System examples pre-VE.Bus
Pre-VE.Bus system with 1 AC source:
The control panel must be scaled (matched to the system) when it is used with pre-VE.Bus systems. This can be done by changing the “scaling factor” parameter. For instructions, refer to the Scaling factor chapter.
Once the scaling is accurately configured, proceed to set up any other relevant parameters. For instructions, refer to the Configuration chapter.
Pre-VE.Bus system with 2 AC sources:
For a pre-VE.Bus system with 2 AC sources, an external transfer switch (VE Transfer Switch) is essential.
The control panel must be scaled (matched to the system) when it is used with pre-VE.Bus systems. This can be done by changing the “scaling factor” parameter. For instructions refer to the Scaling factor chapter.
Once the scaling factor is configured, follow the installation process similar to using a VE.Bus system with an external transfer switch. Refer to the MultiPlus system with 2 AC sources and transfer switch chapter for instructions.
