Electrical | 12/5 | 12/7 | 12/10 | 12/15 | 12/25 | |
Mains power voltage (Nominal | Min/Max) | 110 - 120VAC | 100 - 130VAC | |||||
Mains power frequency (Nominal | Min/Max) | 50 - 60Hz | 45 - 65Hz | |||||
Power factor | >0.6 | |||||
Standby power | 0.5W | |||||
Max efficiency | 94% | |||||
Charge voltage (Absorption | Float | Storage) | Normal | 14.4V | 13.8V | 13.2V | ||||
High | 14.7V | 13.8V | 13.2V | |||||
Li-ion | 14.2V | N/A | 13.5V | |||||
Temperature compensation (N/A for Li-ion) | -16mV/°C (-9mV/°F) | |||||
Charge algorithm | 7-stage adaptive (4 stage for Li-ion) | |||||
Charge current limit (in selected mode) | Max | 5A | 7A | 10A | 15A | 25A |
Low | 2A | 2A | 3A | 4A | 10A | |
Max battery capacity (≥0.1C in max mode) | 50Ah | 70Ah | 100Ah | 150Ah | 250Ah | |
Min battery capacity - Lead-acid (≤0.3C in selected mode) | Max | 17Ah | 23Ah | 33Ah | 50Ah | 83Ah |
Low | 7Ah | 7Ah | 10Ah | 13Ah | 33Ah | |
Min battery capacity - Li-ion (≤0.5C in selected mode) | Max | 10Ah | 14Ah | 20Ah | 30Ah | 50Ah |
Low | 4Ah | 4Ah | 6Ah | 8Ah | 20Ah | |
Fault protection | Reverse polarity, output short circuit and over temperature | |||||
Communication | Bluetooth (via VictronConnect app) | |||||
Bluetooth power and frequency | +4dBm | 2402 - 2480MHz | |||||
Cooling | Convection (no fan) | |||||
Operating temperature range | -20 to 50°C (-4 to 122°F) with full rated output up to 30°C (86°F) | |||||
Max humidity | 95% | |||||
Pollution degree (PD) | 2 | |||||
Overvoltage category (OVC) | II | |||||
Physical | ||||||
Material and colour | Plastic | Black | |||||
Mains power connection | 1.8m (6ft) mains cable with US NEMA 1-15P plug | |||||
Battery connection | Type | 1.5m (5ft) figure-8 red/black cable with interchangeable battery connections (M8 ring terminals and battery clamps included) | ||||
Cable | 16 AWG | 14 AWG | 12 AWG | 10 AWG | ||
Ingress protection (IP) rating | IP65 | |||||
Weight | 0.8kg (1.8lb) | 0.9kg (2.0lb) | 1.9kg (4.2lb) | |||
Dimensions (h x w x d) | 12/5 and 12/7: 47 x 95 x 190 mm (1.9 x 3.7 x 7.5 inch) 12/10 and 12/15: 60 x 105 x 190 mm (2.4 x 4.1 x 7.5 inch) 12/25: 75 x 140 x 240 mm (3.0 x 5.5 x 9.4 inch) | |||||
Compliance | ||||||
Safety | UL1236, CSA22.2 | |||||
EMC | FCC15B, ICES-003 | |||||
Electrical | 24/5 | 24/8 | 24/13 | |
Max efficiency | 95% | |||
Charge voltage (Absorption | Float | Storage) | Normal | 28.8V | 27.6V | 26.4V | ||
High | 29.4V | 27.6V | 26.4V | |||
Li-ion | 28.4V | N/A | 27.0V | |||
Temperature compensation (N/A for Li-ion) | -32mV/°C (-18mV/°F) | |||
Charge current limit (in selected mode) | Max | 5A | 8A | 13A |
Low | 2A | 3A | 4A | |
Max battery capacity (≥0.1C in max mode) | 50Ah | 80Ah | 130Ah | |
Min battery capacity - Lead-acid (≤0.3C in selected mode) | Max | 17Ah | 27Ah | 43Ah |
Low | 7Ah | 10Ah | 13Ah | |
Min battery capacity - Li-ion (≤0.5C in selected mode) | Max | 16Ah | 24Ah | 32Ah |
Low | 8Ah | 12Ah | 16Ah | |
Physical | ||||
Cable | 16 AWG | 14 AWG | 10 AWG | |
Weight | 0.8kg (1.8lb) | 0.9kg (2.0lb) | 1.9 kg (4.2lb) | |
Dimensions (h x w x d) | 47 x 95 x 190 mm (1.9 x 3.7 x 7.5 inch) | 60 x 105 x 190 mm (2.4 x 4.1 x 7.5 inch) | 75 x 140 x 240 mm (3.0 x 5.5 x 9.4 inch) | |
Compliance | ||||
