4. BMS tester
The BMS tester tab allows emulation of a Lithium NG battery. This allows BMS functionality to be inspected without a physical Lithium NG battery and is particularly useful for commissioning and troubleshooting.
The BMS tester allows inspection of BMS functions using external hardware circuits, for example:
ATD
ATC
Pre-alarm
Relay status
Setup procedure
Data exchange overview
The Sent BMS Info tab displays:
The Received BMS Info tab displays:
Battery emulator controls
Battery current can be set using the slider or text input:
