Multi HS19 Solar 15k
5. Operation
In this section:
5.1. Device display
The Multi HS19 Solar has an LCD screen that displays operational information.
The pages will change one after the other. There is no button or any other means to change to the next page.
ACin: This page shows the voltage and power for each of the input phases.
The state of the AC input relay, open or closed, is shown on the bottom row of the screen.
ACout1+2: On this page, the voltage and power for each of the phases at the AC output.
The power figures are the sum of the loads on the AC output 1 and AC output 2.
The state of the AC input relay, open or closed, is also shown on the bottom row of this screen so that you can more easily see that the Multi HS19 Solar is passing the AC input power through to the AC output.
Battery: The battery voltage, current and power are displayed. Negative current and power values mean that the battery is discharging.
SOC is the state of charge of the battery.
CAH displays the capacity of the battery in Ah.
Solar There are four separate pages for each of the solar PV trackers.
The PV voltage and power as well as the total energy harvest for the day per tracker.
