Quattro (with firmware xxxx400 or higher) Australia
10. Technical specifications
In this section:
Quattro
12/5000/220-100/100
24/5000/120-100/100
48/5000/70-100/100
24/8000/200-100/100
48/8000/110-100/100
48/10000/140-100/100
48/15000/200-100/100
Nominal battery voltage
12/5000: 12V Battery
24/5000: 24V Battery
48/5000: 48V Battery
24/8000: 24V Battery
48/8000: 48V Battery
48V Battery
PowerControl / PowerAssist
Yes
Integrated Transfer switch
Yes
AC input (x2)
Input voltage range: 187 - 265VAC
Input frequency: 45 - 65Hz
Cos Φ >0.8
Maximum feed-through current (A)
2x100
2x100
2x100
2x100
ICw
10 kA
I short circuit
2,2kA Peak, 1.6kA rms
INVERTER
Input voltage range (VDC)
9.5 -17 V
19 - 33 V
38 - 60 V
19 – 33 V
38 – 60 V
38 – 60 V
38 – 60 V
Output in inverter mode (1)
Output voltage: 230VAC ± 2%
Frequency:  50Hz ± 0.1%
Cont. output power at 25°C (VA) (3)
5000
8000
10000
15000
Cont. output power at 25°C (W)
4000W
6400
8000
12000
Cont. output power at 40°C (W)
3700W
5500
6500
10000
Cont. output power at 65°C (W)
3000W
3600
4500
7000
Peak power (W)
10000
16000
20000
25000
Input current (ADC)
458
238
118
381
188
235
350
Max. continous output current (A)
19
30
37
53/50
Power factor range
±0.8
±0.8
±0.8
±0.8
Maximum output fault current
53A 1sec.
100A 1sec.
100A 1sec.
150A 1sec.
Maximum efficiency (%)
94
94
95
94
96
96
96
Zero-load power (W)
30
30
35
45
50
55
80
Zero-load power in AES mode
20
25
30
30
30
35
50
Zero-load power in Search mode
10
10
15
10
20
20
30
CHARGER
Charge voltage "absorption" (VDC)
14.4
28.8
57.6
28.8
57.6
57.6
57.6
Charge voltage "float" (VDC)
13.8
27.6
55.2
27.6
55.2
55.2
55.2
Storage mode (VDC)
13.2
26.4
52.8
26.4
52.8
52.8
52.8
Charge current house battery (A) (4)
220
120
70
200
110
140
200
Charge current starter battery (A)
4 (12V and 24V models only)
Battery temperature sensor
Not included with 48V models. Order number: ASS000001000
Compatible battery chemistries
Only Lead Acid and LiFePO4 rechargeable batteries
GENERAL
Auxiliary output (A) (5)
 50
50
50
50
Programmable relay (6)
3x
3x
3x
3x
Protection (2)
a - g
VE.Bus communication port
For parallel and three-phase operation. Connect to a GX device for BMS, remote monitoring and system integration.
General purpose com. port
2x
2x
2x
2x
Remote on-off
Yes
Common Characteristics
Operating temp.: -20 to +60°C (-4 – 140°F)
(fan-assisted cooling)
Humidity (non-condensing): max 95%
Maximum Altitude
2000m
Country of manufacture
India
ENCLOSURE
Material & Colour: Aluminium, (blue RAL 5012)
Protection category: IP20
Pollution degree: 2
Overvoltage category: OVCIII
Battery connection
Four M8 bolts (2 plus and 2 minus connections)
230  VAC connection
Bolts M6
Bolts M6
Bolts M6
Bolts M6
Weight (kg)
34
30
30
45
41
45
72
Dimensions (hxwxd in mm)
470 x 350 x 280
444 x 328 x 240
444 x 328 x 240
470 x 350 x 280
470 x 350 x 280
572 x 488 x 344
STANDARDS
Safety
EN-IEC 60335-1, EN-IEC 60335-2-29, EN-IEC 62109-1
Emission, Immunity
EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3, EN-IEC 61000-6-3, EN-IEC 61000-6-2, EN-IEC 61000-6-1
Vehicles, aftermarket
12 V and 24 V models: EN 50498
Anti-islanding
See our website.
1) Can be adjusted to 60 HZ; 120 V 60 Hz on request.
2) Protection key:
a) output short circuit
b) overload
c) battery voltage too high
d) battery voltage too low
e) temperature too high
f) 230 VAC on inverter output
g) input voltage ripple too high
3) Non-linear load, crest factor 3:1
4) At 25 ˚C ambient
5) Switches off when no external AC source available
6) Programmable relay that can a.o. be set for general alarm:
- DC under voltage or genset start/stop function
- AC rating: 230 V / 4 A
- DC rating: 4 A up to 35 VDC, 1 A up to 60 VDC
