Manual - EV Charging Station NS
5. Setup, configuration & operation
In this section:
5.1. First use setup via VictronConnect
The initial setup is required when the EVCS is new and has yet to be configured or after it has been reset to factory defaults.
Preparation
  1. Open VictronConnect and find the entry for your EVCS (EVCS-HQXXXXXXXXX).
  2. Tap on EVCS. This will start the pairing dialogue. Enter the pairing code, which is a unique number on a sticker inside the housing.
Start initial setup
After successful pairing, the Status page appears.
A warning notification will pop up stating "Initial setup not completed".
Tap the cog wheel icon in the upper right to open the Settings page so that the initial setup can be performed.
Step 1 of 5: Location and time zone
Complete the fields for your Region, Country, Country region, and time zone.
Note
The time zone is important for charging schedules to work properly.
Step 2 of 5: Off peak charging
Some regions prohibit EV charging during certain hours of the day.
You should leave this setting enabled if this applies to your region.
Step 3 of 5: Configure WiFi access
One of the following parameters must be changed to complete the first setup and start using the EV:
  • Either confirm the WiFi mode AP (the EVCS provides its own access point) - some of the parameters are already pre-filled. You need to provide an Access Point Passphrase.
  • Or choose Station mode to connect the EVCS to your local network/router. If you already know the network name (SSID), you can enter it manually. Alternatively, hit SCAN to find nearby networks, select your desired network, and enter the access password.
Step 4 of 5: Change web access credentials
This step is necessary to ensure secure access to the web interface. The default username is "admin". The default password corresponds to the one on the sticker inside the EVCS. We recommend setting up your own password and username.
Step 5 of 5: Set the maximum charging current
Set the maximum charging current with which the EVCS is allowed to charge (range: 6A - 32A).
Note
This setting is the hard limit of the EVCS. You'll still be able to set the actual charge current between the minimum up to the maximum limit set here.
Initial setup complete
You'll be returned to the Status page and the warning notification will have cleared.
You can now start using the EV Charging Station NS.
5.2. First use setup via WiFi access point
The charging station broadcasts its own WiFi access point as soon as the charging station is powered for the first time. The following steps describe the first setup to prepare the charging station for operation.
Connect to the WiFi access point:
  1. Scan the QR Code on the internal label.
  2. Or go to the WiFi menu of your mobile device or laptop and manually add the access point that automatically broadcasts its SSID. SSID and Password are noted on a sticker inside the case.
  1. Location setup:
    Once connected to the access point, enter the default IP address 192.168.0.1 into a web browser. The default username is "admin". The default password is printed on the sticker inside the unit. The First setup process will then start:
    Select the location and time zone where the EV Charging Station NS is being installed. Daylight savings time will automatically be applied accordingly.
  2. Off peak charging
    Depending upon what location was chosen in the previous step, you may need to enable Off-peak charging.
  3. WiFi setup: Configure the WiFi network by choosing the WiFi mode
    1. Access point: The unit creates its own WiFi access point. This is either for setting up the unit or in the absence of a separate WiFi network including a GX device.
      Set SSID, Wi-Fi Password, IP address and Mask (subnetmask) according to your needs.
    2. Station: Connects the device to a local WiFi network that includes other Victron devices like a GX device or VRM.
      Change the WiFi mode from AP to Station.
      Click the Scan button to search for other WiFi networks or add manually a known AP by clicking the Add button. Note the WiFi standards: 802.11 b/g/n (2.4Ghz only).
      Tick the network you wish to connect to and then click Apply.
      In the Password box, enter the external WiFi password and click Next.
      In case you need a static IP rather then DHCP, change the IP mode button to Manual and fill in the static IP address, Mask, Gateway and DNS.
  4. Access setup:
    1. Click into the Username field and type in your own username. The default username is 'admin'.
    2. Click into the Password field and change the password to a new one with at least 8 characters, containing lower, upper and special characters. The default password is printed on the sticker inside the unit.
    3. Confirm your new password.
    4. Click Next.
  5. Charging current setup:
    Set the maximum allowable charging current (6 - 32A).
  6. First setup completion:
    After clicking Save, the EV Charging Station NS will restart.
    Log in with the credentials that you entered in step 3.
    The main Dashboard page will be displayed and the EV Charging Station NS is ready to use.
