4. Technical specifications
GX IO-Extender 150 | ||
Supply voltage | Powered by USB | |
Power consumption | < 100 mW when idle, max, 1 W (< 200 mA @ 5 V) | |
Mounting | Wall or DIN-rail (by using adapter accessory) | |
Input and Output connectivity | ||
Digital I/Os (isolated from USB) | 8 I/Os with LEDs indicating state, configurable as 8 inputs, 8 outputs or 4 inputs + 4 outputs | |
Inputs: 3,8 – 5,5 V, Outputs: 5 V, 4 mA max The digital I/Os are capable to handle voltages up to 5,5 V. Any overvoltage can cause permanent damage | ||
PWM output (isolated from USB) | 4 channels with LEDs indicating the state Voltage level: 5 V, Precision: 8 bits @ 1,5625 kHz | |
Latching relays (potential free) | 2x latching relays (bi-stable) with LEDs indicating the state | |
Contact rating (resistive load): DC: 3 A @ 30 V, 1 A @ 60 V, 0,3 A @ 220 V (90 W max) AC: 2 A @ 60 V, 1 A @ 125 V, 0,5 A @ 250 V (125VA max) | ||
Solid switch (isolated from USB) | Max battery voltage: | 70 VDC |
Max load current: | 4 A | |
Max capacitive load: | Vbat up to 15 V: 1000 µF 15 V < Vbat < 30 V: 400 µF 30 V < Vbat < 70 V: 50 µF | |
Max inductive load: | Up to 1 A: 1000 mH 1 A < | < 2 A: 100 mH More than 2 A: 10 mH | |
Dimensions | ||
Outer dimensions (h x w x d) | 123 x 67 x 23 mm | |
Weight | 0,170 kg | |
Operating temperature range | -20 °C to +50 °C | |
