MultiPlus-II GX
13. Technical Specifications
In this section:
MultiPlus-II GX
24/3000/70-32
48/3000/35-32
48/5000/70-50
INVERTER/CHARGER
PowerControl & PowerAssist
Yes
Transfer switch
32 A
32 A
50 A
Maximum AC input current
32 A
32 A
50 A
Auxiliary output
Yes (32 A)
INVERTER
Input voltage range
19 - 33 V
38 – 66V
Output 1)
Output voltage: 230 VAC ± 2%            Frequency: 50 Hz ± 0,1%   (1)
Cont. output power at 25°C   (3)
3000 VA / 2400 W
5000 VA /4000 W
Cont. output power at 40°C / 65°C
2200 W / 1700 W
3700 W / 3000 W
Maximum feed-in power
3000 VA
5000 VA
Peak power
5500 W
9000 W
Maximum efficiency
94%
95%
96%
Zero load power
13 W
11 W
18 W
Zero load power in AES mode
9 W
7 W
12 W
Zero load power in Search mode
3 W
2 W
2 W
CHARGER
AC Input
Input voltage range: 187-265 VAC    Input frequency: 45 – 65 Hz
Charge voltage 'absorption'
28.8 V
28.8 V / 57.6 V
Charge voltage 'float'
27.6 V
27.6 V / 55.2 V
Storage mode
26.4 V
52.8 V
Maximum battery charge current   (4)
70 A
35 A
70 A
Battery temperature sensor
Yes
GENERAL
Programmable (AUX) relay   (5)
Yes
Auxiliary power supply
12V / 100mA
Programmable open collector output
70V / 100mA
Analog-digital aux inputs
Yes, 2x
Temperaure sensor
Yes
Voltage sense contacts
Yes
Protection   (2)
a - g
VE.Bus communication port
For parallel and three phase operation, remote monitoring and system integration
General purpose com. port
Yes, 2x
Interfaces
BMS-Can, USB, Ethernet, VE.Direct, Wi-Fi
External AC current sensor (optional)
50 A
100 A
Remote on-off
Yes
Operating temperature range
-40 to +65 °C (fan assisted cooling). Maximum Altitude 2000m
Humidity (non-condensing)
max 95%
ENCLOSURE
Material & Colour
Steel, blue RAL 5012
Protection category
IP22
Battery-connection
M8 bolts
230 V AC-connection
Screw terminals 13 mm2 (6 AWG)
Weight
19kg
30kg
Dimensions (hxwxd)
3kVA - 506 x 275 x 237 mm
565 x 323 x 148
STANDARDS
Safety
EN-IEC 62019-1, EN-IEC 6201-2, EN-IEC 60335-1, EN-IEC 60335-2-29
Emission / Immunity
EN55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3
IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3
Uninterruptible power supply
IEC 62040-1
Anti-islanding
Please consult the certificates on our website.
1) Can be adjusted to 60 Hz
2) Protection key:
a) output short circuit
b) overload
c) battery voltage too high
d) battery voltage too low
e) temperature too high
f) 230 VAC on inverter output
g) input voltage ripple too high
3) Non-linear load, crest factor 3:1
4) Up to 25°C ambient
5) Programmable relay which can be set for general alarm, DC under voltage or genset start/stop function.
AC rating: 230V / 4A, DC rating: 4A up to 35VDC and 1A up to 60VDC