5.3. MQTT activation
This is the recommended method of connecting the EV Charging Station NS to a GX device.
Communication with a GX device was previously based on Modbus TCP. MQTT is more flexible and gives the EV Charging Station NS access to a larger GX dataset, so the two devices exchange more information and work together better.
  • The EV Charging Station NS can be reached from anywhere with VictronConnect-Remote.
  • Warnings and errors are shown on the GX device.
  • The GX device can control charging for GX Opportunity Loads and Dynamic ESS.
  • It is the foundation for future features.
Modbus TCP remains available as an alternative.
Note
The GX device must be running version 3.80 or later.
VictronConnect must be version 6.41 or later.
The EV Charging Station NS and the GX device must be paired before they will communicate with each other.
The GX device must first be set to pairing mode where it will listen for a pairing request from the EV Charging Station NS.
5.3.1. Activate pairing mode
Either from the GX device touchscreen or its web interface, navigate to Settings → Integrations → MQTT Devices.
Tap the Activate button to enable pairing mode on the GX device.
A popup will show briefly at the bottom of the page informing you that pairing mode has been enabled. Additionally, the Activate button will be replaced by a countdown timer showing the remaining time that pairing is active.
Note
If you run out of time, you can simply tap the activate button again.
As an alternative to the above two steps, pairing mode can also be activated using the physical button on certain GX devices that are equipped with one.
Double press the button with a pointed object, like a pen.
The blue LED on the front of the GX device will flash steadily when pairing mode is active, and will time out after two minutes.
5.3.2. Pairing via EVCS web interface
From the EV Charging Station NS web interface, navigate to General → GX device.
Ensure that Communication is set to Enabled.
Set the communication type to MQTT.
Tap the "Discover" button to find GX devices on the network.
Note
The EV Charging Station NS and the GX device need to be on the same network subnet.
A popup box will show all GX devices which have been discovered on the network.
Tap or click on the GX device you want to pair with.
The IP address and VRM Portal ID of the selected GX device will be populated in the respective fields.
Note
Ensure that Pairing mode is still active of the GX device. If it has timed out, activate it again.
Tap the Pair button to begin the pairing process.
Once successfully paired, a message will pop up at the bottom of the page.
The details of the paired GX device will be written below the buttons.
Finally, click the Save button at the bottom of the page
Additionally, on the GX device, the EV Charging Station NS will be listed as a paired device.
The EV Charging Station NS appears in the device list, with a brief description of its status.
The EV Charging Station NS shows on the main Overview page of the GX device.
5.3.3. Pairing via VictronConnect
This method is an alternative to the web interface method described previously. The pairing process here uses VictronConnect instead.
If you have already completed the pairing process using the web interface, and communication is established, then you can skip this section.
Note
VictronConnect version 6.41 or later is required.
Connect to the EV Charging Station NS using the VictronConnect app.
Navigate to Settings → General → GX Device.
Tap Selected GX (None).
Turn "Enable communication" on.
Set the "Communication type" to MQTT.
Note
Any discovered GX devices will appear in a list.
Tap "Select" to choose the GX device you want to pair with.
Note
Tap the "Pair" button to begin the pairing process.
Once successfully paired, the status should change to "Communication established" in green, along with the IP address and VRM ID of the GX device.
5.4. GX device setup, configuration and operation
5.4.1. Setup menu and options
As soon as MQTT communication has been activated, the named EVCS appears in the device list and displays the current mode and charging status.
This sub menu displays the current charging session with charging power per phase.
The charging mode can be changed along with any other parameters related to a particular charging mode.
The Setup menu allows some settings to be configured, including the position that the EV Charging Station NS is installed at.
Autostart will enable charging as soon as the vehicle is plugged in.
Note
When charging is enabled, it does not necessarily mean that the vehicle will start charging right away. It means that the EV Charging Station NS will be ready to start once a schedule becomes active, for example.
The Device sub menu displays the EV Charging Station NS parameters.
The name of the EV Charging Station NS can be changed.
5.5. VictronConnect setup, configuration and operation
5.5.1. Setup
The following steps are necessary to successfully connect to the EV Charging Station NS via Bluetooth and VictronConnect:
  1. Make sure Bluetooth is enabled in your EVCS.
    Tip
    In case Bluetooth is disabled, see the Networks menu chapter for details on enabling Bluetooth.Networks menu
  2. Download and install the VictronConnect app from the App Store or Google Play.
  3. Open VictronConnect and scroll through the list of devices for the EVCS.
  4. Tap on it to launch the pairing dialog. Enter the pairing code which is the unique number on the sticker inside the housing.
