Lithium SuperPack NG manual
4. Installation
In this section:
4.1. Unpacking and Handling the Battery
Handle the battery with care during unpacking. Batteries are heavy; do not lift the battery by its terminals. Use the carry handles located on both sides. The weight is specified in the Battery Specification.
Before installation, familiarise yourself with the battery layout. The main terminals on the top are marked with “+” (positive) and “–” (negative) to ensure correct polarity.
4.2. Download and Install VictronConnect
Download the VictronConnect app for Android, iOS or macOS from their respective app stores. For more information about the app, see the VictronConnect product page.
4.3. Updating Battery Firmware
Updating the firmware via VictronConnect
The battery firmware can be updated via the VictronConnect app.
  • Ensure that the latest version of VictronConnect is installed, as this provides access to the most recent firmware.
  • A new battery is charged to a maximum of 30 % SoC. Fully charge the battery before performing a firmware update.
  • On first connection, the app may prompt to update the battery firmware. If prompted, allow the update to complete.
  • Before updating, refer to the firmware update chapter in the VictronConnect manual for detailed instructions.
Updating a battery bank
There is no combined update for a battery bank. Each battery must be updated individually in VictronConnect, one after the other. Update every battery of the bank in the same session, before returning the system to service.
General notes on firmware updates
  • Newer isn’t always better – only update if necessary.
  • If it works, don’t break it – avoid unnecessary updates.
  • Read the changelog first – available on Victron Professional.
Use this feature with care. Our main advice is not to update a running system unless problems occur or before the first startup.
Note
A firmware update can change the charge and discharge limits or other performance parameters of the battery. Such changes are made to keep the product within its intended safety and performance boundaries. Every firmware release is published together with a changelog that describes the changes and any modified behaviour.
Notes on updating the Lithium SuperPack NG battery firmware
  • The firmware update does not cause a full system shutdown.
  • During the update, the Charge disconnect output opens, preventing battery charging.
  • If the update fails, the Load disconnect output will open after 120 seconds as a safety measure, allowing time to retry the update.
  • During a firmware update, the Bluetooth and Error LEDs blink simultaneously, indicating that the update is in progress.
4.4. Mounting the Battery
WARNING
Hazard: Unsecured battery in a vehicle or vessel.
Consequence: During a collision, a sudden stop or a heavy sea state, an unsecured battery can become a projectile and cause serious injury or death.
Avoidance:
  • Mount the battery securely so that it cannot move.
  • In vehicles, use the supplied mounting brackets.
  • Use suitable handling and securing equipment when moving or transporting the battery.
Observe the following requirements when mounting the battery:
  1. The battery may be installed upright or on its long side.
    Do not install the battery upside down.
  2. The battery has an IP65 rating, providing protection against dust ingress and water jets. It can be installed in outdoor or semi-protected environments, but should not be exposed to direct sunlight, heavy rain, or other weather conditions.
  3. Use suitable handling equipment when moving the battery.
  4. Mount the battery securely to prevent movement. In vehicles, use the supplied mounting brackets.
  5. Allow at least 10 mm clearance on all sides to ensure adequate ventilation during charging and discharging.
4.5. Electrical Installation
Maximum terminal voltage
The SuperPack NG is designed to withstand a maximum absolute voltage difference of 60 V between its own terminals. The system must be designed so that no fault condition can cause this limit to be exceeded.
WARNING
Hazard: Voltage between the battery terminals above 60 V.
Consequence: The internal insulation degrades or fails. This can cause an internal fault, a cascade failure of the system and a fire.
Avoidance:
  • Do not connect the battery to any source that can apply more than 60 V across its terminals.
  • Design the system so that no single fault can raise the terminal voltage above this limit.
  • Where such a fault cannot be excluded by design, fit an overvoltage protection (OVP) device.
DC wiring
  • Use battery cables with a cross-sectional area suitable for the maximum expected current in the system.
  • Appropriately sized cables minimise voltage drop and heat generation. Keep cable lengths equal when connecting multiple batteries in parallel.
  • For most installations, the voltage drop should not exceed 2 % of the nominal system voltage.
  • The wire cross-sectional area for the EFS signal wire should be at least 0,75 mm2.
  • All DC wiring must comply with applicable system design guidelines and local electrical installation regulations.
Fusing
  • Batteries are capable of delivering very high currents; therefore, all electrical connections to the battery must be fused.
  • For the main battery terminal connection, use an MRBF-type or T-type fuse with an interrupt rating (IR) of at least 10 kA.
  • For the EFS signal wire, use a 315 mA fast-acting fuse, DC-rated ≥ 32 V (5×20 mm type).
  • Install all fuses as close as possible to the positive battery terminal. Ensure that the selected fuse ratings comply with the system design guidelines and local electrical regulations.
Terminal connections
  • Tighten the M8 terminal bolts to a torque of 14 Nm.
  • Use the following sequence:
    1. Bolt
    2. Spring washer
    3. Washer
    4. Cable lug
    5. Battery terminal
  • Ensure all contact surfaces are clean, flat and securely tightened.
