An Android tablet or phone can serve as a dedicated display for a GX device when running in kiosk mode. By connecting over WiFi, the Android device acts as a remote display for the local GX device.
The Android device display can function independently in systems without a dedicated screen, like a standalone Cerbo GX. The Android device can also act as an additional display when used alongside the GX Touch display or Ekrano GX built-in display.
It's also possible to connect multiple Android devices to a single GX device at the same time.
You can repurpose an older Android device instead of buying a brand new one specifically for this task.
When the App is running in kiosk mode, it takes complete control over the Android device, allowing only the desired functions to be accessible. This setup ensures that the Android device will be exclusively dedicated to the remote GX display task, offering a consistent and reliable user experience.
An internet connection is required to install the software. Once installed, the Android device can connect to a WiFi network without internet access, or directly to the GX's built-in WiFi access point.
There are few things to beware of before starting with the setup:
When running in kiosk mode, the Android device will act solely as a dedicated remote GX display. Access to regular apps and features on the device will not be possible.
You will not be able to use the tablet for tasks like web browsing, email, or any other apps.
The device will remain like this until it is factory reset.
The Android device needs a factory reset.
If you are planning to repurpose a previously used device, be aware that it will be wiped, and all data on it will be permanently erased.
Although the Android device connects wirelessly, it still needs a permanent charging source to keep the display on.
