9. Technical specifications
Electrical | 12/4 | 12/5 | 12/7 | 12/10 | 12/15 | 12/25 | |
Mains power voltage (Nominal | Min/Max) | 220 - 240VAC | 180 - 265VAC | ||||||
Mains power frequency (Nominal | Min/Max) | 50 - 60Hz | 45 - 65Hz | ||||||
Power factor | >0.6 | ||||||
Standby power | 0.5W | ||||||
Max efficiency | 94% | ||||||
Charge voltage (Absorption | Float | Storage) | Normal | 14.4V | 13.8V | 13.2V | |||||
High | 14.7V | 13.8V | 13.2V | ||||||
Li-ion | 14.2V | N/A | 13.5V | ||||||
Temperature compensation (N/A for Li-ion) | -16mV/°C (-9mV/°F) | ||||||
Charge algorithm | 7-stage adaptive (4 stage for Li-ion) | ||||||
Charge current limit (in selected mode) | Max | 4A | 5A | 7A | 10A | 15A | 25A |
Low | 2A | 2A | 2A | 3A | 4A | 10A | |
Max battery capacity (≥0.1C in max mode) | 40Ah | 50Ah | 70Ah | 100Ah | 150Ah | 250Ah | |
Min battery capacity - Lead-acid (≤0.3C in selected mode) | Max | 13Ah | 17Ah | 23Ah | 33Ah | 50Ah | 83Ah |
Low | 7Ah | 7Ah | 7Ah | 10Ah | 13Ah | 33Ah | |
Min battery capacity - Li-ion (≤0.5C in selected mode) | Max | 8Ah | 10Ah | 14Ah | 20Ah | 30Ah | 50Ah |
Low | 4Ah | 4Ah | 4Ah | 6Ah | 8Ah | 20Ah | |
Fault protection | Reverse polarity, output short circuit and over temperature | ||||||
Communication | Bluetooth (via VictronConnect app) | ||||||
Bluetooth power and frequency | +4dBm | 2402 - 2480MHz | ||||||
Cooling | Convection (no fan) | ||||||
Operating temperature range | -40 to 50°C (-40 to 122°F) with full rated output up to 30°C (86°F) | ||||||
Max humidity | 95% | ||||||
Physical | |||||||
Material and colour | Plastic | Black | ||||||
Mains power connection | 1.5m (5ft) mains cable with CEE 7/16, CEE 7/17, BS 1363 or AS/NZS 3112 plug | ||||||
Battery connection | Type | 1.5m (5ft) figure-8 red/black cable with interchangeable battery connections (M8 ring terminals and battery clamps included) | |||||
Cable | 16 AWG | 14AWG | 12AWG | 10AWG | |||
Ingress protection (IP) rating | IP65 | ||||||
Weight | 0.6kg (1.3lb) | 0.8kg (1.8lb) | 0.9kg (2.0lb) | 1.9kg (4.2kg) | |||
Dimensions (h x w x d) | 12/4 and 12/5: 45 x 81 x 183 mm (1.8 x 3.2 x 7.2 inch) 12/7: 47 x 95 x 190 mm (1.9 x 3.7 x 7.5 inch) 12/10 and 12/15: 60 x 105 x 190 mm (2.4 x 4.1 x 7.5 inch) 12/25: 75 x 140 x 240 mm (3.0 x 5.5 x 9.4 inch) | ||||||
Compliance | |||||||
Safety | EN 60335-1, EN 60335-2-29 | ||||||
EMC | ETSI EN 301 489-1 V2.2.3, ETSI EN 301 489-17 V3.2.4, ETSI EN 300 328 V2.2.2 | ||||||
Automotive | ECE R10 | ||||||
Electrical | 24/5 | 24/8 | 24/13 | |
Max efficiency | 95% | |||
Charge voltage (Absorption | Float | Storage) | Normal | 28.8V | 27.6V | 26.4V | ||
High | 29.4V | 27.6V | 26.4V | |||
Li-ion | 28.4V | N/A | 27.0V | |||
Temperature compensation (N/A for Li-ion) | -32mV/°C (-18mV/°F) | |||
Charge current limit (in selected mode) | Max | 5A | 8A | 13A |
Low | 2A | 3A | 4A | |
Max battery capacity (≥0.1C in max mode) | 50Ah | 80Ah | 130Ah | |
Min battery capacity - Lead-acid (≤0.3C in selected mode) | Max | 17Ah | 27Ah | 43Ah |
Low | 7Ah | 10Ah | 13Ah | |
Min battery capacity - Li-ion (≤0.5C in selected mode) | Max | 16Ah | 24Ah | 32Ah |
Low | 8Ah | 12Ah | 16Ah | |
Physical | ||||
Cable | 16 AWG | 14 AWG | 10 AWG | |
Weight | 0.8kg (1.8lb) | 0.9kg (2.0lb) | 1.9kg (4.2lb) | |
Dimensions (h x w x d) | 47 x 95 x 190 mm (1.9 x 3.7 x 7.5 inch) | 60 x 105 x 190 mm (2.4 x 4.1 x 7.5 inch) | 75 x 140 x 240 mm (3.0 x 5.5 x 9.4 inch) | |
Compliance | ||||