WARNING
Hazard: Loose or high-resistance terminal connections.
Consequence: A loose connection creates a local hot spot. The resulting high temperature can damage the battery and ignite a fire.
Avoidance:
  • Tighten all terminal connections to the specified torque.
  • Inspect all connections during installation and again as part of regular maintenance.
Connection sequence
  1. Connect the positive (+) cable first.
  2. Connect the negative (-) cable last.
  3. When disconnecting, reverse the order.
  4. Connect the External Feedback Signal (EFS) - see External Feedback Signal (EFS) – Function and Wiring.External Feedback Signal (EFS) – Function and Wiring
NOTICE
This battery incorporates an internal negative switch. In OFF status or during a protection event, the negative terminal may be electronically disconnected.
4.5.1. Connecting multiple batteries in parallel
Batteries can be connected in parallel to increase capacity and autonomy. Power expansion is restricted by the maximum system current (refer to the Battery Specification). Power is increased by using multiple independent and redundantly protected battery packs, not by adding more batteries to a single pack.
WARNING
Hazard: System current above the interrupting capability of a single battery.
Consequence: In the event of a system overcurrent, the cascading protection sequence can leave the E-switch of the final battery to interrupt a fault current beyond its specified capability. The switch fails to open, which can lead to overheating, thermal runaway and fire.
Avoidance:
  • Ensure that the total system current drawn from a parallel battery pack never exceeds 800 A, the maximum current that a single SuperPack NG can safely interrupt.
  • Do not fit a main fuse for the battery pack rated above 800 A.
  • Increase power by using multiple independent and redundantly protected battery packs, not by adding further batteries to a single pack.
  • Connect the DC system cables diagonally to ensure equal current paths through each battery.
  • Ensure that the cross-sectional area of the main system cable is equal to the cross-sectional area of a single string cable multiplied by the number of parallel strings.
  • Fuse each battery on the positive side.
  • Fuse the positive main cable leading to the battery bank.
  • Connect the battery bank to the DC system.
  • For detailed wiring principles, calculations, and examples, refer to the Wiring Unlimited book.
SuperPack_NG_Parallel.svg
Fuse example
Two batteries are connected in parallel, each with a maximum continuous current of 100 A.
Each battery must be protected by an individual fuse rated slightly above 100 A, for example a 125 A Class T fuse (or MRBF type) with an interrupt rating of 20 kA. These fuses protect the cables and the battery in case of a fault in a single string.
The total system current is the sum of the individual battery currents. In this example, the maximum system current is 200 A. The main positive system cable and the main system fuse must therefore be rated for at least 200 A, for example a 250 A Class T fuse (or MRBF type) with an interrupt rating of 20 kA.
This ensures that each battery string is correctly protected while the main fuse protects the DC system against excessive total current.
4.6. External Feedback Signal (EFS) – Function and Wiring
The SuperPack NG battery features an M12 single-pole connector on the top panel that provides the External Feedback Signal (EFS).
The EFS connector can be associated with two functions:
  • External Disconnection Signal (EDS)
  • External Charging Signal (ECS)
Although both functions share the same physical EFS output, their signal behaviour and intended use are different.
General EFS characteristics
During normal operation, the EFS output is free-floating (0 V). When active, it outputs a battery-positive voltage (+Vbatt) referenced to battery negative and can supply up to 250 mA.
WARNING
Hazard: Inductive, capacitive or high-current loads connected directly to the EFS output.
Consequence: Voltage peaks and inrush currents can destroy the EFS output. Any protection function that relies on the signal, such as an external safety relay, is then lost without this being apparent.
Avoidance:
  • Do not connect the EFS output directly to inductive, capacitive, or high-current loads. When using inductive devices such as relays or buzzers without an internal driver circuit, always fit a flyback diode across the coil (cathode to Vbatt+).
  • Capacitive loads with large inrush currents should be avoided or suitably limited.
Always use the battery negative as the common reference for external devices connected to the EFS output. If multiple devices are connected, ensure that the total current remains within the output capability.
ECS can be enabled in the VictronConnect app. When active, the EFS output is continuously high at battery-positive voltage (+Vbatt).
ECS is triggered when the configured Low SoC warning threshold is reached. The signal remains active as long as the SoC is below the threshold or a charging current is detected. Whenever SoC is above the Low SoC threshold and no charging current is detected for more than 30 seconds, the ECS is deactivated.
Because ECS provides a steady ON/OFF signal for more than 30 seconds, it can be used directly to:
  • energise a relay coil,
  • drive a visual or audible alarm,
  • control devices with a remote on/off input such as a BatteryProtect, Solar Charger, or Orion XS.
EDS is always enabled and provides an additional layer of system protection. When current flow is detected while ATC (Allow To Charge) or ATD (Allow To Discharge) is inactive, the EFS output generates an alternating square-wave signal.
This condition can only occur in rare fault scenarios, such as a fail-short of electronic switching devices. The internal flags allow detection of such malfunctions and enables timely intervention.
