Manual - EV Charging Station NS
2. Description and features
In this section:
2.1. Description
The EV Charging Station NS is an AC charging station for electric vehicles. It delivers up to 22 kW in three-phase mode or 7.3 kW in single-phase mode, with a configurable charging current of up to 32 A per phase.
The charging station connects to the local network over WiFi or Ethernet. It is operated and monitored with the VictronConnect app over Bluetooth, in its own web interface, from a GX device, and from anywhere through the VRM portal and VictronConnect-Remote.
In a system with solar, the charging station can charge the vehicle from surplus solar energy once the house batteries are full and feed-in is active, instead of exporting that energy to the grid at a lower price.
An internal RCD monitors residual current and stops charging on a fault, integrated energy metering records the energy delivered to the vehicle, and proximity pilot detection limits the charging current to the rating of the connected cable. A motorised lock secures the cable in the socket. In selected regions, an intrusion detection sensor stops charging and displays an error if the case is opened.
A programmable RGB light ring around the charging port shows the state of the charging station, with 55 configurable light effects.
2.2. Features
2.3. What's in the box?
  • EV Charging Station NS
  • Mounting plate
  • 28mm nylon cable gland for power cables up to 19mm in diameter
  • Type 2 cable plug holder dummy socket
  • Rubber plug
