Where to buy
Find a dealer near you
Garmin integration offers RVers fingertip control of everything
Single screen, whole-van control
“RV-C is a communications protocol used on board Recreational Vehicles based on the Controller Area Network bus. Using Vicron’s Cerbo GX MK2 allows for internal Victron CAN communication integration while also broadcasting RV-C to external devices.
“A key advantage of this networking is the ability to combine systems rather than operate each one in isolation.
“Because of the extensive communication within the ecosystem, we can now prompt actions from far more data triggers. For example, with our pet-safe mode we are able to set a thermostat to keep the cabin within a chosen temperature range using different systems – which might include hydronic heating, air conditioning and ventilation fans.
“Furthermore, because we can see advanced Victron data we can trigger those methods of climate control based on the available energy. If the system detects AC ‘shore’ power, higher energy-consuming devices – such as air conditioning or electric heaters – can be initiated.
“If a shore power disconnect is detected, higher-consumption devices can be shut down when the battery SOC % falls below a preset level; and instead the ventilation fans will be used for cooling …or the diesel/gas furnace will be initiated to provide heat.
“As you can see, this deeper integration allows us to provide users with far more advanced choices, seamlessly.
(Application Engineer Jordan Burgess programs a power system unique to customer needs.)
“Integrating Victron systems with the Garmin Core System, takes a significant step forward in providing a unified, efficient, and user-friendly platform. It allows for visibility and control of all critical systems – including energy and water systems, heating, ventilation, and lighting – through a single-screen, eradicating the clutter of the traditional RV control panel.
“By incorporating all systems into a single screen – navigation, battery power data, tank levels, etc – their clients are able to use features intuitively and without explanation. The old ‘grand tours’ of system education about heating, cooling, and power consumption now presents itself in one convenient location. The client is impressed by that experience and the relationship between the client and builder is elevated.
“A key component of this integration is the Cerbo GX MK2, which serves as the communication and monitoring hub for the Victron system. The MK2 includes two fully functional VE.Can ports, with VE.Can 1 being fully isolated. This CAN channel isolation provides the ability to use the RV-C protocol alongside a Lynx Smart BMS CAN protocol which requires its own VE.Can channel and protocol.”
[You can investigate the differences between the Cerbo GX, and Mk 2 devices in this comparison table.]End User, and OEM benefits“For End Users:
Our videographer, Jono, recently filmed a Victron/Garmin integration in Europe:
If you’re in Europe you can visit the van featured in this video on the Victron Energy stand, Hall 13/C32, at the Caravan Salon Düsseldorf exhibition in Germany which runs between August 31 – Sept 8.
Artek offers support to OEMs and dealers across North America through continued technological advancements. Their proprietary ‘Garmin Core System’ provides an easy to install off-the-shelf solution to the latest Garmin RV integration, and they can assist with development of bespoke integrations.Need advice? Our highly trained dealers are happy to help with questions, small or large.
Support
Warranty
©Victron Energy 2026