  5. After successful pairing, the EVCS overview page is displayed.
5.5.2. Overview page
The overview page provides information about the charging state, controls to start/stop charging or changing the charging mode and charging current. Furthermore, the actual charging values and session statistics can be monitored.
Controls:
  • Start/Stop: Start or stop charging.
    Note that after pressing the stop button, first the charging current is reduced to a minimum and only then the contactor opens (with a delay of 2 seconds).
  • Charging mode: Change the charging mode to manual, auto or scheduled.
  • Charging current: Adjust the charging current in Manual mode (range: 6-32 A, depending on the minimum and maximum charging current set on the General Settings page or in the web interface).
    In Scheduled mode, the charging current is not adjustable here because it is defined in the schedule.
    In Auto mode, the charging current is calculated dynamically based on surplus solar energy.
Actual charging values:
  • Power: Charging power. With a multi-phase supply, all phases are combined.
Session statistics:
  • Session time: The time of the current charging session.
  • Session energy: Total energy charged in this session.
  • Session cost: The session cost (when charged from grid) depending on the energy price per kWh set in the EVCS settings, see the General Settings chapter.
  • Session saved cost: Saved cost based on energy charged from PV and depending on the energy price per kWh set in the EVCS settings.
  • Total Energy: The total energy charged since initial installation.
5.5.3. Settings page
The Settings menu is accessible by pressing the cog wheel from the top right of the Overview page.
The following menu options are available:
  • Network: Change the network settings.
  • General: Adjust the charger settings.
  • Scheduler: Set up charging schedules.
  • Light Ring: Configure the behaviour of the light ring.
  • Access: Specify web access credentials.
Tap the three vertical dots in the top right corner of the settings page to perform the following actions:
  • Import settings from file: Import previously saved settings from a file in the settings library.
  • Save settings to file: Save the current settings to a file which will be stored in the settings library. This file can be used as a backup to restore settings on this EV Charging Station NS or to easily apply the same settings to another one.
  • Share settings: Share the settings file via email or other social apps which may be in use on the Android or iOS device for example.
  • Product info: Displays the EV Charging Station NS model number and serial number. There is also a switch to enable or disable Bluetooth. See the Product info section for more information.
  • Reset to defaults: Reset all settings to the factory defaults. This will mean that any customised settings will be lost and setup will need to be performed again or imported from a previously saved settings file.
5.5.4. Product info page
To get to the Product info page, tap the 3 vertical dots icon from the Settings page.
  • Product: Shows the product name and the model number.
  • Serial number: Shows the serial number of the EV Charging Station NS.
  • Pin code: Pin code is hidden but it can be changed using the change button to the right.
  • Custom name: Change the friendly name of the EV Charging Station NS.
  • Firmware: Displays the current firmware version running on the EV Charging Station NS.
  • Bluetooth: Enable or disable the Bluetooth functionality of the EV Charging Station NS.
More about how to assign your own name to your EV Charging Station NS and how to deactivate and reactivate Bluetooth, please refer to the VictronConnect App manual.
Warning
Note that if you disable Bluetooth via VictronConnect, it will have to be re-enabled via the web interface Networks menu or by using the Reset to factory defaults feature, either via the web interface or the DEF button procedure. For older devices that have Bluetooth disabled from the factory, use the web interface's network menu to enable Bluetooth.Networks menuReset to factory defaults and password recovery
5.5.5. Network Settings
The Network setting page shows options for configuring either type of network connection.
The WiFi section allows configuration of the WiFi settings for the EV Charging Station NS.
Ethernet section will take you to the Ethernet settings page for configuration of the wired Ethernet connection..
The WiFi Settings section shows:
  • Current status: Shows the current status of the network.
  • Connected to: Displays the name of the WiFi network that the EV Charging Station NS is connected to.
  • IP address: Displays the LAN IP address of the EV Charging Station NS.
  • Mode: Allows the choice of local WiFi connection or if the EV Charging Station NS should create a WiFi Access Point. The EV Charging Station NS should usually only be set up to act as an Access Point if there are no other WiFi networks available.
