Intersolar Europe 2026
Victron Energy: continual innovation, next-level power installations
Come and meet us on stand B4.150 on June 23rd, 24th and 25th at Intersolar 2026 – the world’s leading exhibition for the solar industry which takes place in Munich.
Ask questions and get hands-on with our reliable battery-based power system hardware: Inverters, Chargers, the world’s largest range of Solar Charge Controllers and Next Generation Lithium Batteries.
Plus, continual development of our world-leading software allows for system automation and the integration of third party devices which achieve extraordinary power installations with finger-tip control.
Across Marine, Mobile, RV, Industrial, Utility, in Remote Communities, and in the comfort of your home – we make the power which runs your work, rest and play.
Here are some of the highlights you’ll see on our stand:
Victron Native Microgrid
Arguably one of the most exciting innovations at the show is our latest Microgrid technology. Multiple independent Victron inverter/charger systems – which we call Power Banks – operate in parallel on a shared AC bus. Power Banks can be of mixed sizes, and together they form high-power off-grid systems which automatically share the load.
Each Power Bank is a complete installation in its own right, having its own inverter/chargers, batteries and monitoring. It’s incredibly simple, having no central controller, and no data communication wiring between units. Power Banks can be added or taken away on demand, and the system can be  scaled up to 400 kW.
There will be a live demonstration of how Victron native microgrid works, on stand. Test Victron Microgrid’s load sharing capabilities for yourself!
GX Opportunity Loads
Another new and exciting innovation allows you to utilise every photon of solar energy – even when your batteries are full and all power loads are being met.
Think of GX Opportunity Loads as an optimisation strategy. Whenever solar energy is going to waste – more is available than is currently being used – that potential can be harvested by sending it automatically toward devices or utilities – flexible assets – which you prioritise, such as: EV or e-bike charging; hot water storage; pool heating/treating etc.
The Opportunity Loads feature turns the GX device into a system-level coordinator – even running multiple loads in parallel when sufficient power is available.
GX Opportunity Loads activates Victron EV Charging Stations and Shelly switches connected to controllable devices.
SolarSense 750
SolarSense 750 is a standalone, self-powered, wireless irradiance monitor which provides real time data to your GX device. It allows you, and your Victron installation, to instantly see the full potential available from de-rated PV panels, activate Opportunity Loads; run a health check by comparing potential and real PV output; and to make informed decisions prior to panel installation.
New VM-3P5A Energy Meter – for larger systems
The successful VM-3P75CT, launched two years ago, now has a new sibling. While the VM-3P75CT works exclusively with the supplied current transformers (CTs) and can measure up to 75A per phase, the new VM-3P5A is designed for use with standard 5A CTs, the industry-standard current transformer type.
It supports applications measuring up to a theoretical 6,000A per phase, depending on the CTs used.
Like the existing model, the VM-3P5A connects via Ethernet or VE.Can and can be used to measure the output of a PV inverter, AC genset, as a grid meter in an ESS installation, or to measure AC loads.
Nucleo GX
We welcome a new member of the GX family – our communication centre devices that bring system monitoring, control, remote access, firmware updates and configuration together in one place, whether you’re on-site or managing a system from the other side of the world.
The Nucleo GX is a cost-effective addition to the GX range, designed for systems that do not require all the interfaces available on our higher-end GX devices. By omitting features such as VE.Bus connectivity, HDMI output for GX Touch displays, and tank and temperature sensor inputs, the Nucleo GX delivers the core GX functionality at a lower cost.
The Nucleo GX retains the monitoring, control and connectivity features that make GX devices the heart of a Victron Energy system, making it an ideal choice for ESS and off-grid systems built around the Multi RS.
What’s new with the Nucleo GX is that it excludes VE.Bus connections allowing cost savings whilst retaining all the usual benefits, and is suitable for systems which do not require VE.Bus communications. The Nucleo GX will typically be used in Multi RS systems for example.
Multi RS 48/6000
A lightweight, high-frequency inverter/charger suitable for both stationary and mobile applications. The Multi RS 48/6000 comes without MPPT solar trackers providing flexibility on solar configuration and for retrofitting in situations with existing solar inverters..
Switches to backup mode during a grid outage. Can operate without grid connection. Can control  generator to minimize run-hours and cover peak loads from the battery when demand exceeds the capacity of the generator. When the load reduces, the spare power is used to recharge the battery.
For stationary applications, it supports Dynamic ESS functionality while giving you the flexibility to pair it with a different type or size of solar inverter.
First arrivals of this device have now sold out, next shipment can be pre-ordered.
GlobalLink 530
We have a new member of the GlobalLink family which operates on the 4G cellular network offering much greater stability and worldwide coverage.
Multi HS19 Solar
Our new high voltage three-phase rack mountable 15kW Inverter Charger will be in stock this summer.
It has one AC input; two AC outputs. With four MPPT solar charge controllers on board, its operating range is between 650 and 1000V from a solar array offering up to 30kW. The MC4 solar connectors are at the back of the device allowing for a clutter free appearance when installed.
Power Sessions: Expert Tuition, Headphone Audience
Our super successful 20 – 30 minute technology updates return this year!
No booking required – just turn up and listen to our expert presenter, live, to learn more about our new Microgrid Technology every show day at 11:00 and 15:00; and about our own next-level Energy Storage Systems with exciting intelligent, programmable automations, each show day at 13:00.
Workshops – meet the professionals
If you’d like to laser focus on particular areas of Victron knowledge – like automations using Node-RED flows; integrating Shelly devices for smart control; a deep dive into our exciting Microgrid technology; or maximised efficiency using GX Opportunity Loads  – join us in our meeting room, away from the buzz of the exhibition floor, to get exactly the information you require.
Presentations are available in English and Deutsch. Reservations can be made through your Victron Professional account. If you don’t yet have a Victron Professional account you’re welcome to sign up for one.
The schedule and location follows:
We look forward to seeing you on our stand – B4.150
Intersolar takes place at: Messe München Messegelände 81823, Munich, Germany.
Intersolar 2026 Exhibition dates are –  June: Tuesday 23rd / Wednesday 24th / Thursday 25th
Avatar of justin
Previous
Community generates four times the energy it consumes
Next
Narrow boaters upgrade to lithium
Related blogs
