venus-os:start
Victron GX product range
Introduction
The GX-device lies at the heart of the system - providing monitoring, and operating as the communication-centre of your installation. All the other system-components - such as inverter/chargers, solar chargers, and batteries - are connected to it. Monitoring can be carried out locally and remotely - via our free-to-use Victron Remote Management portal (VRM). The GX-device also provides Remote firmware updates and allows inverter/charger settings to be changed remotely.
  • Cerbo GX - Most commonly used GX product.
  • Cerbo-S GX - Lower cost version, same as normal Cerbo GX but without BMS-Can port, Tank- and Temperature monitoring inputs.
  • Color Control GX - Our first released GX product, the CCGX has a display and buttons.
  • Venus GX - The Venus GX has more analog and digital IO, no LCD and is more cost effective than the CCGX.
  • CANvu GX - The CANvu GX is best for harsh environments - when its IP67 rating and touch LCD is a must.
  • Octo GX - The Octo GX is particularly suited to medium size installations which have many MPPT Solar Chargers, as it has 10 VE.Direct ports.
  • Maxi GX - Compared to the other GX devices, the Maxi GX has most CPU power and most VE.Direct ports: 25. This is the GX device to use for large systems with many VE.Direct MPPT Solar Chargers.
Lastly, there is a GX device built into our MultiPlus-II GX and EasySolar-II GX Inverter/chargers.
Available accessories
  • GX Touch - Touch screen display accessory for the Cerbo GX
  • GX GSM - A 2G and 3G cellular modem. It connects to GX device via USB, and takes a simcard
  • GX LTE 4G - A 2G, 3G and 4G cellular modem. It connects to GX device via USB and takes a simcard
  • Energy Meters - Measures PV Inverter Output where PV Inverters cannot be read-out directly. Also used as a grid meter in an Energy Storage System (ESS).
  • VE.Can resistive tank sender adapter - Allows a standard resistive tank-level sender to be connected to the GX device. Note that some GX Devices feature resistive tank-level inputs themselves.
  • GX Touch adapter for CCGX cut-out - An adapter that fits in a cut-out made for a CCGX, into which fits a Cerbo GX. For when upgrading a CCGX system to a Cerbo GX. More details available asap.
Comparison table
User interface Cerbo GX CCGX Venus GX Octo GX CANvu GX Maxi GX MultiPlus-II GX and EasySolar-II GX
Appearance
Display
GX Touch
optional touch display (16)
GX Touch 50: 800 x 480
GX Touch 70: 1024 x 600
480 x 272 LCD Display & 7 buttons no display no display 4.3“ touch-screen 2×16 character display
Remote Console yes
Buzzer yes yes yes no yes no
Documentation Cerbo GX CCGX Venus GX Octo GX CANvu GX Maxi GX MultiPlus-II GX and EasySolar-II GX
Manual Cerbo GX manual CCGX manual VGX manual OGX manual CANvu manual Maxi GX manual MultiPlus-II GX manual
Product detail page page page page page page page page
Victron comm. ports Cerbo GX CCGX Venus GX Octo GX CANvu GX(12) Maxi GX MultiPlus-II GX and EasySolar-II GX
VE.Direct ports
(always isolated)
3 (1) 2 (1) 10 (1) 3 (1) 25 1
VE.Bus
(always isolated)
2 paralleled RJ45 sockets 1 RJ45 socket 2 paralleled RJ45 sockets
VE.Can yes - non isolated 2 paralleled RJ45 sockets – isolated no (14) depends (23)
Other comm. ports Cerbo GX CCGX Venus GX Octo GX CANvu GX Maxi GX MultiPlus-II GX and EasySolar-II GX
USB 2 USB Host ports
& 1 power only port(21)
2 USB Host ports 1 USB Host port
Ethernet 10/100 RJ45 socket - isolated except shield 10/100 RJ45 socket (12) 10/100 RJ45 socket
WiFi built-in optional (2) built-in, but see (3) built-in, external antenna (11) optional (2) no built-in
Bluetooth Smart yes (17) no depends (23)
Micro SDcard slot SDHC cards up to max. of 32GB. (5) no yes no
Second CAN-bus port
(BMS-Can) (18))
no no yes - non-isolated yes - non-isolated no no no
BMS-Can port (15) yes no yes (14) depends (14, 23)
Built-in RS485 no no no yes - non-isolated no no
IO Cerbo GX CCGX Venus GX Octo GX CANvu GX(12) Maxi GX MultiPlus-II GX and EasySolar-II GX
Programmable relay (7) 2 x NO/NC (8)
DC up to 30VDC: 6A
DC up to 70VDC: 1A
AC: 6A, 125VAC
1 x NO 1 x NO/NC (8) 1x NO / NC 2x NO / NC (8) n/a
Resistive tank
level inputs
4 (9) no 3 (9) no
Temperature sense
inputs
4 (10) no 2 (10) no
Digital Inputs 4 (22) no 5 (22) 3 (22) 1 (22) 4 (22) no