    Note
    The EVCS local WiFi connection (STA) mode is designed to operate within a network environment that uses certified, standards-compliant networking equipment. Ensure that the WiFi access point or router used in your installation meets applicable regulatory requirements and is RED-compliant, so the EVCS remains protected and performs reliably within a properly managed network.
  • IP Configuration: Option to allow automatic (DHCP) IP address allocation or manual fixed IP address configuration. Automatic IP configuration is the recommended option. The manual option is only intended for advanced network configurations or by instruction from the network's administrator.
The Access point list section shows discovered local WiFi networks or allows for a WiFi network to be added manually.
The currently connected Access Point name is shown here in green along with "FORGET" and "DISABLE" buttons.
  • Add AP manually: Provides the option to add a WiFi network manually. This may be used in circumstances where the required network's SSID is hidden and doesn't show in the list of discovered networks.
  • Scan for WiFi networks: Tap the "SCAN" button to immediately scan for available WiFi networks nearby.
    A list of all available WiFi networks will begin to appear as they are discovered. The list includes the Access Point name, its security status shown with a padlock symbol. The signal strength received by the EV Charging Station is displayed with the WiFi symbol to the right.
    Tap the "ADD" button beside the network that you wish to connect to. You'll be asked to enter the password for the selected network if applicable.
The Ethernet settings page shows the Network information for the wired Ethernet connection.
  • Status: Shows the if the wired network is connected or not.
The Settings section allows:
  • Enabled: Toggle the switch to enable or disable the wired Ethernet connection.
    Note
    If this option is enabled, then the below items will be greyed out.
  • IP Address: Configure the IP address.
  • IP Mask: Set the subnet mask for the network.
  • Gateway: Define the default gateway for this network.
  • DNS: Specify a DNS server accessible by this network.
  • MAC Address: This is not configurable here, but is displayed for information.
5.5.6. General Settings
The General settings page lists the options for the general configuration of the EV Charging Station NS.
Charging settings section has the following options:
  • EV Charger position: This option selects where in the system the EV Charging Station NS is wired. For example, the EV Charging Station NS could be wired on the AC Input side or the AC Output side of a MultiPlus.
  • EV Charger autostart: This option defines whether or not the EV charger will begin charging automatically when the EV charging cable is connected to the vehicle.
  • Control charging by Tag: Enforce the use of NFC Tag to start or stop charging sessions.
  • Manual mode phase: Choose how many phases to use when charging in manual mode.
  • Auto mode phase: Choose how many phases to use when charging in Auto mode.
  • Contactor active when charged: When the EV is charged the contactor can be set to remain closed or to open which will fully disconnect the EV from the supply.
  • Maximum charging current: The maximum charging current that the EV Charging Station NS will supply to the EV in any event. The configurable range is 6A to 32A.
    The maximum charging current will also be determined by the current rating of the connected charging cable.
  • Minimum charging current: The minimum charging current that should be supplied to the EV unless it is charged to the desired level. The configurable range is 6A to 32A.
  • Power calibration: Adjust this setting to calibrate the Actual power reading.
  • Actual power: Displays the actual combined power of all phases that the EV Charging Station NS is supplying to the EV.
Other settings section provides:
  • Energy price per kWh: Set the price of energy imported from the grid.
  • GX Device: Select this option for communicating with a GX Device such as a Cerbo GX or Ekrano GX.
  • Display settings: Adjust the settings for the built in LCD.
  • Date & Time: Set the time zone, date and time.
Reboot EVCS:
  • System reboot: tap the "REBOOT" button to reboot the EV Charging Station NS.
EV Charger position
Select the position that the EV Charging Station NS is wired in the system.
If the EV Charging Station NS is wired anywhere before the Inverter / Charger then select the "Inverter AC in" option.
Alternatively, if the EV Charging Station NS is wired after the Inverter / Charger or is wired after an Inverter then choose the "Inverter AC out" option.
Choose whether or not the EV Charging Station NS starts automatically when the charging cable is connected to the EV.
Select "Enabled" to have charging start automatically when the charging cable is connected to the EV.
Select "Disabled" if you don't want charging to start automatically. In this case charging needs to be started manually by pressing the "Start" button from the Overview page. This can help to prevent unauthorised use of the EV Charging Station NS.
Control charging by tag
If enabled, users must present an NFC tag to start or stop charging sessions.
Manual mode phase
Choose how many phases to use for charging in Manual mode.
