Where to buy
Find a dealer near you
Lightning-fast maximum power point tracking
Remote Management optional
Intelligent charge algorithm
VictronConnect App
Wireless charging synchronisation
SafetyShield+
12/24/36/48 Volt
Fast and efficient charging to keep batteries full
Uninterrupted battery protection
Easy pairing for synchronised charging
Compact and robust design
The SmartSolar MPPT extracts every bit of energy from the sunlight, even in partially shaded conditions. Extremely fast power point tracking and intelligent charge algorithms make it happen.
Multiple MPPTs can coordinate, using Bluetooth or a GX communication centre connected to the VE.Can port. This allows them to switch through charge stages simultaneously, extending battery life and ensuring peak system efficiency.
Get the most out of your solar panels while protecting your batteries with adaptive charging. The MPPT solar charge controller automatically switches between bulk, absorption, and float stages, with intelligent algorithms tailored to your battery type.
Compatible with lithium, AGM, gel, and flooded batteries, the MPPT solar charge controller offers automatic voltage selection and a dedicated charging profile for each battery type. It can even revive fully discharged batteries.
Models 150/70 to 250/100 offer extra built-in features. These include relay and on/off terminals for automated load management and remote operation, and an optional plug-in display (sold separately) for viewing essential device information. MC4 models come with MC4 connectors for quick, secure solar panel connections.
The VE.Direct port connects to a communication centre for access to VRM, Victron’s remote management portal. Configure settings, check system data, analyse performance, and actively manage your system from anywhere in the world.
The SmartSolar MPPT prioritises battery care with built-in SafetyShield+ features, based on decades of battery know-how. These include temperature-compensated charging, over-temperature protection, and safeguards against PV short-circuits, reverse polarity, and reverse current.
Get started quickly with VictronConnect, our user-friendly smartphone app trusted by millions worldwide. Extensive battery presets make configuration simple for new or existing systems, while the app gives you control over features like load output settings, charging profiles, and real-time performance monitoring.
The Victron system is designed to give you complete control anytime, anywhere.
VictronConnect App
VRM - Remote Monitoring portal
Solar & Wind priority
Solar forecast
The VictronConnect app connects you to your energy system, delivering real-time data and a 30-day performance history. Configure devices, update firmware, and create custom alarms, easily adapting a setup to your exact needs.
Connect to the Victron Remote Management (VRM) portal with a communication centre to operate your system remotely. Use VRM app widgets, create custom data views to monitor key parameters, manage multiple systems simultaneously, and set up alerts to prevent issues.
Victron’s Solar & Wind Priority feature automatically favours the energy harvested by the SmartSolar MPPT to charge your batteries. Shore power is only used as a safety net to prevent deep discharge. This feature requires an inverter/charger and GX device to coordinate the system.
The VRM portal combines your system’s historic performance data with local weather forecasts to predict how much solar power you could generate in the coming days. Plan your energy use accordingly and make the most of every sunny day.
Whenever and wherever the sun shines, the SmartSolar MPPT charge controller will extract maximum power from your panels.
Get a higher solar yield while out on the water. The SmartSolar MPPT excels in changing conditions, handling partial shading from sails, clouds, and moving objects while protecting your batteries.
Become even more self-sufficient by synchronising multiple SmartSolar MPPTs to work as one. This improves solar harvest, boosts system performance, and extends battery life.
Keep benefitting from solar power as shadows shift and change on the road. Engineered for mobile life, the SmartSolar MPPT maintains peak performance through vibration, movement, and changing conditions.
Save fuel by converting more solar energy, using the MPPT’s fast power point tracking technology. Manage multiple generators remotely and monitor critical parameters with custom VRM widgets and push notifications.
Powered by decades of know-how
Our modular ecosystem of robust building blocks is designed for maximum performance and efficiency. All products work together as one and can be managed remotely, from a few feet to thousands of miles away.
Support
Warranty
©Victron Energy 2026
