Manual - EV Charging Station NS
8. Appendix
In this section:
8.1. External control of grid-relevant power (§14a EnWG - Germany)
The charging current of the EVCS can be limited to a maximum of 6 A using an external switch. This is particularly relevant in Germany to comply with the requirements of §14a EnWG (applicable to charging stations installed from 1 January 2024) and to enable the grid operator to reduce the charging power to help maintain grid stability. Note that this feature requires EVCS firmware v2.0 or later.
A warning (W-108 – The charging current is limited by an external switch) will appear on the display, web interface, or in VictronConnect when the switch is activated.
A charging limit is applied when the switch is closed. When the switch is open, there is no charging limit.
The diagram below shows how such a switch or relay should be wired to the EVCS.
