the new Cerbo GX & GX Touch 50.
Powerful processor
VRM - Remote monitoring
Optional waterproof touchscreen
VictronConnect App
Simple mounting
Integrates with MFD's & NMEA 2000
Cerbo GX
Monitor & control
Monitor your system and gain full control from whereever you are with the Victron Remote Monitoring (VRM) portal and the VictronConnect app. Enjoy perfect control through the optional GX Touch display and your Marine Multi-functional display.
Works with
Compatibility
Experience the full power of Victron-connected products and an ever growing list of compatible third-party devices and integrations with this all-in-one communication centre.
Auto start/stop generator
Marine MFD’s
Resistive tank level & temperature inputs
Micro SD card slot for off-line data storage
Victron connected products
GX touch display
Solar irradiance & wind meters
Managed lithium batteries
Compatibility
1
2
3
4
5
6
7
8
1
2
Marine MFD’s
3
4
5
6
GX touch display
7
8
The Cerbo GX has a powerful dual core processor that manages all connected Victron products and a large range of supported third party devices with ease.
System monitoring just entered a new era, with the latest Venus OS. Now, keeping up with your electrical system is easier and more intuitive than ever. The sleek human-centred design and updated colour scheme helps you to stay focussed on the things that matter to you most.
For seamless integration with an ever growing list of leading third-party lithium battery manufacturers, a GX device is required. Great efforts are made to ensure a deep and hassle-free integration of supported batteries.
The Cerbo GX is designed to fit into any system setup and can also easily be mounted on a DIN-Rail. The optional touchscreen is top-mountable and requires just one cable, removing the cable clutter on your dashboard.
The optional GX Touch 50 and GX Touch 70 display accessories have a waterproof design. The supplied protection cover prevents damage from UV light during prolonged exposure to the sun.
Adjust configuration settings remotely with remote console, just like if you were standing in front of the device. The same functionality is also available on the local network LAN, or using the WiFi Access Point of the Cerbo GX.
Monitor the performance of your energy system with the powerful Venus OS. Configure the system completely to your every need, use simple controls to stay on top and let our algorithms do the rest.
The dashboard
Live power overview
Tank levels and environment
Completely in control
Safety net
Your entire system at a glance, with a clear overview of all vital data. Instantly check power input from the grid, wind and solar power harvest, battery levels, tank levels and power consumption.
Instantly monitor the battery state of charge, power consumption, wind and solar power harvest, generator, alternator and mains power. All in one clear overview.
Keep an eye on levels of fresh water, fuel, black water and any other tank liquid in your system, as well as environmental data like temperature and relative humidity. With customizable labels and critical level indicators, you’ll see instantly if any of them needs attention.
You are in control with the communication centre. Setting the input current limit or remotely switching your generator on or off is easy with quick controls.
With a set of fully customizable alerts and alarms we’ve created a safety net that will inform you of any issues and critical actions that may be required, helping you ensure your system is safe.
Your Cerbo GX will actively maximize the performance of your system. Acting as a communication hub it unifies readings and coordinates system-wide actions to optimize performance for all connected devices. The extremely powerful processor and the innovative Venus OS will ensure that your already efficient hardware reaches new levels of efficiency.
MFD integrations
Advanced automations
Effortlessly connect to the Victron Remote Monitoring (VRM) portal with your Cerbo GX. Operate your system from a distance with iOS and Android widgets, design custom data views to monitor crucial parameters, manage hundreds of systems at a time and create alerts to prevent serious issues from occurring.
Monitor and control your system right from your glass bridge with our MFD app or use the NMEA2000 marine industry standard integration options.
Take your system customization even further and create intelligent automation flows with Node-RED - the browser-based low-code editor that makes it ever so easy to wire together flows and automations. Easily connect hardware devices, APIs and online services together with PLC like programming.
The Cerbo GX serves endless purposes, extending perfect control to the most diverse applications.
Easily integrate with your MFD or go all the way thanks to Signal K and NMEA 2000 data sharing for smooth sailing. All right from your glass bridge.
Read moreOptimise for the many different grid tariffs and times with scheduled charging. Live more efficiently from the sun with improved peak shaving and using VRM’s solar forecasts for your location.
Read moreMinimise generator use by prioritising solar power. Auto start/stop generators at the most optimal conditions or add ‘quiet’ periods. Set the most optimal warm-up and cool-down times.
Read moreManage hundreds of systems remotely and keep a close eye on critical parameters with custom VRM widgets and push notifications. Design even more efficient automation flows with Node-Red and Venus OS Large.
Read moreOur modular ecosystem of robust and flexible building blocks is engineered for maximum performance with the greatest efficiency. All our products work seamlessly together and can be managed from anywhere in the world.
Works
with
Support
Warranty
©Victron Energy 2026
