4. Configuration and settings
4.1. Configuration of chargers and loads
Before turning on the system, ensure that chargers and loads are correctly configured, particularly their maximum combined charge and combined discharge currents, to avoid exceeding battery limits.
Maximum charge current
The maximum continuous charge current is 1C. The maximum pulse charging current depends on the battery model. Please refer to the Lithium NG battery datasheet for details.
Tip
For optimal battery performance, a charge current of 0.3C is recommended.
Maximum discharge current
The maximum continuous discharge current is 1C. The maximum pulse discharge current is 2C for a maximum of 10 seconds.
Tip
For optimal battery performance, a discharge current of 0.5C is recommended.
Important
Chargers and loads not controlled by the BMS (via ATC and ATD) can permanently damage the battery.
Maximum battery charge- and discharge currents for 12.8V Lithium NG batteries | ||||
12.8/100 | 12.8/150 | 12.8/200 | 12.8/300 | |
Max continuous discharge current | 100A | 150A | 200A | 300A |
Max pulse discharge current (10s) | 200A | 300A | 400A | 600A |
Max continuous charge current | 100A | 150A | 200A | 300A |
Max pulse charge current (10s) | 200A | 225A | 400A | 450A |
Maximum battery charge- and discharge currents for 25.6V and 51.2V Lithium NG batteries | ||||
25.6/100 | 25.6/200 | 25.6/300 | 51.2/100 | |
Max continuous discharge current | 100A | 200A | 300A | 100A |
Max pulse discharge current (10s) | 200A | 400A | 600A | 200A |
Max continuous charge current | 100A | 200A | 300A | 100A |
Max pulse charge current (10s) | 200A | 400A | 450A | 200A |
4.2. Power up for the first time
The VE.Bus BMS NG switches on when the following conditions are met:
Battery connection: The Bat+ of the 6-pin terminal block must be connected to Battery Plus.
VE.Bus inverter/charger connection: The RJ45 labelled MultiPlus/Quattro port must be connected to a VE.Bus inverter/charger or VE.Bus inverter. This connection is essential, as the BMS derives its battery negative through the VE.Bus link.
The VE.Bus BMS assistant no longer needs to be configured via VEConfigure. This is done automatically as soon as a connection between the VE.Bus device and the BMS is established.
4.3. VE.Bus BMS NG and Lithium NG battery settings
Once powered up, use the VictronConnect app to configure the BMS settings.
Some values such as battery capacity, voltage, and the number of batteries (in total, in series, and in parallel) are automatically detected and cannot be edited. However, they should still be verified for accuracy.
Battery monitor settings: Unlike other battery monitors, the VE.Bus BMS NG has mostly fixed parameters. This is because it is designed specifically for use with Victron Lithium NG batteries, where key settings are predefined.
4.4. Update BMS and Battery firmware
Updating the VE.Bus BMS NG firmware can be carried via the VictronConnect app.
General notes on firmware updates
Newer isn’t always better – only update if necessary.
If it works, don’t break it – avoid unnecessary updates.
Read the changelog first – available on Victron Professional.
Use this feature with care. Our main advice is not to update a running system unless problems occur or before the first startup.
Notes on updating the VE.Bus BMS NG and Lithium NG battery firmware
The firmware update does not cause a full system shutdown.
During the update, the Charge disconnect output opens, preventing battery charging.
If the update fails, the Load disconnect output will open after 120 seconds as a safety measure, allowing time to retry the update.
Updating the firmware
For detailed instructions, refer to the firmware update chapter in the VictronConnect manual.
If a newer firmware version is available, VictronConnect (ensure you are using the latest app version) will notify you automatically once a connection with the VE.Bus BMS NG is established.
Which firmware version do I have?
The firmware version is visible on the VictronConnect Product info page of the BMS. |
4.5. Bluetooth reactivation
If Bluetooth has been deactivated for the BMS in VictronConnect, for example for security reasons, it can be reactivated as follows:
