Inverter VE.Direct 120V Manual
6. Technical specifications
In this section:
6.1. Technical specifications Inverter VE.Direct 120V
12/250
24/250
48/250
12/375
24/375
48/375
12/500
24/500
48/500
12/800
24/800
48/800
12/1200
24/1200
48/1200
12/1600
24/1600
48/1600
Continuous power at 77°F (25°C)
250W
375W
460W
800W
1200W
1500W
Continuous power at 104°F (40°C)
200W
300W
380W
650W
1100W
1350W
Time-limited power (cold start)
300W/15s
450W/10s
500W/1h
900W/1h
1300W/1h
1700W/1h
Peak power
400W/2s
600W/2s
750W/3s
1200W/15s
1600W/15s
2100W/15s
Output AC voltage
120Vac +/- 3%
Output AC frequency (adjustable)
60Hz +/- 0.1%
Input DC voltage range
9.2 - 17V
18.4 - 34.0V
36.8 - 62.0V
Low battery shutdown DC voltage (adjustable)
9.3V
18.6V
37.2V
Dynamic (load dependent) DC low shut down (fully configurable)
Yes, see the Dynamic cut off chapter.
Low battery restart & alarm DC voltage (adjustable)
10.9V
21.8V
43.6V
Battery charged detect DC voltage (adjustable)
14.0V
28.0V
56.0V
Maximum efficiency
84%
86%
86%
86%
88%
88%
86%
88%
88%
90%
90%
91%
91%
91%
92%
91%
91%
92%
Zero-load power
5W
6W
8W
6W
7W
9W
7W
8W
10W
8W
8W
9W
11W
11W
12W
14W
14W
15W
Default zero-load power in ECO mode
(default search interval: 2.5s, adjustable)
1W
1W
2W
1W
1W
2W
1W
1W
2W
1W
2W
2W
1W
2W
3W
1W
2W
3W
ECO mode stop and start power setting
Adjustable
Protection (1)
a – g
Operating temperature range
-40 to 149°F (-40 to +65°C) (fan-assisted cooling)
Power derating
1.25% per °F above 104°F (40°C)
Maximum humidity
max 95% (non-condensing)
ENCLOSURE
Material
Steel chassis and plastic cover
Colour
Blue, RAL 5012
Battery connection terminals
Screw terminals
Maximum battery cable cross-section in mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
25 mm²
16 mm²
16 mm²
35 mm²
25 mm²
25 mm²
50 mm²
25 mm²
25 mm²
Maximum battery cable cross-section in AWG
AWG 8
AWG 8
AWG 8
AWG 8
AWG 8
AWG 8
AWG 8
AWG 8
AWG 8
AWG 4
AWG 6
AWG 6
AWG 2
AWG 4
AWG 4
AWG 1
AWG 4
AWG 4
AC outlet type
NEMA 5-15R or GFCI
Protection category
IP 21
Weight in lbs
6lbs
6.6lbs
7.7lbs
11lbs
15lbs
18lbs
Weight in kg
2.7kg
3.0kg
3.5kg
5.1kg
7kg
8kg
Dimensions (hxwxd, mm)
86x165x260
86x165x260
86x165x260
86x165x260
86x165x260
86x165x260
86x172x275
86x172x275
86x172x275
95x231x334
105x216x310
105x216x310
117x231x374
117x231x333
117x231x333
117x231x395
117x231x365
117x231x365
Dimensions (hxwxd, inch)
3.4x6.5x10.2
3.4x6.5x10.2
3.4x6.5x10.2
3.4x6.5x10.2
3.4x6.5x10.2
3.4x6.5x10.2
3.4x6.8x10.8
3.4x6.8x10.8
3.4x6.8x10.8
3.7x9.1x13.0
4.1x8.5x12.2
4.1x8.5x12.2
4.6x9.1x14.7
4.6x9.1x13.1
4.6x9.1x13.1
4.6x9.1x15.6
4.6x9.1x14.4
4.6x9.1x14.4
ACCESSORIES
Remote on/off terminal
Yes
Automatic AC transfer switch
Not built-in. Add a Filax2 transfer switch, or use an inverter/charger instead.
STANDARDS
Safety
EN/IEC 60335-1, EN/IEC 62109-1
EMC
EN 55014-1, EN 55014-2, IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3
  1. Protection key:
    1. Output short circuit
    2. Overload
    3. Battery voltage too high
    4. Battery voltage too low
    5. Temperature too high
    6. 120VAC on inverter output
    7. DC ripple too high
