Inverter VE.Direct 230V Manual
6. Technical specifications
In this section:
6.1. Technical specifications Inverter VE.Direct 230V
12/250
24/250
48/250
12/375
24/375
48/375
12/500
24/500
48/500
12/800
24/800
48/800
12/1200
24/1200
48/1200
12/1600
24/1600
48/1600
Continuous power at 25°C
250W
375W
450W
800W
1150W
1450W
Continuous power at 40°C
200W
300W
380W
650W
1000W
1300W
Time-limited power (cold start)
300W/15s
450W/10s
500W/1h
900W/1h
1200W/1h
1600W/1h
Peak power
400W/2s
600W/2s
750W/3s
1200W/15s
1600W/15s
2100W/15s
Output AC voltage
230V +/- 3%
Output AC frequency (adjustable)
50 or 60Hz +/- 0.1%
Input DC voltage range
9.2 - 17V
18.4 - 34V
36.8 -62V
Low battery shutdown DC voltage (adjustable)
9.3V
18.6V
37.2V
Dynamic (load dependent) DC low shut down (fully configurable)
Yes, see the Dynamic cut off chapter.
Low battery restart & alarm DC voltage (adjustable)
10.9V
21.8V
43.6V
Battery charged detect DC voltage (adjustable)
14.0V
28V
56V
Max. efficiency
84%
86%
86%
86%
88%
88%
86%
88%
88%
90%
90%
91%
91%
91%
92%
91%
91%
92%
Zero-load power
5W
6W
8W
6W
7W
9W
7W
8W
10W
8W
8W
9W
11W
11W
12W
14W
14W
15W
Default zero-load power in ECO mode (default search interval: 2.5s, adjustable)
1W
1W
2W
1W
1W
2W
1W
1W
2W
1W
2W
2W
1W
2W
3W
1W
2W
3W
ECO mode stop and start power setting
Adjustable
Protection (2)
a – g
Operating temperature range
-40 to +65°C (fan-assisted cooling)
Power derating
1.25% per °C above 40°C
Humidity (non-condensing)
max 95%
ENCLOSURE
Material and colour
Steel chassis and plastic cover (blue Ral 5012)
Battery connection terminals
Screw terminals
Maximum battery cable cross-section
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
10 mm²
25 mm²
16 mm²
16 mm²
35 mm²
25 mm²
25 mm²
50mm²
25 mm²
25 mm²
Standard AC outlets
SCHUKO model: CEE 7/4
IEC model: IEC-320 (male plug included)
UK model: BS 1363
AU/NZ model: AS/NZS 3112
Protection category
IP 21
Weight
2.7 kg
3 kg
3.5 kg
5.5 kg
7.2 kg
8.9 kg
Dimensions (hxwxd, mm)
86x165x260
86x165x260
86x165x260
86x165x260
86x165x260
86x165x260
86x172x275
86x172x275
86x172x275
95x231x334
105x216x310
105x216x310
117x231x374
117x231x333
117x231x333
117x231x395
117x231x365
117x231x365
ACCESSORIES
Remote on/off terminal
Yes
Automatic AC transfer switch
Not built-in. Add a Filax2 transfer switch, or use an inverter/charger instead.
STANDARDS
Safety
EN/IEC 60335-1, EN/IEC 62109-1
EMC
EN 55014-1, EN 55014-2
IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3
Automotive Directive
ECE R10-4 pending
  1. Output socket:
    X=1: IEC
    X=2: Schuko
    X=3: AU/NZ
    X=4: UK
  2. Protection key:
    a. Output short circuit
    b. Overload
    c. Battery voltage too high
    d. Battery voltage too low
    e. Temperature too high
    f. 230VAC on inverter output
    g. DC ripple too high
