1. Knowledge Articles
  2. How do lead-acid batteries work?
The chemistry behind charging, discharging, and diffusion
Justin Tyers
02 Sept 2026
Lead-acid (AGM) battery pack
The battery is a secretive product. From the outside there is nothing to tell us about its quality, possible ageing or state-of-charge. A battery, when it fails, has to be replaced. That’s it.
Also, batteries are very vulnerable. Overcharging, undercharging, discharging too deeply, charging too fast, excessive temperature…. All these issues can occur and the consequences can be disastrous.
What does the process in a lead-acid battery look like?
A lead-acid battery stores and releases energy through a chemical reaction between two lead-based plates submerged in a mixture of sulphuric acid and water. When discharging, the chemical reaction between the plates and the acid produces electricity. When a battery is recharged, that process runs in reverse - pushing electrical energy back in which restores the chemicals to their original state so the whole cycle can happen again.
A section of a lead-acid battery to explain its construction and operation
What happens in a cell as it discharges?
As a cell discharges lead sulphate forms on both the positive and negative plates through absorption of acid from the electrolyte. This difference in chemical potential between the two plates creates a voltage - essentially an "electron pressure" - that drives electrons through the external circuit (your device), producing usable electrical current. The quantity of electrolyte in the cells remains unchanged. However, the acid content in the electrolyte reduces - a change which can be measured in the specific gravity of the electrolyte.
What happens during charging?
An external voltage source - a battery charger or alternator - forces current through the battery in the opposite direction, reversing the discharge reactions. On both plates acid is released, while the positive plate converts into lead oxide and the negative plate into porous, sponge-like lead. Once charged, the battery can no longer take up energy and any further energy will decompose water into hydrogen gas and oxygen gas. A battery charger tapers the charge current toward the end of the charge cycle as overcharging will deplete the electrolyte and pose a safety risk due to flammable hydrogen gas buildup.Short description with image
  1. An external voltage forces electrons in the opposite direction, reversing both electrode reactions.
  2. PbSO₄ is converted back to Pb (negative) and PbO₂ (positive).
  3. H₂SO₄ is regenerated, restoring electrolyte density — the battery is fully charged.
Drawings of discharge and charge process of a lead-acid battery
Fluid Consistency and Specific Gravity
Behind the scenes of this chemical cycle lies a shifting physical state: the literal weakening and strengthening of the battery fluid. As the cell discharges and the plates absorb the acid, the remaining liquid becomes mostly light, plain water, causing its density, measured as specific gravity, to drop significantly. Conversely, charging forces the dense sulfuric acid back into the liquid, regenerating its weight and thickness until a fully charged state is restored.
Because you cannot see this transformation from the outside, a tool called a hydrometer is used to gauge this fluid consistency. Measuring specific gravity acts like a direct window into the chemical heart of a flooded cell, offering a precise, unhackable readout of the battery's true state of charge and internal health that simple voltage meters can easily miss.
Diffusion process
When a battery is being discharged, ions have to move through the electrolyte and through the active material of the plates to come into contact with the lead and lead oxide that has not yet been chemically converted into lead sulphate. This moving of ions through the electrolyte is called diffusion. When the battery is being charged the reverse process takes place. The diffusion process is relatively slow, and as you can imagine, the chemical reaction will first take place at the surface of the plates, and later (and also more slowly) deep inside the active material of the plates.
The function of a battery in a power installation
The battery acts as a buffer between the power sources (DC generator, battery charger, solar panel, wind generator, alternator, electricity grid) and the power consumers (DC lighting and pumps etc; and - with an inverter - AC powered appliances).
An off grid battery-based installation usually experiences cyclic daily use - recharging during the day, and discharging during the night or quiet periods. In mobile off grid installations - mobile homes and boats - there may be long idle periods of winterization, or long periods where the battery is connected to the electricity grid.
The job of the battery is to ensure power is always available.
The number of charge/discharge cycles per year, the ambient temperature and many other factors influence a battery’s service life.
Related Knowledge Articles
lithium-or-lead-acid-battery
John Rushworth • 30 March 2015
Lithium-ion vs Lead-acid (AGM/Gel) Batteries
Lithium-ion vs Lead-acid (AGM/Gel): usable energy, depth of discharge & load performance compared.
lead-acid-battery-composition-types
Justin Tyers • 10 August 2026
The most common types of lead-acid batteries
Lead-acid batteries differ in alloy, electrolyte type, and build. Learn which one fits your needs.
how-a-battery-monitor-changed-my-rv-electrical-life-body-6
Justin Tyers • 15 September 2026
Lead-acid battery monitoring: How it works
Specific gravity, voltage, or amp-hours: three ways to track your battery's charge, and why monitors win out.