Auto mode phase
Choose how many phases to use for charging in Auto mode.
Single + 3 phase will allow w wider range of charging power. Auto mode will switch between Single phase and 3 phase to allow higher charging power than a single phase can supply and a lower charging power than three phase can supply.
Note
The charging session may stop and restart again when auto mode changes the between single phase and three phase.
Choose whether or not the contactor within the EV Charging Station NS remains closed or opens when the EV is charged but the cable is still connected.
Select "Enabled" for the internal contactor to remain closed when the EV is charged. For example, this can be useful if you would like to pre-condition the cabin air using electricity from the charging source rather then the EV battery.
Note
Some vehicles may present an error if the EV Charging Station NS contactor remains closed after charging has stopped.
Select "Disabled" if you want the internal contactor to open when the EV is charged. This has the effect of disconnecting the EV from the supply as if the charging cable is removed.
Enter the price of imported electricity per kWh. This will be used to calculate the session savings.
GX device communication:
The GX device settings page is accessible from the General settings page.
  • Selected GX: Shows the IP address of the connected GX device and the VRM Portal ID.
    Tap this field to make changes.
  • Start charging at backup battery SOC: The minimum backup battery SOC before the EV Charging Station NS starts charging in Auto mode.
  • Stop charging at backup battery SOC if off grid: When off-grid or the grid is not available, then the EV Charging Station NS will stop charging when the backup battery SOC falls below this level.
  • Allow Battery/Grid power for Auto mode: Enable this setting to allow Auto mode to continue charging the EV at minimum current even if there is insufficient excess solar power. This helps to minimise automatic charging enable/disable cycles when in Auto mode. Note: The EV Charging Station NS cannot decide if the energy comes from the battery or grid, this is up to the inverter/charger in the system.
  • Allow low excess solar power for auto mode: If there is not enough PV power to satisfy the required car charging power, this option allows the EV Charging Station NS to make up the deficit using grid power.
    This only operates in Auto mode.
  • Battery/Grid power timeout: If the above setting is enabled then this is the maximum continuous amount of time that the EV Charging Station NS will draw power from the battery or grid.
  • Overload protection: When enabled, this setting will read the overload status of the system inverter. In the event of an overload then the EV Charging Station NS will reduce its charging current to minimum and wait about 5 seconds. If the inverter overload condition is still active then the EV Charging Station NS will stop charging. EV charging will resume a short period of time after the inverter overload condition has cleared.
    If multiple overload events are detected within a certain time period the the EV Charging Station NS will reduce the charging current by 10%.
    The same applies to grid-tied system where an enforced grid current limit is exceeded.
    A warning will be displayed in VictronConnect or in the EV Charging Station NS if charging power is reduced or if charging is interrupted.
  • Input current limit: This displays the enforced grid current limit which is applied to grid-tied systems.
  • Backup battery emulation: This should only be enabled in systems without a backup battery installed. Enabling this option allows the EV Charging Station NS to emulate a system battery. This allows Auto mode to work even if there is no physical battery in the system.
  • Enable communication: Enable or disable communication between the EV Charging Station NS and the GX device.
  • Communication type: Choose between MQTT or Modbus TCP. MQTT is the preferred method.
  • IP address: Shows the IP address of the connected GX device.
  • VRM Portal ID: Shows the VRM Portal ID used by the GX device.
  • Establish communication: Use this to set up communication with a GX device or to change to a different GX device. This is generally not needed if communication is already established as shown in green below.
  • Unestablish communication: Sever communication with an already connected GX device.
  • Device discovery: If the communication check fails then verify that the GX IP address specified is correct or use the "DISCOVER" button to search for a local GX device as below.
  • Device discovery: Tap the "DISCOVER" button to allow the EV Charging Station NS to automatically discover any GX devices on the local network.
    Any GX devices which have been found by Device discovery will be listed.
    Tap "SELECT" to pair the desired GX device to the EV Charging Station NS. This will then become the GX device that the EV Charging Station NS communicates with and its details will be populated in the IP Address and VRM Portal ID fields.
Date & Time
The correct date and time is essential for scheduled charging to work correctly.
  • Region: Select your time zone region.
  • Offset: If UTC region is selected then it will be necessary to enter the correct offset for your time zone.
System reboot
  • Tap the "REBOOT" button to reboot the EV Charging Station NS. Select "YES" on the popup window to confirm reboot.
