Victron Energy at Metstrade 2025
50 years of Innovation. Decades of Marine Integration.
Visit us on Stand 01.541 to get hands-on with our latest products.
During fifty years of innovation we’ve developed hundreds of devices which build into whole-boat ecosystems for energy storage, battery charging, voltage conversion, DC distribution, system monitoring, and control.
But we don’t stop there: our partnerships with other leading manufacturers in the marine industry result in an extraordinary user-experience.
For example – our dedicated GX Boat Page is so good it’s been nominated for a DAME Design Award – the Oscar of the Marine Industry!
Boat Page communicates with electric propulsion motors, batteries, Android Tablet and navigation systems to provide at-a-glance whole system information and control – whilst cruising silently and sustainably.
New VICTRON ENERGY Products On Display at METS:
Lithium SuperPack NG batteries
Featuring an internal Battery Management System and Shunt these SuperPacks are a simple drop-in replacement for old lead-acid batteries – without extra cabling.
The shunt allows accurate state-of-charge monitoring; on-board Bluetooth communicates this information straight to your phone. SuperPack NG is self-heating too – it continues to provide full Lithium performance even at sub-zero temperatures.
The 12V 100Ah SuperPack NG has reduced height allowing it to fit tiny spaces – even under the seat of a camper! Next Generation SuperPack is expected in Feb 2026.
Battery Management Systems for Lithium Smart NG – the Next Generation
Our BMS range just got bigger:
NG BMS’s are mandatory when installing our NG Lithium Smart batteries.
A BMS controls and protects lithium batteries through charge/load cycles preventing over/under voltage and temperature. Bluetooth allows wireless configuration, updates and status monitoring – at cell level – direct from your phone via the VictronConnect app.
Smart BMS NG 12/200 : Controls the charging current of up to 50 Victron Lithium NG 12.8V batteries from any 12V alternator. Adjustable current limiter; battery protection and combiner. Safety at sea: this BMS uses MOSFET switches and is therefore ignition proof.
VE.Bus BMS NG: BMS NG for systems having VE.Bus communication. It receives battery current data – no need for a separate SmartShunt. Bluetooth connection allows for local monitoring via VictronConnect.
SmallBMS NG: It’s tiny – but powerful. Bluetooth on board – it’s a cost-effective alternative to the rest of the BMS NG range, for systems where no integration with Inverter/Chargers is required.
Smart IP43 Charger – new 48V model
New 48V model. A very welcome addition to our range of chargers for boats having 48V systems – finally a fully integrated 48V charger.
A wide input range of 85-250VAC allows these battery chargers to be connected to shore power anywhere in the world. These chargers adapt to fluctuating power – whether from weak grids, generators, or long cable runs. Models having two or three outputs can charge separate battery banks, simultaneously, with a clean and stable output.
Models are now available for all DC system voltages: 12V / 24V / 36V / 48V.
Orion XS 12/12-70A battery to battery charger
Orion XS 12/12 70A is our new high-power battery charger – available in the second quarter of 2026 it can be parallel-connected for even more charging power.
Orion XS allows you to connect any alternator to any battery. It protects the alternator from Lithium battery high demand. Available with 12V / 24V or mixed 12/24/12 input/output conversion – the 12/12 70A compliments our range of Orion XS chargers which includes:
MultiPlus-II 4k5 and 6k5
Our extensive range of MultiPlus-II Inverter/Chargers just got bigger.
Multi RS 48/6000
Our lightweight, compact 6000VA High Frequency Inverter/100A Charger is ideal for Marine systems: HF technology allows size and weight reductions with higher power conversion efficiency and a smooth AC output to power the most sensitive on-board electronic-devices.
The Multi RS 6000 differs from other RS devices in our range in that there is no on-board MPPT.
GlobalLink 530
Connecting your off-grid power installation to VRM allows you to keep an eye on it and control it remotely. Our GlobalLink 520 remains available – the new GlobalLink 530 offers true 4G connection with higher potential speeds and lower latency.
Brand INTEGRATIONS allow outstanding user experience:
For decades we’ve partnered with major brands in the Marine Industry to push the limits of what’s possible in performance and control. Devices which speak the same language take functionality beyond customer expectation. Come and see the new standards in marine applications including:
POWER SESSIONS:   Expert briefing, Headphone audience with Q&A
Take part in one of our scheduled 30-minute Headphone-Audience Power Sessions. Just turn up and take part for up-to-the-minute information on the following subjects:
Next Generation Lithium Batteries, Superpacks and NG BMS
Sessions Available : Tuesday 11:00 /  Wednesday 14:00 / Thursday 11:00
What does NG make possible? Massive storage; parallel banks for redundancy; high-precision shunts allow cell-level read-out via Bluetooth straight to your phone, 12V/24V/48V formats and up to IP65 with mounting bracket for hostile constant motion environments.
Marine Integrations and Monitoring
Sessions Available : Tuesday 14:00 /  Wednesday 11:00 / Thursday 14:00
Beyond expectation user-experience. Learn about : GX Boat Page – what does it provide for the user?; Temp sensing; Multiple tank-sensing – aggregated level; Digital Switching; Load switching; all-systems MFD.
Stand Party – Your invitation
Please join us for our stand party – we’re now famous for them:
Metstrade takes place between 18th and 20th November at RAI Amsterdam We look forward to welcoming you on stand 01.541 !
Avatar of justin
Previous
Fuel Station opens E-Bike pit stop
Next
Uninterruptible power for pet care provider
Related blogs
