Lithium SuperPack NG manual
7. Technical Data
In this section:
7.1. Battery Specification
VOLTAGE & CAPACITY
SuperPack 12,8V/100 Ah NG
SuperPack 12,8 V /200 Ah NG
SuperPack 25,6 V /100 Ah NG
SuperPack 25,6 V /200 Ah NG
SuperPack 51,2 V /100 Ah NG
Part Number
BAT512110740
BAT512120740
BAT524110740
BAT5241207401)
BAT5481107401)
Nominal capacity @ 25 °C2)
12,8 V
25,6 V
51,2 V
Nominal energy @ 25°C2)
100 Ah
200 Ah
100 Ah
200 Ah
100 Ah
Nominal energy @ 25 °C
1280 Wh
2560 Wh
5120 Wh
Capacity loss / Energy loss
(per 100 cycles, @ 25 °C, 100 % DoD): <1 %
Round trip efficiency3)
93 %
CYCLE LIFE 25 °C (capacity ≥ 80 % of nominal)3)
Cycle life
2500 cycles @80 % DoD | 3000 cycles @70 % DoD | 5000 cycles @50 % DoD
DISCHARGING
Recommended discharge current (continuous use)
50 A
100 A
50 A
100 A
50 A
Max continuous discharge current8)
200 A
400 A
200 A
400 A
200 A
End of discharge voltage
11,2 V
22,4 V
44,8 V
Internal resistance
2 mΩ
1 mΩ
4 mΩ
2 mΩ
8 mΩ
CHARGING
Recommended charging voltage
14 V
28 V
56 V
Float voltage
13,5 V
27 V
54 V
Charging voltage range
[13,5 - 14,2] V
[27 - 28,4] V
[54V - 56,8] V
Recommended charging current
30 A
60 A
30 A
60 A
30 A
Max continuous charging current8)
100 A
200 A
100 A
200 A
100 A
FEATURES
Hardware connection /  System max current
Short circuit above 800 A
Software protections
Overvoltage, Undervoltage, Overtemperature, Undertemperature, Overcurrent
Wired communication
External Feedback Signal (EFS)
Bluetooth
Yes, VictronConnect App
GUI / Status indication
Push button (On/Off), BLE LED, Error LED
Self-heating max power
65 W
130 W
260 W
OPERATING CONDITIONS
Parallel configuration
Yes, unlimited energy expansion, with power expansion limited to the system’s maximum current
Series configuration
No
Operating temperature
Charge7) and Discharge: -30 °C to +60 °C
Humidity Operating Range (non condensing)
<90 % RH
Storage temperature
Recommended [10 - 35] °C
Expanded [-40 to +65] °C4)
Max storage time @ 25°C
1 year with at least initial remaining SoC >50 %
Protection class
IP65
MOUNTING
Power connection (threaded insert)
M8 female 20 mm including nut screws
Mounting options
Upright and on its long side, maintain flat horizontal support
Dimensions [LxWxH] (mm)5)
273 x 173 x 1736)
466 x 198 x 173
871 x 198 x 173
Weight (kg)
10,7
20,5
41
External Feedback Signal (EFS) Connector
External Feedback Signal connector for SuperPack NG (included) - Victron part number: SPR00310
STANDARDS
Safety
Cells: IEC62619 | UL1973 | UL 9540A
Battery: IEC62619 (pending)
EMC
EN 61000-6-3, EN 61000-6-2
Performance
IEC62620 (pending)
Transportation
UN 38.3
Automotive
ECE R10-7
ECE R10 pending
Notes
1) Product launch after Q1 2026
2) Discharge current ≤1C
3) 25 °C and 0.5C cycling
4) Performances might be reduced
5) Additional height of 15 mm for terminal screws
6) Compatible with BCI Group 49 dimensions
7) Below 0 °C, charging is suspended while the internal self-heating function warms the cells and automatically resumes once a safe charging temperature is reached.
8) At 25 °C ambient and 100% SoC, 2C can be sustained for approximately 10 minutes. The actual duration depends on temperature and voltage protection limits. Above this, overcurrent protection is triggered within 5 seconds.
7.2. Enclosure Dimensions
DIMENS_1.PDF
DIMENS_1_1.PDF
DIMENS_1_2.PDF
DIMENS_1_3.PDF
DIMENS_1_4.PDF
