7. Technical specifications VE.Bus BMS NG
Electrical | |
Input voltage range | 9 – 70 Vdc |
Current draw - regular operation | 10 mA (excluding Load disconnect current) |
Current draw - low cell voltage | 2 mA |
Current draw - switched off via remote on/off terminal | 1,50 mA |
GX-pow output | 1 A |
Aux-in input | 1 A |
Pre-alarm output current rating | 1 A, not short circuit protected |
Load disconnect output | Normally high (output voltage ≈ supply voltage – 1 V) Floating when the load needs to be disconnected Source current limit: 1 A Sink current: 0 A |
Charge disconnect output | Normally high, (output voltage ≈ supply voltage – 1 V) Floating when charger should be disconnected Source current limit: 10 mA Sink current: 0 A |
Remote on/off terminals | Usage modes to turn the system on or off:
VE.Bus communications ports | 2 x RJ45 sockets to connect to all VE.Bus products |
General | |
Operating temperature | -20 to +50 °C (0 - 120 °F) |
Humidity | Max. 95 % (non-condensing) |
Protection grade | IP20 |
Enclosure | |
Material | ABS |
Colour | Matt black with a blue sticker |
Weight | 120 gr |
Dimension (h x w x d) | 23,8 mm x 94,5 mm x 105,5 mm |
Standards | |
Safety | EN 60950 |
Emission | EN 61000-6-3, EN 55014-1 |
Immunity | EN 61000-6-2, EN 61000-6-1, EN 55014-2 |
Automotive | EN 50498 |
External AC-DC adapter (if installed) | |
Min. power rating | 1 A @ 12 V - If the nominal output voltage is > battery voltage, the AC-DC adapter takes over the power supply of the GX device. |