EDS is a diagnostic signal and is not intended to directly drive relays, lamps, or buzzers. When using EDS, external logic or signal conditioning is required to detect the square-wave signal and convert it into a stable control or alarm output.
EFS functional wiring examples (ECS)
Indicator light (visible alarm)
An indicator light can be connected to provide a visible alarm during ECS operation. Connect the positive lead of the light to the EFS signal pin and the negative lead to the battery negative terminal. The light illuminates continuously while the ECS signal is active.
SuperPack_NG_ECS_Visible_Alarm.svg
Audible alarm
An audible alarm, such as a buzzer or speaker, can be connected in the same way. The alarm sounds continuously while the ECS signal is active.
SuperPack_NG_ECS_Audible_Alarm.svg
Relay-based control – alarm contact
A relay with NO/NC contacts can be driven directly by the ECS signal, as ECS provides a continuous battery-positive output. Connect the relay coil positive terminal to the EFS signal pin and the negative terminal to battery negative. When ECS is active, the relay energises and the contact can be used to switch an external alarm or signalling circuit.
SuperPack_NG_ECS_Alarm_Contact.svg
Direct control of a Victron product's remote on/off input
The ECS function can be used to control Victron products that provide a remote on/off input. It provides an automatic control signal that can be used to enable or disable external equipment based on the Low SoC threshold.
Connect the ECS output (EFS signal pin) to either the remote on/off L or H input of the device, depending on the required control behaviour for the application. Use the battery negative as the common reference (GND).
When ECS becomes active, the EFS signal goes high (+Vbatt). This activates or deactivates the device via the selected remote on/off L or H input, depending on the application. When ECS is cleared, the EFS signal returns to 0 V (free-floating) and the device reverts to its default state.
Refer to the product manual for the correct Remote on/off wiring and input requirements.
SuperPack_NG_ECS_Redundant_Switch.svg
Relay-based control of a charger's remote on/off input
A relay with NO/NC contacts can be driven directly by the ECS signal. Connect the relay coil positive terminal to the EFS signal pin and the negative terminal to battery negative. When ECS is active, the relay energises and the contact can be used to control a charger or other device with a remote on/off input.
SuperPack_NG_ECS_Redundant_Switch_2.svg
Battery bank solutions (ECS)
Parallel battery bank – ECS outputs connected in parallel
In systems with multiple Lithium SuperPack NG batteries connected in parallel, the EFS outputs of all batteries can also be connected in parallel. This ensures that when any battery triggers its EFS signal, the combined output activates, allowing connected devices or alarms to respond to a protection event from any unit in the system.
SuperPack_NG_ECS_Parallel.svg
Parallel battery bank – ECS relay contacts in series
In systems with multiple Lithium SuperPack NG batteries connected in parallel, each battery can use its ECS output to drive its own relay. The relay contacts are connected in series, forming a single control path to the external device (for example, the AUX input of a MultiPlus-II).
If any battery activates its ECS signal, its relay opens and interrupts the control circuit, ensuring that the system responds immediately to a protection or warning condition from any battery.
SuperPack_NG_ECS_Parallel_Feedthrough.svg
EFS functional wiring example (EDS)
The EDS output provides a square-wave diagnostic signal when an internal fault condition is detected while charging or discharging is not allowed. This signal must be connected to external logic capable of detecting the square wave and converting it into a stable alarm or shutdown signal. The EDS output must not be used to directly drive relays.
SuperPack_NG_EDS.svg
4.6.1. EFS inverter/charger integration
An inverter/charger such as the MultiPlus and Quattro that is powered from the AC input while the battery is disconnected can draw an overcurrent. This can trip the AC protection and prevent the battery from being charged again, leaving the system unable to recover on its own.
The battery protects itself against deep discharge and locks out. Before connecting the AC input to shore power, for example a shore power socket in a marina or a power socket on a campsite, verify that the battery is active and ready to be charged. For the lock-out condition and how to clear it, see Self-restoring protection mechanisms.
To prevent a deep discharge, the EFS output with the ECS function can be used to send a feedback signal to the inverter. On a MultiPlus-II, the AUX input can be configured for this purpose. Connect the EFS output through a separate relay so that the interface between the battery and the inverter is electrically isolated. Observe the maximum output current of the EFS channel of 250 mA.
The EDS function remains active on the same EFS output, because it is the native function of the channel. In the event of a BMS failure, the square-wave EDS signal is present on the same line as the ECS signal and can cause the inverter to disconnect intermittently. External logic is therefore required to distinguish the two signals.
Before using this arrangement, establish whether a sudden disconnection of the loads can create an undesired or critical condition in the application. See also the warning on automatic disconnection in Charge and Discharge Warnings.
ECS feedback to an inverter/charger
The ECS output drives the coil of a separate relay. The relay contact is wired to the AUX input of the inverter/charger, so that the control circuit is electrically isolated from the battery. Use the battery negative as the common reference for the relay coil.