5.5.7. Scheduler
If the Charging Mode is set to "Scheduled" from the Overview page then the EV Charging Station NS will charge according to the schedules set in this section.
Multiple schedules can be created for different times of the day and / or days of the week.
  • Add a new schedule: Tap here to configure a new schedule.
On the Scheduled scene configuration page you can adjust the following conditions. The time conditions are expresses in 24h format.
  • Enable: Toggle the current scene to enable or disable it.
  • Start time: The time that you want the EV Charging Station NS to begin charging.
  • End time: The time that you want the EV Charging Station NS to stop charging.
  • Current: The maximum amount of current to charge the EV during this schedule.
  • Repeat: Select the drop down menu to choose the type of repeat pattern.
    • Daily: The schedule will repeat every day.
    • Mon-Fri: The schedule repeats on week days Monday to Friday only.
    • Weekends: The schedule repeats on weekends Saturday and Sunday only.
    • Custom: A list of each day of the week is shown. Tick the days of the week that you would like this schedule scene to apply to.
Once you have set your preferences then tap the "Save new schedule" button to add it to the scheduler or "Cancel" if you don't want to create the new schedule.
The newly created schedule will be added to the scheduler list. From here the individual schedules can be enabled or disabled, amended or deleted.
  • Status: Shows the status of the scene. If the scene is disabled then it will not run.
  • Delete schedule: Tap the "Delete" button to delete the schedule, a popup box will show to confirm schedule deletion.
  • Add a new schedule: This will be shown below the existing schedules and can be used to create an additional schedule.
5.5.8. Light Ring
The light ring surrounding the charging cable socket on the front of the EV Charging Station NS shows what it is doing at a glance.
There are various lighting modes and brightness settings to choose from to represent the status of the EV Charging Station NS:
  • Disconnected
  • Connected
  • Waiting for start
  • Waiting for sun
  • Low SOC
  • Charging Manual
  • Charging Auto
  • Charged
  • Waiting for Tag
Light ring settings
The light ring of the EV Charging Station NS can be customised for each of its status modes as listed above.
  • Mode: Choose the behaviour or pattern that the light ring displays:
    • Static
    • Blink
    • Breath
    • Color wipe
    • Color wipe inverse
    • Color wipe reverse
    • Color wipe reverse inverse
    • Color wipe random
  • Color: Choose a color from the color picker or enter specific RGB values.
  • Period: Specify how long the mode will be displayed for.
  • Brightness: Adjust the brightness of LED ring for this mode, 0 - 100%.
  • Try this scene: Tap the "TRY" button to test if the scene's color and brightness are suitable.
5.5.9. Access
Web access credentials
The Web access credentials page allows you to change the access credentials for the web page of the EV Charging Station NS.
For security reasons it is strongly advised to change these credentials from their defaults.
  • User: User name
  • Password: Set a suitably strong password to prevent unauthorised access to the EV Charging Station NS.
5.5.10. Reset to defaults
It is possible to factory reset the EV Charging Station NS via VictronConnect. Note that this process will reset all settings to their default values and require the first setup (see the First use setup via VictronConnect chapter for details) to be performed again.
To get to the Reset to defaults option, tap the 3 vertical dots icon from the Settings page and tap on "Reset to defaults".
A "Restore device?" confirmation popup will appear. Tap "YES" to continue with restoring the device to factory defaults.
5.6. NFC tags
NFC tags can be used to allow only tag holders to start and stop charging sessions. Drivers can present their NFC tag near the NFC reader.
The NFC reader is located on the front of the EV Charging Station NS.
5.6.1. Adding NFC tags
NFC tags need to be added to the EV Charging Station NS before they can be used.
You need the tags you want to add and you need to have physical access to the EV Charging Station NS, to present the new tags.
Two NFC tags are included with the EV Charging Station NS.
Note
NFC tags can only be added via the web interface.
From the web interface select the Tags section on the left.
On the right hand side there is a table which lists all authorized tags. The table is currently empty.
Expand the Tags history field using the small arrow on the right.
Click the button called Activate NFC reader.
You now have 120 seconds to present the tags you want to add to the EV Charging Station NS.
Hold each tag up to the reader one at a time.
After all of the tags have been presented, they'll be listed in Tag history.
The scanned tags now need to be added:
  • Click Add at the top of the page.