Third party compatibility Cerbo GX CCGX Venus GX Octo GX CANvu GX Maxi GX MultiPlus-II GX and EasySolar-II GX
Canbus-BMS batteries Many battery brands. See here for details
Fronius PV Inverters See here for details
SMA PV Inverters See here for details
ABB/FIMER PV Inverters See here for details
SolarEdge PV Inverters See here for details
Marine MFD
App Support
Generic MFD Manual, Navico, Garmin, Raymarine, Furuno
Performance Cerbo GX CCGX Venus GX Octo GX CANvu GX Maxi GX MultiPlus-II GX and EasySolar-II GX
CPU dual core single core quad core
RAM 1GB 256MB 512MB 512MB 256MB 512MB 512MB
Max. VE.Direct
devices (1)
15 5 6 10 4 25 25
Other Cerbo GX CCGX Venus GX Octo GX CANvu GX Maxi GX MultiPlus-II GX and EasySolar-II GX
Supply voltage 8 - 70 VDC 8 - 32 VDC 32 - 70 VDC powered internally, no external supply
Power draw 2,5 to 5 W (19) tbd
Mounting Wall or DIN rail (35mm)(20) Panel Integration Wall mounting DIN Rail (35mm) Panel Wall mount IP65 Built-in
Outer dimensions
( h x w x d )
78 x 154 x 48 mm 130 x 120 x 28 mm 45 x 143 x 96 mm 61 x 108 x 90 mm ? 600 x 380 x 210 mm
Operating temperature -20 to +50°C -20 to +70°C -20 to +50°C
Battery backup clock yes no yes yes
5V output no 1 A (13) no
Standards Cerbo GX CCGX Venus GX Octo GX CANvu GX Maxi GX MultiPlus-II GX and EasySolar-II GX
Safety IEC 62368-1 EN 60950 IEC 62368-1 IEC 62368-1 IEC62368-1 IEC 62109-1, IEC62109-2, IEC62040-1
EMC EN 301489-1, EN301489-17
Automotive ECE R10-6 E4-10R-053535 ECE R10-6 no
Notes
  1. The listed maximum VE.Direct devices on the `Performance` section in above table is the total connected VE.Direct devices such as MPPT Solar Charge controllers. Total means all directly connected devices plus the devices connected over USB. The limit is mostly bound by CPU processing power. In relation to that, note that (a) connecting solar chargers over VE.Can is more efficient than connected over VE.Direct - and besides more efficient also makes for better communication wiring. For example, a Cerbo GX can perfectly handle 25 pieces of VE.Can Solar Charger, combined with 6 pieces of Fronius three phase PV Inverter and of course a three phase Victron system. And note (b) that CPU load is not only caused by connecting VE.Direct devices; there are also other factors. Connecting multiple PV Inverters increases the CPU load, especially when they are three phase. Enabling ModbusTCP increases the CPU load as well. Up to three or four three phase inverters can typically be monitored on a CCGX. Higher power CPU devices can monitor more.
  2. Though the CCGX has no built-in WiFi that functionality can easily be added by attaching a USB-WiFi dongle. See CCGX Manual, section 1.4.2 for details.
  3. The built-in WiFi in the Venus GX has a very low signal strength - unfortunately. It is strong enough to connect to a phone, tablet or laptop in order to access setup and monitoring. But to connect the Venus GX to the internet either use the built-in Ethernet port or add a USB-WiFi dongle. See CCGX Manual, section 1.4.2 for details. Make sure the Venus GX is running v2.06 or later - early shipments of Venus GX units ran v2.05.
  4. The hardware of the Venus GX and Octo GX includes a built-in Bluetooth Smart chipset which hasn't proved satisfactory. Bluetooth Smart for GX devices is coming soon but will not use built-in chipsets.
  5. Larger SD memory cards (SDXC) are not supported. SD cards can be used for two purposes:
  6. The second CANbus port is accessible via the GND, CAN-H and CAN-L terminals. Note that the port is not Isolated. See Settings → Services for configuring that port.
  7. The programmable relay can be set to act as an alarm relay, automatic genset start stop, or an on/off switch, and is controlled via the GUI and/or ModbusTCP.
  8. In the Venus and Cerbo GX hardware there are two relays. Currently, Relay 1 can be used for programming as an alarm relay, generator start/stop, tank pump, temperature controlled relay or manual operation. Relay 2 is available for programming as a temperature controlled relay or manual operation in the Relay menu of the GX (requires firmware 2.80 or higher).
  9. The tank level inputs are resistive and should be connected to a resistive tank sender. Victron does not supply tank senders. The tank level ports can each be configured to work with either European (0 - 180 Ohm); or US tank senders (240 - 30 Ohm).
