9. Technical specifications
Specification | 12/30 (1+1) & (3) | 12/50 (1+1) & (3) | 24/16 (1+1) & (3) | 24/25 (1+1) & (3) | 36/15 (1) | 48/13 (1) | |
Nominal input voltage - AC supply | 120 – 240VAC | ||||||
Input voltage range – AC supply | 85 – 250VAC (full power from 100VAC, startup from 90VAC) | ||||||
Input frequency - AC supply | 45 - 65Hz | ||||||
Input voltage - DC supply | 90 - 375 VDC | ||||||
Power factor | >0.99 | ||||||
Max Efficiency - 230VAC / 120VAC | 95 / 93% | 94 / 92% | 96 / 94% | 96 / 94% | 96 / 94% | 96 / 94% | |
Charge voltages - Normal mode | Absorption | 14.4V | 28.8V | 43.2V | 57.6V | ||
Float | 13.8V | 27.6V | 41.4V | 55.2V | |||
Storage | 13.2V | 26.4V | 39.6V | 52.8V | |||
Charge voltages - High mode | Absorption | 14.7V | 29.4V | 44.1V | 58.8V | ||
Charge voltages - Lithium mode | Absorption | 14.2V | 28.4V | 42.6V | 56.8V | ||
Float | N/A | N/A | N/A | N/A | |||
Storage | 13.5V | 27V | 40.5V | 54V | |||
Temperature compensation (N/A for Li-ion) | -16mV/°C | -32mV/°C | -48mV/°C | -64mV/°C | |||
Charge algorithm | 6-stage adaptive (3 stage for Li-ion) | ||||||
Max output current - Normal mode | 30A | 50A | 16A | 25A | 15A | 13A | |
Max output current - Low current mode | 15A | 25A | 8A | 12.5A | 7.5A | 6.5A | |
Max output current - Starter battery | 4A (1+1 output models only) | ||||||
Back drain current | <1mA | ||||||
Max battery capacity (recommended) | 300Ah | 500Ah | 160Ah | 250Ah | 150Ah | 130Ah | |
Min battery capacity - Normal mode | Lead: 120Ah Li-ion: 60Ah | Lead: 200Ah Li-ion: 100Ah | Lead: 64Ah Li-ion: 32Ah | Lead: 100Ah Li-ion: 50Ah | Lead: 60Ah Li-ion: 30Ah | Lead: 50Ah Li-ion: 25Ah | |
Min battery capacity - Low current mode | Lead: 60Ah Li-ion: 30Ah | Lead: 100Ah Li-ion: 50Ah | Lead: 32Ah Li-ion: 16Ah | Lead: 50Ah Li-ion: 25Ah | Lead: 30Ah Li-ion: 15Ah | Lead: 25Ah Li-ion: 12Ah | |
Data communication | VE.Direct and Bluetooth (via VictronConnect app) | ||||||
Bluetooth power and frequency | +4dBm | 2402 - 2480MHz | ||||||
Remote on/off | Yes (2 pole terminal) | ||||||
Programmable relay | Yes (SPDT - 5A up to 250VAC / 5A up to 28VDC) | ||||||
Operating temperature | -20 to +60°C (0 - 140°F) Full rated output up to 40°C | ||||||
Max humidity | 95% | ||||||
Enclosure | |||||||
Material and colour | Aluminium | Blue RAL 5012 | ||||||
AC connection | IEC 320 C14 inlet with retainer clip (AC cord ordered separately) | ||||||
Battery connection | Screw terminals 16 mm² (AWG6) | ||||||
Number of battery connections | (1) models: 1 | (1+1) models: 2 (2nd output via 2 pole terminal) | (3) models: 3 | ||||||
Protection category | IP43 | ||||||
Weight | 2.7 kg (6.0 lbs) | ||||||
Dimensions (h x w x d) | 180 x 249 x 116mm (7.1 x 9.8 x 4.6 inch) | ||||||
Compliance standards | |||||||
Safety | EN 60335-1, EN 60335-2-29 | ||||||
Emission | EN 55014-1, EN 61000-6-3, EN 61000-3-2 | ||||||
Immunity | EN 55014-2, EN 61000-6-1, EN 61000-6-2, EN 61000-3-3 | ||||||
