Victron GX product range
Introduction
The GX-device lies at the heart of the system - providing monitoring, and operating as the communication-centre of your installation. All the other system-components - such as inverter/chargers, solar chargers, and batteries - are connected to it. Monitoring can be carried out locally and remotely - via our free-to-use Victron Remote Management portal (VRM). The GX-device also provides Remote firmware updates and allows inverter/charger settings to be changed remotely.
- Color Control GX - Our first released GX product, the CCGX has a display and buttons.
- Venus GX - The Venus GX has more analog and digital IO, no LCD and is more cost effective than the CCGX.
- CANvu GX - The CANvu GX is best for harsh environments - when its IP67 rating and touch LCD is a must.
- Octo GX - The Octo GX is particularly suited to medium size installations which have many MPPT Solar Chargers, as it has 10 VE.Direct ports.
- Maxi GX - Compared to the other GX devices, the Maxi GX has most CPU power and most VE.Direct ports: 25. This is the GX device to use for large systems with many VE.Direct MPPT Solar Chargers.
Lastly, there is a GX device built into our MultiPlus-II GX and EasySolar-II GX Inverter/chargers.
Available accessories
- GX GSM - A cellular modem. It connects to Venus-device via USB, and takes a simcard
- VE.Can resistive tank sender adapter Allows a standard resistive tank-level sender to be connected to the Venus-device.
Comparison table
User interface | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Appearance | ![]() | ![]() | ![]() | ![]() | ![]() | ![]() |
Display | LCD Display & 7 buttons | no display | no display | 4.3“ touch-screen | 2×16 character display | |
Remote Console | yes | |||||
Buzzer | yes | yes | no | yes | no | |
Documentation | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Manual | CCGX manual | VGX manual | OGX manual | CANvu manual | Maxi GX manual | MultiPlus-II GX |
Product detail page | CCGX product | VGX product | OGX product | CANvu product | Maxi GX product | |
Victron comm. ports | CCGX | Venus GX | Octo GX | CANvu GX(12) | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
VE.Direct ports (always isolated) | 2 (1) | 10 (1) | 3 (1) | 25 | 1 | |
VE.Can | 2 paralleled RJ45 sockets – isolated | |||||
VE.Bus | 2 paralleled RJ45 sockets – isolated | 1 isolated RJ45 socket | 2 paralleled RJ45 sockets – isolated | |||
Non Victron-products | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Canbus-BMS batteries | Many battery brands. See here for details | |||||
Fronius PV Inverters | See here for details | |||||
SMA PV Inverters | See here for details | |||||
ABB PV Inverters | See here for details | |||||
SolarEdge PV Inverters | See here for details | |||||
Communication | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
USB | 2 USB Host ports – not isolated | 1 USB Host port - not isolated | ||||
Ethernet | 10/100 RJ45 socket - isolated except shield | 1 port. isolation?(12) | 10/100 RJ45 socket | |||
WiFi | optional (2) | built-in, but see (3) | built-in, external antenna (11) | optional (2) | no | built-in |
Bluetooth Smart | no | |||||
Micro SDcard slot | SDHC cards up to max. of 32GB. (5) | no | yes | no | ||
Second CAN-bus port | no | yes - non-isolated | yes - non-isolated | yes - non-isolated | no | no |
Built-in RS485 | no | no | yes - non-isolated | no | no | |
IO | CCGX | Venus GX | Octo GX | CANvu GX(12) | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Programmable relay (7) | 1x NO | 1x NO / NC (8) | 1x NO / NC | 2x NO / NC (8) | n/a | |
Resistive tank level inputs | no | 3 (9) | no | |||
Temperature sense inputs | no | 2 (10) | no | |||
Digital Inputs | no | 5 | 3 | 1 | 4 | no |
Performance | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
CPU | single core | quad core | ||||
RAM | 256MB | 512MB | 512MB | 256MB | 512MB | 512MB |
Max. VE.Direct devices (1) | 5 | 6 | 10 | 4 | 25 | 25 |
Other | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Supply voltage | 8 - 70 VDC | 8 - 32 VDC | 32 - 70 VDC | powered internally, no external supply | ||
Mounting | Panel Integration | Wall mounting | DIN Rail (35mm) | Panel | Wall mount IP65 | Built-in |
Outer dimensions ( h x w x d ) | 130 x 120 x 28 mm | 45 x 143 x 96 mm | 61 x 108 x 90 mm | ? | 600 x 380 x 210 mm | |
Operating temperature | -20 to +50°C | -20 to +70°C | -20 to +50°C | |||
Battery backupped clock | yes | no | yes | yes | ||
Standards | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Safety | EN 60950 | ? | ? | ? | ||
EMC | EN 61000-6-3, EN 55014-1, EN 61000-6-2, EN 61000-6-1, EN 55014-2 | |||||
Automotive | E4-10R-053535 | In progress | ? | ? | no |
Notes
- The listed maximum on the `Performance` section in above table is the total connected VE.Direct devices such as MPPT Solar Charge controllers. Total means all directly connected devices plus the devices connected over USB. The limit is mostly bound by CPU processing power. Note that there is also a limit to the other type of devices of which often multiple are connected: PV Inverters. Up to three or four three phase inverters can typically be monitored on a CCGX. Higher power CPU devices can monitor more.
- The hardware of the Venus GX and Octo GX includes a built-in Bluetooth Smart chipset which hasn't proved satisfactory. Bluetooth Smart for Venus-devices is coming soon but will not use built-in chipsets.
- The Venus GX has two temperature terminals which can be used to measure & monitor all kinds of temperature-inputs. Temperature senders are not included. The required sensor is ASS000001000 - Temperature Sensor QUA/PMP/Venus GX. (Note that this is not the same as the BMV temperature accessory.)
- Requires the CANvu GX IO Extender and wiring kit