  • Highlight the ID of the tag you want to add from the list to copy it, right click + copy or simply Ctrl+C.
  • Paste the ID into the ID box at the top right.
  • Give you new tag an appropriate name.
  • Click Accept. The tag will be added to the list.
The table on the right hand side now lists all authorized tags.
Click Save to save the tag list.
Under the General -> Charger settings menu, Enable the option Control charging by Tag.
Now the charging process can be controlled by any of the tags in the tag list.
5.7. Firmware updates
There are three different ways to perform firmware updates.
  1. Using VictronConnect.
    If a new firmware update is available, then a notification will pop up in the settings menu.
    Tap the blue Update text to install the update.
    Alternatively, tap the three dots menu from the settings page, and select Product Info.
    If a new firmware update is available, it'll be highlighted under the Firmware field.
    Tap the blue Update text to proceed.
    A confirmation page will show the current and new firmware versions along with release notes for the new version.
    Tap the blue Update button at the bottom of the page to install the update.
    Wait for the firmware update to install. A progress bar shows the installation progress.
    Once complete, a confirmation page will be displayed, including the release notes.
    Tap Continue to close the page and return to the settings menu.
    The EV Charging Station NS will reboot.
  2. Via the web interface.
    Under the Maintenance section, click FW update.
    Two options are presented , Online updates tab or Offline updates tab. Online updates is the easiest method to download and install the latest firmware updates.
    Click the Press to check button to check for any firmware updates.
    Note
    For offline updates, see the step for Optional Offline updates further down.
    The EV Charging Station NS will check for any newer firmware update online.
    If an update is available, the new version number will be shown in the Press to update button.
    The release notes for the new version will be listed below the button.
    Click the Press to update button to proceed with the firmware update.
    Optional Offline updates step:
    Note
    This is an optional method to Online updates. You can use Offline updates if your EV Charging Station NS is not connected to the internet.
    You'll need to download the offline firmware file from Victron Professional beforehand. Ensure you have the correct firmware file for the model of EV Charging Station NS you are updating. The last four characters of the firmware file represent the product ID. These should match the product ID of your EV Charging Station NS. This is in bold text e.g. (*C026.evcsup) in this example.
    Click Choose file to select the offline firmware file, then click the Update button to continue.
    The EV Charging Station NS will now install the new firmware.
    Once complete, a confirmation message will be displayed.
  3. Through VRM.
    Note
    For this method to work, the EV Charging Station NS needs to be connected to a GX device connected to the VRM portal.
    Log in to your VRM site and click on the Device list using the menu on the left.
    The devices in your VRM site will be listed.
    Click the Firmware Update button at the bottom of the page.
    Wait for VRM to return a list of firmware versions for all your devices. Any devices which have newer firmware update available will have a blue bar at the left.
    Look for your EV Charging Station NS in the list.
    The Installed column shows the firmware version that is currently installed on your device and the Latest column shows the latest firmware version that available for it.
    Click the blue Update Device button to install the latest firmware version.
    Allow the update to complete in the background.
    Once finished, the Installed and Latest firmware versions will be the same, with the Updatable column showing Up to date.
5.8. Reset procedure
You can reset the EV Charging Station NS in one of three ways.
  1. From VictronConnect app.
    Tap the settings cog icon, followed by the three dots icon.
    Choose "Reset to defaults" at the bottom of the menu.
  2. From the web interface.
    Select "Backup & Reset at the bottom of the menu tree.
    Click on "Reset to factory defaults".
    Select the tick boxes for settings that you may wish to keep.
    Note
    If you want to clear all settings then don't select any tick boxes.
    Click the Reset button.
  3. Reset button inside theEV Charging Station NS.
    Warning
    The DEF button procedure should only be performed by qualified personnel, as this process requires the EV Charging Station NS to be powered. Working under high voltage is very dangerous and can be fatal if done incorrectly. Do not touch any parts of the circuit board assembly while it is powered on. Use an insulated tool to press the DEF button.
    Use an insulated tool to press the DEF button on the circuit board. Press and hold the DEF button for at least 15 seconds to perform a full reset.
    Note
    If you hold the DEF button for more than 5 seconds but less than 15 seconds, only the password will be reset.
    The location of the button is shown in the image to the right.
5.9. Maintenance
The EV Charging Station NS does not require specific maintenance.
