Where to buy
Find a dealer near you
Careful – Alternator Charging Lithium
(or how to not blow up your alternator)
Charging lithium batteries from an alternator, be that in a boat or vehicle, presents some challenges when compared to the straightforward nature of charging lead based batteries.
The video in this blog highlights these lithium challenges and shows you what can happen when things go wrong – namely alternator overheating, smoke and an expensive alternator replacement, not to mention the risk of a battery thermal event.
The two key issues demonstrated in the video are:
The test rig in the video is by Victron Energy dealer, ATI Energy, Bucharest.
In this video, by Jonathan Cecil of Journey with Jono, we put both a traditional and a regulated alternator through their paces.
Using different RPM, we charge a 300Ah lithium battery and test the results.
It’s only by using the correct lithium battery charging solution/s in a given situation, that you can be sure of system safety.
Victron have a range of solutions, such as the Buck-Boost DC-DC Converter (used in the Victron Van install), and the similar lower power Orion-Tr Smart DC-DC Charger Isolated, as well as the BMS 12/200 as used in Jono’s canal barge, plus more on the way.
BMS 12/200 installed in Jono’s canal barge.
So – stay tuned, as Victron are in the middle of expanding their range of alternator charging for lithium batteries.
In the meantime make sure you are using the right tool for the job – all of which can be discussed on the Victron Community.
John Rushworth
Support
Warranty
©Victron Energy 2026
