VictronConnect app
14. Android widgets
In this section:
With an Android phone or tablet, create home screen widgets to see key info from your Victron Bluetooth Smart devices at a glance.
Note
The widgets described here are VictronConnect widgets, which are not the same as the VRM widgets.
14.1. Setup
Follow these steps to create a widget for your home screen:
  • Touch and hold an empty area of the home screen until the customization menu pops up.
  • Select "Widgets"
A list of apps will appear.
  • Choose "VictronConnect" from the list to expand the dropdown menu.
A list of available widget templates will be presented.
  • Touch and hold the widget template to drag into your desired position.
  • Release the widget one it's in position.
When you release the widget, you can select a device to display its data.
  • Choose a product from the list.
You can resize the widget by dragging its handles.
