Technical specifications Inverter VE.Direct 120V
Inverter VE.Direct 120V | 12/250 24/250 48/250 | 12/375 24/375 48/375 | 12/500 24/500 48/500 | 12/800 24/800 48/800 | 12/1200 24/1200 48/1200 | 12/1600 24/1600 48/1600 |
Continuous power at 25°C | 250W | 375W | 500W | 800W | 1200W | 1500W |
Continuous power at 40°C | 200W | 300W | 438W | 650W | 1100W | 1350W |
Time-limited power (cold start) | 300W/15s | 450W/25s | 500W/1h | 900W/1h | 1300W/1h | 1700W/1h |
Peak power | 400W/2s | 600W/2s | 750W/2s | 1200W/15s | 1600W/15s | 2100W/15s |
Output AC voltage | 120Vac +/- 3% | |||||
Output AC frequency (adjustable) | 60Hz +/- 0.1% | |||||
Input DC voltage range | 9.2 - 17V 18.4 - 34.0V 36.8 - 62.0V | |||||
Low battery shutdown DC voltage (adjustable) | 9.3V 18.6V 37.2V | |||||
Dynamic (load dependent) DC low shut down (fully configurable) | Yes, see the Dynamic cut off chapter. | |||||
Low battery restart & alarm DC voltage (adjustable) | 10.9V 21.8V 43.6V | |||||
Battery charged detect DC voltage (adjustable) | 14.0V 28.0V 56.0V | |||||
Maximum efficiency | 84% 85% 85% | 87% 88% 88% | 88% 89% 89% | 90% 90% 91% | 91% 91% 92% | 92% 92% 93% |
Zero-load power | 5W 6W 8W | 6W 7W 8W | 7W 8W 10W | 8W 8W 9W | 11W 11W 12W | 14W 14W 15W |
Default zero-load power in ECO mode (default search interval: 2.5s, adjustable) | 1W 1W 2W | 1W 1W 2W | 1W 1W 2W | 1W 1W 2W | 1W 2W 3W | 2W 2W 3W |
ECO mode stop and start power setting | Adjustable | |||||
Protection (1) | a – g | |||||
Operating temperature range | -40 to +60°C (fan-assisted cooling) | |||||
Power derating | 1.25% per °C above 40°C | |||||
Maximum humidity | max 95% (non-condensing) | |||||
ENCLOSURE | ||||||
Material | Steel chassis and plastic cover | |||||
Colour | Blue, RAL 5012 | |||||
Battery connection terminals | Screw terminals | |||||
Maximum battery cable cross-section in mm² | 10 mm² 10 mm² 10 mm² | 10 mm² 10 mm² 10 mm² | 10 mm² 10 mm² 10 mm² | 25 mm² 10 mm² 10 mm² | 35 mm² 25 mm² 25 mm² | 50 mm² 35 mm² 25 mm² |
Maximum battery cable cross-section in AWG | AWG 8 AWG 8 AWG 8 | AWG 8 AWG 8 AWG 8 | AWG 8 AWG 8 AWG 8 | AWG 4 AWG 8 AWG 8 | AWG 2 AWG 4 AWG 4 | AWG 1 AWG 2 AWG 4 |
AC outlet type | NEMA 5-15R | |||||
Protection category | IP 21 | |||||
Weight in kg | 2.7kg | 3.0kg | 3.5kg | 5.1kg | 6.9kg | 7.9kg |
Weight in lbs | 5.9lbs | 6.6lbs | 7.7lbs | 11.2lbs | 15.2lbs | 17.4lbs |
Dimensions (hxwxd, mm) | 86x165x260 | 86x165x260 | 86x172x275 | 105x216x305 | 117x231x374 | 117x231x395 |
Dimensions (hxwxd, inch) | 3.4x6.5x10.2 | 3.4x6.5x10.2 | 3.4x6.5x10.8 | 4.1x8.5x12 | 4.6x9.1x14.7 | 4.6x9.1x15.6 |
ACCESSORIES | ||||||
Remote on/off terminal | Yes | |||||
Automatic AC transfer switch | Not built-in. Add a Filax2 transfer switch, or use an inverter/charger instead. | |||||
STANDARDS | ||||||
Safety | EN/IEC 60335-1, EN/IEC 62109-1 | |||||
EMC | EN 55014-1, EN 55014-2, IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | |||||
