MultiPlus system with 1 AC source
Setup is easy, simply connect the control panel to the VE.Bus system (refer to the Inverter/charger connection chapter), and it will automatically adapt to the system. No adjustments are required unless you want to restrict the operator's maximum AC current setting. For this refer to the Upper AC input limit 1 to 4 chapter.