  10. The Cerbo GX has four temperature terminals, and the Venus GX has two. They can be used to measure & monitor all kinds of temperature-inputs. Temperature senders are not included. The required sensor is ASS000001000 - Temperature Sensor QUA/PMP/Venus GX. (Note that this is not the same as the BMV temperature accessory.). Temperature range is -20C to +70C. Actually it can measure up to 100C, but the sensor is not made to withstand temperatures above 70C long term. Note that this is intended as a crude temperature sensor, and not calibrated. A deviation of +/- 2C is to be expected.
  11. Octo GX comes with a small Wifi antenna. You may remove and replace it with any other Wifi antenna having an RP-SMA connector.
  12. The 5V output on the Venus GX can be used to power, for example, a USB hub. Note that its output is not current limited or otherwise protected, and it shares the internal power supply in the Venus GX: overdrawing from it will result in shutdown(s) of the Venus GX. It is recommended to install a fuse for prevention.
  13. The CAN-Bus port of the Maxi GX, MultiPlus-II GX and EasySolar-II GX is a BMS-Can port. It can only be used to connect to managed batteries such as Freedomwon, BYD, Pylontech, BlueNova, MG Energy Systems and others, at 500kbps. Note that some early production batches had a labelling mistake: the port was labelled VE.Can. Which -unfortunately- is wrong. The hardware does not meet the requirements for a VE.Can port; and therefor is BMS-Can only.
  14. A BMS-Can port is a port dedicated to be used for connecting managed batteries, such as Freedomwon, BYD, Pylontech, BlueNova, MG Energy Systems and others, only. It is not possible to connect Victron VE.Can products to that port. To connect such managed battery, use our special cables, and see documentation here. Connect the side labelled 'VE.Can' into the BMS-Can/VE.Can port on the GX Device. And connect the other side to the battery. The baudrate of a BMS-Can port is fixed to 500kbps.
  15. The GX Touch connects to the Cerbo GX using a single cable; fixed permanently to the GX Touch, which on the other end splits into a USB and a connector for the video signal. Both need to be inserted into the Cerbo GX, taking one of the three USB ports. The USB part of the cable is used to power the GX Touch. The cable is 2 meters in length; and can not be extended in length.
  16. The Bluetooth feature of the Cerbo GX allows to configure its WiFi and Ethernet settings from within VictronConnect. Even though it can be used for wireless temperature monitoring, we recommend to use a USB Bluetooth adapter instead: the Bluetooth function in the Cerbo GX stops working when the internal temperature is too high.
  17. The secondary CAN port, available on some GX devices as per table above, can be configured to be used as a BMS-Can port, as well as other profiles. For details, see manual.
  18. Cerbo GX power draw without GX Touch mounted: around 2.8W. With GX Touch connected, and backlight off: 3.8W. Backlight at max intensity: 4.8W
  19. DIN rail mounting requires additional accessory - DIN35 Adapter.
  20. On the Cerbo GX, the USB socket closest to the HDMI connector can only be used to power a GX Touch. That USB port can not be used for any data related functions such as VE.Direct to USB cables, USB-sticks, USB-GPS-es, or other common USB usages. It’s a power port only, no data.
    Future versions of Venus OS will disable all data related features of this port, so it should not be used for anything other than powering the GX Touch screen. Attempting to use this port for data purposes may lead to corrupted VRM data on USB sticks or unreliable communication to for example a Solar Charger when using a VE.Direct to USB cable.
  21. The digital inputs can be used for open/closed monitoring of alarms, for example doors, or fire- or bilge alarms. The digital inputs on the Venus GX can also be used for pulse counting. The digital inputs on the Cerbo GX and other devices are not able to do pulse counting. See product manual for electrical specifications of the digital inputs.
  22. Late 2021 / early 2022, the hardware of the MultiPlus-II GX and EasySolar-II GX product range has been updated. The update adds Bluetooth and changes the CAN-communications port from a limited 500kbps BMS-Can only type to a full featured VE.Can port (non-isolated). Status per model, updated 2022-10-04:
    1. MultiPlus-II GX 24 3kVA; per HQ2231. Not shipping yet
    2. MultiPlus-II GX 48V 3kVA; per HQ2124, Ships from Australia, Spain, Netherlands and South Africa warehouses.
    3. MultiPlus-II GX 48V 5kVA; per HQ2220. Not shipping yet.
    4. EasySolar-II GX 24V 3kVA; introduced per HQ2203. Ships only from the Dutch warehouse
    5. EasySolar-II GX 48V 3kVA; per HQ2229. Ships only from Spain and SA warehouses
    6. EasySolar-II GX 48V 5kVA; per HQ2220. Ships from all warehouses.
venus-os/start.1664884993.txt.gz · Last modified: (external edit)
