Where to buy
Find a dealer near you
A sleeker, more modern looking MultiPlus in the 500VA – 800VA range with voltages of 12, 24 and 48V is set to replace the earlier MultiPlus Compact range. If you are familiar with Victron Energy products you might just have noticed that 48V is now included in the new range, which wasn’t the case with the Compacts. The new range is gradually being introduced. Here are the ones planned for stock at the end of July.
Very little is the answer as the new design has all the exceptional features from before, plus the new sleeker and more modern look.
The new design, when comparing the new models above with comparable earlier Compacts has slightly differing dimensions – a little wider and a bit smaller in depth – as h x w x d in mm for the new 800VA range is 375 x 240 x 100, compared to 375 x 214 x 110 previously.
And let’s not forget the price – it’s now less than the original Compact.
Here’s a view of the base and connections of the MultiPlus 12/800/35-16 230V VE.Bus.
DIP switches are behind the small ‘Settings’ panel. Note there is now one VE.BUS connection due to space constraints, whereas there were two previously (which were paralleled anyhow).
If you are an end user you might not be aware of all that can be done with a MultiPlus. Here’s a précis of this multifunctional product.
The MultiPlus, as the name suggests, is a combined inverter and charger in one elegant package. Its many features include a true sine wave inverter, adaptive charging, hybrid PowerAssist technology, plus multiple system integration features.
To learn more please see the blog ‘MultiPlus magic: Small generator, big power‘, where I do my best to explain much that a MultiPlus can do.
Further information and datasheets for the models above can be found here.
To learn when a new product is in stock or planned, if a distributor or dealer, there is of course e-order. For end users simply contact your dealer and you could be one of the first with a new style MultiPlus. First come, first served…
John Rushworth
Support
Warranty
©Victron Energy 2026
