4. Phone, tablet and laptop compatibility
4.1. Windows PC
VictronConnect requires Windows 10 or later. For older Windows versions, XP and Vista, check our archive of previous VictronConnect versions. Keep in mind that previous software releases might not include all the capabilities found in the latest versions.
Note
Bluetooth support for Windows systems requires VictronConnect v6.40 or later.
USB Driver installation
Windows 10 ships with a compatible driver for both the VE.Direct USB cable and the MK3-USB cable: there is normally no need to install a driver for that. In case you do have issues connecting to a Victron product via USB, we recommend manually installing the VE.Direct USB driver. You can download it from our website on the Software downloads page.
For Windows 7 and Windows 8, we always recommend installing the USB driver.
These USB drivers can be installed with or without the USB cable connected to your computer. It will automatically install the files to be used once you connect the cable.
4.2. macOS
Today's version of VictronConnect runs on any Mac with Intel or Apple Silicon chip that runs macOS version from macOS 12 (Monterey) up to macOS 26 (Tahoe).
For older macOS versions, 11 / 10.11/10.10/10.9, an older version of VictronConnect is still available in the Apple Store. Do note that the older version is unsupported: if it works then great, that is why we provide that older version. If it does not work, then it's too bad, and we’ll not be able to help. The solution is then to get another laptop or device, that can work with the most recent version of VictronConnect.
To connect to a Victron product with Bluetooth, the Apple computer needs to have Bluetooth 4.0 (Bluetooth Low Energy or Bluetooth Smart).
4.3. Android
Android 9.0 is the minimum version required to run VictronConnect. For older Android versions, check our archive of previous versions.
Note
For devices with Android 12 or later, running VictronConnect v5.70 or later, it is not necessary to grant Access for Location Service. You are not asked for it when opening or installing the VictronConnect app. We recommend updating the mobile device to at least Android 12 whenever possible.
For older Android and/or VictronConnect versions, the following applies to Android Location Service.
An older version of VictronConnect that works for some Android 4.3 and 4.4 users is still available in the archive , but it is unsupported.
The required hardware is ARMv7 and later, as well as x86 or ARM64bit.
Notes for Android 5
Android 5 devices with a 64-bit CPU will experience a crash at startup due to an issue in the libraries we use to develop VictronConnect. This is not expected to be fixed. A workaround for this issue is manually installing the VictronConnect APK, which can be downloaded in the software section.
The pairing does not work on some phones running Android 5. The PIN code pop-up does not appear or appears without a text field to enter the PIN code. If you are in this situation, your phone might report that it has been paired with the Victron product, but it has not.
Unfortunately, we have no control over this bug in Android and are, therefore, unable to fix it.
Devices where we have seen this issue are:
Asus Zenfone 2 with 5.0 ← Android 6 is available; update the phone to solve the issue
Motorola Moto G 2 ← Android 6 is available; update the phone to solve the issue
Medion tablet with Android 5.0
Notes for Android 6 and later
There are no known issues when Access to Locations Services are enabled. See also the note at the beginning of the chapter.
Why is Access to Location Services required?
Android 5 and later requires access permission for VictronConnect to the (coarse) Location Services. Otherwise, it can not scan for the Bluetooth products.
In addition to permitting access to its data, the Location Services need to be enabled in many (but not all) cases.
Note that after enabling Location Services, the GPS itself can be switched off again: Android Location Services are more than GPS. Bluetooth and WiFi scan results can technically also be used to approximate the phone's location; hence, these requirements.
Despite the above, you can be sure that Victron is not interested in nor tracking your location.
Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it, unfortunately. More information about why it is needed to enable the Location Services is here.
List of known non-compatible Android devices
Manufacturer | Model | USB OTG | Bluetooth Smart |
HTC | One+ | ? | No |
HTC | One M7 | ? | No |
Huawei | P8 Lite (2015) | No | Only if Location Services are disabled |
Lenovo | Tab 3 A7 | ? | No |
Samsung | Galaxy S3 Mini | No | No |
Samsung | Galaxy S2 | Yes | No |
ZTE | Telstra Max | ? | No |
List of known compatible Android devices
We have tested the following Android devices and can confirm that they are compatible with VictronConnect*:
Google Nexus 6P; LG G4; Sony Xperia Z5; HTC One M9; HTC One S9; OnePlus 3T; Asus Zenfone 2; Samsung Galaxy S5; Samsung Galaxy S5 mini; Samsung Galaxy S7; Samsung Galaxy S8; Samsung Galaxy Tab E 9.6.
*Assumes the phone runs the latest firmware released by the manufacturer.
4.4. Apple iOS iPhones and iPads
VictronConnect works on the following iPhones and iPads running iOS 16 / iPadOS or higher:
iPhone 8 and later
iPhone SE from 2nd generation and later
iPad mini 5 and later
iPad 6 and later
iPad Air 3 and later
10,5" iPad Pro 1 and later
112,9" iPad Pro 2 and later
iPod Touch 7 and later
Unfortunately, Apple iPhone/iPad doesn't support USB OTG.
4.5. Linux
VictronConnect is available via Linux AppImage. It can be downloaded from here: VictronConnect Software Download
After downloading the AppImage file, you need to make it executable. Then the AppImage can be run as a program.
Ensure that the Bluetooth controller is activated, usually from the system menu.
If USB dongles are used, make sure that the user is a member of the dialout group.
Note
The AppImage for Linux is provided as-is, with no official support.
More details can be found here.
4.6. Archive of previous versions
Unfortunately, it is not possible to provide continued support for all operating system versions. A new release of VictronConnect may stop working with older operating system versions.
We always recommend updating your device to the latest operating system version that it supports. If your device still won't run the latest version of VictronConnect, then you may need to install an older version. See the table below for links to older versions of VictronConnect.
Warning
Please note that these older versions are not supported anymore. You should only use these older versions if you have no other choice.
The older versions of VictronConnect will very likely have missing features or functionality.
OS Version | Download link |
Windows 7 and Windows 8 | |
Windows XP and Windows Vista | |
Android 5, 6 and 7 armv7 architecture | |
Android 5, 6 and 7 x86 architecture | |
Android 4.3 to 4.4.4 armv7 architecture | |
Android 4.3 to 4.4.4 x86 architecture | |
macOS 10.9 (OS X Mavericks) | |
Last version for macOS Yosemite | |
Last version for macOS Sierra |
