Note
This installation method is not advised, particularly for end users, as it has several limitations.
Sometimes the QR code installation method might not be suitable.
Some Android devices don't support the QR code installation method.
Not all devices support MDM.
Users may want to use the device for routine tasks, and the GX display function can be activated when convenient.
For these cases, it is possible to install the app manually using the APK file without the need for a factory reset of the device.
Limitations:
Notifications from other apps will not be blocked and might interfere with the app's visibility.
The system might send the app to the background in order to show other apps.
Users might accidentally close the app.
Automatic updates are not supported. Users must manually download and reinstall the APK to upgrade.
To perform daily tasks, users might need to switch between networks with internet access and the one used by the GX device.
Some tablets automatically disconnect from networks without internet access, such as the GX built-in access point.
Your Android device may prevent APK installation due to security settings. To learn how to change these settings and install apps from APK files, refer to your device's user manual.
The APK file can be downloaded from this link: https://ve3.nl/gxDisplay
Run the APK file to begin installing the app.
After the app has installed, you can proceed with the initial configuration steps.
